<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Installing on Xubuntu 18.04.6 LTS]]></title><description><![CDATA[<p dir="auto">hi there,<br />
please forgive me if im posting in the wrong place, im new to linux and life. My first install was on a rpi3 which went without a hitch. I want to use an old acer 5672wlmi 32 bit laptop with Xubuntu 18.04.6 LTS to run magic mirror.<br />
i chose xubuntu because of its low requirements and that version is the last to support 32 bit machines.<br />
After install, it spat out some errrors about node.js and npm. From what i gathered, ithe versions that shipped with OS were too low and so after some googling i managed to  manually install newest versions of the 2 from unofficial builds. i keep getting this error,(see attached) please help me i ve spent so much time and effort on this, i really want it to work! Any help or direction appreciated.<br />
BTW im open to using other lightweight 32bit linux if it will run MM.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17526/installing-on-xubuntu-18-04-6-lts</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 13:12:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17526.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Jan 2023 03:50:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Sun, 20 Oct 2024 21:26:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pato" aria-label="Profile: pato">@<bdi>pato</bdi></a> too old, sorry</p>
]]></description><link>https://forum.magicmirror.builders/post/120703</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120703</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Oct 2024 21:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Wed, 23 Oct 2024 16:19:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pato" aria-label="Profile: pato">@<bdi>pato</bdi></a> yeh,. last  time x86 nodejs was distributed was version 8, in 2019</p>
<pre><code>node-v8.17.0-linux-x86.tar.gz                      17-Dec-2019 06:30            18294008
node-v8.17.0-linux-x86.tar.xz
]]></description><link>https://forum.magicmirror.builders/post/120788</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120788</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 23 Oct 2024 16:19:03 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Sun, 20 Oct 2024 22:49:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pato" aria-label="Profile: pato">@<bdi>pato</bdi></a> i have s chromebook w ubuntu16.04<br />
and too small disk to upgrade</p>
<p dir="auto">it was my traveling dev machine</p>
]]></description><link>https://forum.magicmirror.builders/post/120707</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120707</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Oct 2024 22:49:48 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Sun, 20 Oct 2024 22:02:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Too bad, I’m 2 years late . Thanks anyway for the quick reply. I’ll try to find a solution.</p>
]]></description><link>https://forum.magicmirror.builders/post/120704</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120704</guid><dc:creator><![CDATA[pato]]></dc:creator><pubDate>Sun, 20 Oct 2024 22:02:48 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Sun, 20 Oct 2024 21:26:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pato" aria-label="Profile: pato">@<bdi>pato</bdi></a> too old, sorry</p>
]]></description><link>https://forum.magicmirror.builders/post/120703</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120703</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Oct 2024 21:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Sun, 20 Oct 2024 21:17:01 GMT]]></title><description><![CDATA[<p dir="auto">Hello everyone,<br />
I’m Patrick from France. I’m also trying to install MagicMirror on an old 32 bit computer. Like Rukytech, I’ve installed Raspberry pi OS and tried the sdetweil script installation. Unfortunately, I get a 404 error apparently, when installing node.js.</p>
<p dir="auto">I get the following message:<br />
curl: (22) The requested URL returned error: 404<br />
Error: download preflight failed for ‘20.9.0’ (<a href="https://nodejs.org/dist/v20.9.0" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/dist/v20.9.0</a><br />
/node-v20.9.0- Linux-x86. tar. xz)</p>
<p dir="auto">And indeed, it seems that the file node-v20.9.0- Linux-x86. tar. xz no longer exists.<br />
Thanks in advance if anyone has an idea. I hope it’s not a problem to have resurrected this old topic.</p>
]]></description><link>https://forum.magicmirror.builders/post/120701</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120701</guid><dc:creator><![CDATA[pato]]></dc:creator><pubDate>Sun, 20 Oct 2024 21:17:01 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Thu, 12 Jan 2023 03:52:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rukytech" aria-label="Profile: rukytech">@<bdi>rukytech</bdi></a> try it out, let me know… if troubles, email me the ~/install.log  same userid at gmail</p>
]]></description><link>https://forum.magicmirror.builders/post/107184</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107184</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Jan 2023 03:52:46 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Thu, 12 Jan 2023 03:45:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> sweet! thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/107183</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107183</guid><dc:creator><![CDATA[rukytech]]></dc:creator><pubDate>Thu, 12 Jan 2023 03:45:36 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Thu, 12 Jan 2023 03:44:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rukytech" aria-label="Profile: rukytech">@<bdi>rukytech</bdi></a> said in <a href="/post/107173">Installing on Xubuntu 18.04.6 LTS</a>:</p>
<p dir="auto">Also does this script work with any linux distro? Like puppy?</p>
<p dir="auto">should work with any linux distro… tested with a bunch</p>
<p dir="auto">haven’t tried puppy</p>
]]></description><link>https://forum.magicmirror.builders/post/107181</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107181</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Jan 2023 03:44:13 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Thu, 12 Jan 2023 02:07:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rukytech" aria-label="Profile: rukytech">@<bdi>rukytech</bdi></a> you said yes to pm2, SO… its JOB is to start and keep mm running…</p>
<p dir="auto">SO,</p>
<p dir="auto">alt-spacebar,n to minimize MM</p>
<p dir="auto">ctrl-alt-t to open a terminal window</p>
<p dir="auto">pm2 status to see what being managed<br />
pm2 stop MagicMirror<br />
or<br />
pm2 stop the number of the line (0 probably)<br />
or<br />
pm2 stop all</p>
<p dir="auto">pm2 --help for all the other thing pm2 can do</p>
]]></description><link>https://forum.magicmirror.builders/post/107174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107174</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Jan 2023 02:07:38 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Thu, 12 Jan 2023 02:05:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i installed raspberrypiOS on the laptop(making it a rpi basically) and i tried the manual installation but again i had errors. I assume i keep getting the node and npm versions wrong. I popped in ur script and worked like a charm. Thank you again.  Now, everytime i close the magic mirror app, it automatically restarts, i assume its by dessign from the last part of the script. Is there a way to disbale it temporarily until im done setting it up?<br />
]]></description><link>https://forum.magicmirror.builders/post/107173</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107173</guid><dc:creator><![CDATA[rukytech]]></dc:creator><pubDate>Thu, 12 Jan 2023 02:05:17 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Wed, 11 Jan 2023 05:13:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> many thanks for the quick reply, i shall try it out today and report with results</p>
]]></description><link>https://forum.magicmirror.builders/post/107130</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107130</guid><dc:creator><![CDATA[rukytech]]></dc:creator><pubDate>Wed, 11 Jan 2023 05:13:06 GMT</pubDate></item><item><title><![CDATA[Reply to Installing on Xubuntu 18.04.6 LTS on Tue, 10 Jan 2023 03:57:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rukytech" aria-label="Profile: rukytech">@<bdi>rukytech</bdi></a> use my install script.</p>
<p dir="auto">see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/107117</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107117</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 10 Jan 2023 03:57:30 GMT</pubDate></item></channel></rss>
