<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TOTAL BEGINNER: Exit Code 512 RPi 3 A+ Black Screen and Countless Issues Downloading and Running MagicMirror]]></title><description><![CDATA[<p dir="auto">Hey all! Brand new to coding and the raspberry pi system. I apologize if this has been asked but my level of knowledge on this makes it difficult to follow on the forums as I have been trying to understand them for the past 2 days. Would love to learn more on how to diagnose on my own and commands/pathways to do so. But right now I need step-by-step help please.</p>
<p dir="auto">Been enjoying learning some basic coding but getting frustrated as I run into issues either installing dependencies or running the mirror (as it only goes to black screen). I have tried multiple fresh flashes, disabled proxies, toggled OpenGL, but I still cannot run the MagicMirror. I have VNC and SSH enabled and followed all of the manual install steps including updating NPM and nodes. This morning I finally got it all downloaded with no issues except now running it does not work. On running magic mirror, it does not register as a tab “Magic Mirror” but rather just says “Electron”. I get the below error:</p>
<p dir="auto">b083rt@raspberrypi:~/MagicMirror $ npm run start</p>
<p dir="auto">magicmirror@2.22.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">[14.01.2023 10:56.54.642] [LOG]   Starting MagicMirror: v2.22.0<br />
[14.01.2023 10:56.54.656] [LOG]   Loading config …<br />
[14.01.2023 10:56.54.679] [LOG]   Loading module helpers …<br />
[14.01.2023 10:56.54.692] [LOG]   No helper found for module: alert.<br />
[14.01.2023 10:56.54.765] [LOG]   Initializing new module helper …<br />
[14.01.2023 10:56.54.767] [LOG]   Module helper loaded: updatenotification<br />
[14.01.2023 10:56.54.772] [LOG]   No helper found for module: clock.<br />
[14.01.2023 10:56.55.779] [LOG]   Initializing new module helper …<br />
[14.01.2023 10:56.55.782] [LOG]   Module helper loaded: calendar<br />
[14.01.2023 10:56.55.788] [LOG]   No helper found for module: compliments.<br />
[14.01.2023 10:56.55.794] [LOG]   No helper found for module: weather.<br />
[14.01.2023 10:56.55.884] [LOG]   Initializing new module helper …<br />
[14.01.2023 10:56.55.886] [LOG]   Module helper loaded: newsfeed<br />
[14.01.2023 10:56.55.887] [LOG]   All module helpers loaded.<br />
[14.01.2023 10:56.56.267] [LOG]   Starting server on port 8080 …<br />
[14.01.2023 10:57.01.501] [LOG]   Server started …<br />
[14.01.2023 10:57.01.613] [LOG]   Connecting socket for: updatenotification<br />
[14.01.2023 10:57.01.626] [LOG]   Starting module helper: updatenotification<br />
[14.01.2023 10:57.01.627] [LOG]   Connecting socket for: calendar<br />
[14.01.2023 10:57.01.628] [LOG]   Starting node helper for: calendar<br />
[14.01.2023 10:57.01.629] [LOG]   Connecting socket for: newsfeed<br />
[14.01.2023 10:57.01.631] [LOG]   Starting node helper for: newsfeed<br />
[14.01.2023 10:57.01.632] [LOG]   Sockets connected &amp; modules started …<br />
[14.01.2023 10:57.05.241] [LOG]   Launching application.<br />
[1533:0114/105728.847152:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=512<br />
[1533:0114/105744.845855:ERROR:network_service_instance_impl.cc(521)] Network service crashed, restarting service.<br />
[1533:0114/105752.223672:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=512<br />
[1619:0114/105803.367801:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization<br />
[1644:0114/105807.873067:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.<br />
[1593:0114/105812.122302:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.</p>
<p dir="auto">I believe this code tells you the version of software if this helps:</p>
<p dir="auto">b083rt@raspberrypi:~ $ cat /etc/os-release<br />
PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”<br />
NAME=“Debian GNU/Linux”<br />
VERSION_ID=“11”<br />
VERSION=“11 (bullseye)”<br />
VERSION_CODENAME=bullseye<br />
ID=debian<br />
HOME_URL=“<a href="https://www.debian.org/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.debian.org/</a>”<br />
SUPPORT_URL=“<a href="https://www.debian.org/support" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.debian.org/support</a>”<br />
BUG_REPORT_URL=“<a href="https://bugs.debian.org/" target="_blank" rel="noopener noreferrer nofollow ugc">https://bugs.debian.org/</a>”</p>
]]></description><link>https://forum.magicmirror.builders/topic/17540/total-beginner-exit-code-512-rpi-3-a-black-screen-and-countless-issues-downloading-and-running-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 06:32:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17540.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Jan 2023 16:24:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TOTAL BEGINNER: Exit Code 512 RPi 3 A+ Black Screen and Countless Issues Downloading and Running MagicMirror on Sat, 14 Jan 2023 16:41:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/b083rt" aria-label="Profile: B083Rt">@<bdi>B083Rt</bdi></a>  where u do npm start, type this in advance</p>
<pre><code>export ELECTRON_DISABLE_GPU=1
<p dir="auto">then execute<br />
npm start</p>
<p dir="auto">this should turn off the electron use of the gpu chip.</p>
<p dir="auto">if you use a script, u can add this before it’s npm start</p>
<p dir="auto">also, run my install script it does all the setup.</p>
<p dir="auto">flash again then run install<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/107244</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107244</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 14 Jan 2023 16:41:39 GMT</pubDate></item></channel></rss>
