<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NUC instead?]]></title><description><![CDATA[<p dir="auto">I’ve got a spare NUC. Fully appreciate that’s it’s a bit of overkill (I have my 3B running but a card failed). How would I go about getting the base setup going? Pm2 autoboot, base install, what OS?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17592/nuc-instead</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 03:13:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17592.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Feb 2023 00:45:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NUC instead? on Sat, 04 Feb 2023 02:44:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yk" aria-label="Profile: yk">@<bdi>yk</bdi></a> never used client mode.   but yes, same approach</p>
<p dir="auto">client/full needs desktop to run browser</p>
]]></description><link>https://forum.magicmirror.builders/post/107671</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107671</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Feb 2023 02:44:19 GMT</pubDate></item><item><title><![CDATA[Reply to NUC instead? on Sat, 04 Feb 2023 02:36:37 GMT]]></title><description><![CDATA[<p dir="auto">Understood.  Thanks.</p>
<p dir="auto">Server seems doable.  With the NUC it’ll have a bit more horsepower to run my iCloud sync and Weather setups (nothing overly painful to be honest).</p>
<p dir="auto">Does the client 3B also run MM then?  Meaning run your install scripts but instead update <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> to run client?</p>
<p dir="auto">I fear I’m making the setup overly complex (only satisfying my tinkering needs).  Would you agree or have you found that a server &gt; client setup works better?  (curious of opinion)</p>
]]></description><link>https://forum.magicmirror.builders/post/107670</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107670</guid><dc:creator><![CDATA[yk]]></dc:creator><pubDate>Sat, 04 Feb 2023 02:36:37 GMT</pubDate></item><item><title><![CDATA[Reply to NUC instead? on Sat, 04 Feb 2023 02:30:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yk" aria-label="Profile: yk">@<bdi>yk</bdi></a> all the normal setup, just change the installers/mm.sh<br />
to do</p>
<pre><code>npm run server
<p dir="auto">instead of npm start</p>
<p dir="auto">then client can be browser or u can change <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> to run</p>
<pre><code>npm run client
<p dir="auto">after doing install somewhere else.</p>
<p dir="auto">one install can be any personality,<br />
full. server or client</p>
]]></description><link>https://forum.magicmirror.builders/post/107669</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107669</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Feb 2023 02:30:14 GMT</pubDate></item><item><title><![CDATA[Reply to NUC instead? on Sat, 04 Feb 2023 02:24:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Sam.  The 3B has been running fine for years.  Now that the card failed I’m tempted to go the server &gt; client route.  So the NUC would run Debian, kick off your scripts, it runs in server mode, I do all of the normal setup that I did previously on the pi?  How does the client setup work once I replace the failed card?</p>
<p dir="auto">And, be honest, is this overkill?  Once a new card comes in I can redo the setup on the 3B.</p>
]]></description><link>https://forum.magicmirror.builders/post/107668</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107668</guid><dc:creator><![CDATA[yk]]></dc:creator><pubDate>Sat, 04 Feb 2023 02:24:35 GMT</pubDate></item><item><title><![CDATA[Reply to NUC instead? on Sat, 04 Feb 2023 02:19:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yk" aria-label="Profile: yk">@<bdi>yk</bdi></a> pick any linux, and then use my install script.</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/107667</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107667</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Feb 2023 02:19:57 GMT</pubDate></item></channel></rss>
