<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wireless controle outlet ikea]]></title><description><![CDATA[<p dir="auto">Hi, I’ve (almost) finished my MM setup. I’m using Ikea’s tradfri  to turn on/off the <a href="https://www.lenovo.com/lb/en/monitors/D27-30/" target="_blank" rel="noopener noreferrer nofollow ugc">monitor</a> and a <a href="https://www.ikea.com/nl/en/p/mittled-led-kitchen-worktop-lighting-strip-dimmable-white-70528569/" target="_blank" rel="noopener noreferrer nofollow ugc">led strip</a>. Well that was the idea. The monitor is connected to the <a href="https://www.ikea.com/nl/en/p/tradfri-wireless-control-outlet-smart-90356166/" target="_blank" rel="noopener noreferrer nofollow ugc">wireless controle outlet</a> and activated with the <a href="https://www.ikea.com/nl/en/p/tradfri-wireless-motion-sensor-smart-white-70429913/" target="_blank" rel="noopener noreferrer nofollow ugc">wireless motion sensor</a>. The motion sensor is also used for the led strip which is connected directly to the power outlet.</p>
<p dir="auto">The problem is that the monitor is not always (most of the time actually) powered on when motion is detected. Sometimes I get the startup logo and then it stops and sometimes it does work.</p>
<p dir="auto">Any idea how to solve this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17529/wireless-controle-outlet-ikea</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 01:52:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17529.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Jan 2023 09:42:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wireless controle outlet ikea on Wed, 11 Jan 2023 18:12:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eurtnl" aria-label="Profile: eurtnl">@<bdi>eurtnl</bdi></a> yes, on all time time.</p>
<p dir="auto">good luck…</p>
]]></description><link>https://forum.magicmirror.builders/post/107150</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107150</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Jan 2023 18:12:47 GMT</pubDate></item><item><title><![CDATA[Reply to Wireless controle outlet ikea on Wed, 11 Jan 2023 17:45:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Okay but in that case the TV/Monitor is always powered on isn’t it? My mirror is in the bathroom and I only use the bathroom in the morning when I wake up and in the evening when I go to bed.</p>
<p dir="auto">I have face-recognition installed so maybe that could wake the monitor when it’s a sleep. Not the best solution in my case. Maybe I need to get another wireless control outlet. I have some Hue stuff that I could try.</p>
]]></description><link>https://forum.magicmirror.builders/post/107149</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107149</guid><dc:creator><![CDATA[eurtnl]]></dc:creator><pubDate>Wed, 11 Jan 2023 17:45:50 GMT</pubDate></item><item><title><![CDATA[Reply to Wireless controle outlet ikea on Wed, 11 Jan 2023 16:29:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eurtnl" aria-label="Profile: eurtnl">@<bdi>eurtnl</bdi></a> I know what u want.</p>
<p dir="auto">I have a tv that cannot turn back on via power.<br />
so I hide all the modules instead. sorta my hall nightlite.</p>
<p dir="auto">but, it has another quirk.  because there is no change in the HDMI signal, after 15 minutes it powers off anyhow!!!</p>
<p dir="auto">so I changed my sleepwake module to wakeup ever 14 minutes 58 seconds for 2 seconds, show all the content,  and go back to sleep(hiding all the modules again).  tv is happy and 99.9% of the time I am not watching the monitor when it happens… sleeping, out of the house, watching TV… whatever… so it’s not an issue</p>
]]></description><link>https://forum.magicmirror.builders/post/107145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107145</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Jan 2023 16:29:46 GMT</pubDate></item><item><title><![CDATA[Reply to Wireless controle outlet ikea on Wed, 11 Jan 2023 15:53:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  When my monitor is turned on and I disconnect it from the power supply and then connect it back with power it’s powered on. So the monitor stays in powered on mode even when disconnected from power supply. So I figured this should work. Strange thing is that sometimes it works okay.<br />
I could add a switch to manually power the monitor but the idea was to do it all on motion detection.</p>
]]></description><link>https://forum.magicmirror.builders/post/107144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107144</guid><dc:creator><![CDATA[eurtnl]]></dc:creator><pubDate>Wed, 11 Jan 2023 15:53:21 GMT</pubDate></item><item><title><![CDATA[Reply to Wireless controle outlet ikea on Wed, 11 Jan 2023 14:52:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eurtnl" aria-label="Profile: eurtnl">@<bdi>eurtnl</bdi></a> 2300w is  20 amps!  .  doubt the monitor takes more than 5.  (600w).</p>
<p dir="auto">so, I don’t think that is that problem.</p>
<p dir="auto">if the time between off and back on is short enough there is probably some residual charge left over in the monitor power supply.</p>
<p dir="auto">after a number of minutes/hours this dissipates.</p>
<p dir="auto">none of my current monitors will turn on by  their power cord . all require button push.</p>
<p dir="auto">I used to have an.old 17 monitor that  I could power on with an external power switch. almost 10 years ago now</p>
]]></description><link>https://forum.magicmirror.builders/post/107141</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107141</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Jan 2023 14:52:15 GMT</pubDate></item><item><title><![CDATA[Reply to Wireless controle outlet ikea on Wed, 11 Jan 2023 14:32:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> My best guess is that the wireless control outlet is not delivering enough power for the monitor when it is powered on when motion is detected by the motion sensor :(</p>
<p dir="auto">The manual states that the outlet has max. output power 2300W, that should be enough for a monitor.</p>
]]></description><link>https://forum.magicmirror.builders/post/107140</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107140</guid><dc:creator><![CDATA[eurtnl]]></dc:creator><pubDate>Wed, 11 Jan 2023 14:32:47 GMT</pubDate></item><item><title><![CDATA[Reply to Wireless controle outlet ikea on Wed, 11 Jan 2023 14:20:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eurtnl" aria-label="Profile: eurtnl">@<bdi>eurtnl</bdi></a> sadly  no.</p>
<p dir="auto">if on/off was controlled by the os mm is running on, then if the monitor supported the CEC interface you could power on/off thru vec-cliebt commands.</p>
<p dir="auto">all energystar compliant monitors/TV’s are required to power off after 15 mins of no usage, detected by monitoring the HDMI signal</p>
<p dir="auto">most of the software commands turn off the HDMI port, which will cause the timeout, AND a big ugly display  no input</p>
]]></description><link>https://forum.magicmirror.builders/post/107139</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107139</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Jan 2023 14:20:14 GMT</pubDate></item></channel></rss>
