<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[launching on browser?]]></title><description><![CDATA[<p dir="auto">Hey there! I have successfully installed mm on my laptop running Ubuntu and using the script. Now I’m trying to replicate that in debian 11 but instead of launching electron like it does in Ubuntu it’s launching a web browser and the localhost:8080 (which is unable to connect) I don’t quite understand what happened here. Maybe the script maked a different kind of installation?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17530/launching-on-browser</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 00:09:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17530.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Jan 2023 13:57:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to launching on browser? on Sun, 15 Jan 2023 00:27:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thank you for your replys and your wonderful script, I’m currently running magic mirror without problems</p>
]]></description><link>https://forum.magicmirror.builders/post/107267</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107267</guid><dc:creator><![CDATA[dude31222]]></dc:creator><pubDate>Sun, 15 Jan 2023 00:27:52 GMT</pubDate></item><item><title><![CDATA[Reply to launching on browser? on Thu, 12 Jan 2023 13:27:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dude31222" aria-label="Profile: dude31222">@<bdi>dude31222</bdi></a> i just installed debian 11 in a vm…</p>
<p dir="auto">I had to add  the user to sudoers and then install curl as it was not installed…</p>
<p dir="auto">then the script ran fine, altho I had to add the path to bash   for the script, even tho bash is the default</p>
<p dir="auto">all of those are system issues, not script or mm</p>
]]></description><link>https://forum.magicmirror.builders/post/107185</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107185</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Jan 2023 13:27:34 GMT</pubDate></item><item><title><![CDATA[Reply to launching on browser? on Wed, 11 Jan 2023 17:02:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dude31222" aria-label="Profile: dude31222">@<bdi>dude31222</bdi></a> sure  love to see the log file.</p>
<p dir="auto">I’ve tested on a bunch of OSs all debian based without trouble.</p>
<p dir="auto">I’ll build a VM to check it out as well</p>
]]></description><link>https://forum.magicmirror.builders/post/107147</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107147</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Jan 2023 17:02:36 GMT</pubDate></item><item><title><![CDATA[Reply to launching on browser? on Wed, 11 Jan 2023 16:41:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sorry, I don’t have it anymore. Just made a clean install of xubuntu and after a couple of hours now mm is working. For what I’ve tried this days seems like all the distros based on debian have the same problem, Raspbian desktop, debian 11, emmabuntus…<br />
If you like I can make another install whit debian and email you the log file</p>
]]></description><link>https://forum.magicmirror.builders/post/107146</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107146</guid><dc:creator><![CDATA[dude31222]]></dc:creator><pubDate>Wed, 11 Jan 2023 16:41:22 GMT</pubDate></item><item><title><![CDATA[Reply to launching on browser? on Wed, 11 Jan 2023 14:53:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dude31222" aria-label="Profile: dude31222">@<bdi>dude31222</bdi></a> I do this approach on pi0w where electron is no longer available</p>
]]></description><link>https://forum.magicmirror.builders/post/107142</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107142</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Jan 2023 14:53:11 GMT</pubDate></item><item><title><![CDATA[Reply to launching on browser? on Wed, 11 Jan 2023 14:15:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dude31222" aria-label="Profile: dude31222">@<bdi>dude31222</bdi></a> can you show me the ~/install.log, or email to me. same userid at gmail</p>
<p dir="auto">it looks like I set it up to run server mode w my run-start script.  but it gets the port from the server startup message. that’s what’s in config.js</p>
<p dir="auto">note address: is localhost  which means ONLY apps INSIDE the same booted os can connect<br />
if this is in a VM or docker container  THAT is the booted os.</p>
]]></description><link>https://forum.magicmirror.builders/post/107138</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107138</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Jan 2023 14:15:35 GMT</pubDate></item></channel></rss>
