<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-VolvoOnCall upgrade get wrong]]></title><description><![CDATA[<p dir="auto">Help.<br />
Yesterday after updating from Buster to Bullseye IOS<br />
The module is stopt working.<br />
I Think i’ts getting wrong in the Pyton3 script.</p>
<p dir="auto">The command shell “voc list” is giffing multi errors.<br />
<img src="/assets/uploads/files/1676808174907-img_4586-resized.jpg" alt="IMG_4586.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/17631/mmm-volvooncall-upgrade-get-wrong</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 17:37:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17631.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Feb 2023 12:03:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-VolvoOnCall upgrade get wrong on Mon, 20 Feb 2023 06:20:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a><br />
oke…<br />
The problem is solved.<br />
First I dit the install of  <code> sudo pip install aiohttp</code><br />
Then <code>sudo pip install docopt</code><br />
And last <code>cd volvooncall</code><br />
<code>git pull</code><br />
<code>sudo python3 setup.py install</code><br />
<code>voc list</code></p>
<p dir="auto">And the data was back.<br />
So I think in the upgrade to Bullseye the python3.9 was not complete<br />
After the 2 extra install the module was running again.</p>
]]></description><link>https://forum.magicmirror.builders/post/107971</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107971</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Mon, 20 Feb 2023 06:20:36 GMT</pubDate></item></channel></rss>
