<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic mirror using the IKEA Hogbo glass door]]></title><description><![CDATA[<p dir="auto">Hi all. My plan is to use the billy bookcase with the Ikea Hogbo glass with one way film applied as a magicmirror. I know film is not the best but one way mirror is far too expensive for this DIY project. The Hogbo door uses aluminium extrusion border and I was wondering if anyone has ideas of how to attach the screen to the door. I was thinking of using aluminium extrusions but not sure how to go about doing that.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17563/magic-mirror-using-the-ikea-hogbo-glass-door</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 09:22:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17563.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Jan 2023 15:25:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic mirror using the IKEA Hogbo glass door on Sun, 12 Feb 2023 10:21:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jose-walsh" aria-label="Profile: Jose-Walsh">@<bdi>Jose-Walsh</bdi></a> Thanks for that suggestion. I did look into that but most extrusions are 2 cm and I think they would stick out too much.  I think I have a solution: the door hinges that IKEA provides slots into the aluminium frame (which is an extrusion of its own). It uses 2 screws to holf it in place. So, my idea is to use those to hang a frame on. I will use double sided tape to stick the screen but the frame will bear the weight.  However, they provide 3 hinges and I need more for the other side. Now, one thing I just learned is that IKEA will send you spare parts for free if some broke. so I will get an extra 2 hinges, hack of the hinge part and use the rest to secure the screen on the other side. Will follow up when I am a bit further along. But of course, to anyone else reading this, still open to ideas.</p>
]]></description><link>https://forum.magicmirror.builders/post/107822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107822</guid><dc:creator><![CDATA[Thedoomguy6312]]></dc:creator><pubDate>Sun, 12 Feb 2023 10:21:32 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror using the IKEA Hogbo glass door on Sun, 12 Feb 2023 10:21:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jose-walsh" aria-label="Profile: Jose-Walsh">@<bdi>Jose-Walsh</bdi></a> Thanks for that suggestion. I did look into that but most extrusions are 2 cm and I think they would stick out too much.  I think I have a solution: the door hinges that IKEA provides slots into the aluminium frame (which is an extrusion of its own). It uses 2 screws to holf it in place. So, my idea is to use those to hang a frame on. I will use double sided tape to stick the screen but the frame will bear the weight.  However, they provide 3 hinges and I need more for the other side. Now, one thing I just learned is that IKEA will send you spare parts for free if some broke. so I will get an extra 2 hinges, hack of the hinge part and use the rest to secure the screen on the other side. Will follow up when I am a bit further along. But of course, to anyone else reading this, still open to ideas.</p>
]]></description><link>https://forum.magicmirror.builders/post/107823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107823</guid><dc:creator><![CDATA[Thedoomguy6312]]></dc:creator><pubDate>Sun, 12 Feb 2023 10:21:32 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror using the IKEA Hogbo glass door on Wed, 08 Feb 2023 15:41:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoomguy6312" aria-label="Profile: Thedoomguy6312">@<bdi>Thedoomguy6312</bdi></a> said in <a href="/post/107411">Magic mirror using the IKEA Hogbo glass door</a>:</p>
<p dir="auto">One option for attaching the screen to the door could be to use a frame made of aluminum extrusions. You could cut the extrusions to the correct size and use screws or brackets to attach them to the door, creating a frame around the screen. To secure the screen to the frame, you could use double-sided tape or Velcro strips. If you have access to tools such as a drill or saw, you may be able to customize the frame to fit the screen and door perfectly.</p>
]]></description><link>https://forum.magicmirror.builders/post/107747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107747</guid><dc:creator><![CDATA[Jose Walsh]]></dc:creator><pubDate>Wed, 08 Feb 2023 15:41:50 GMT</pubDate></item></channel></rss>
