<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[EADDRINUSE: address already in use 127.0.0.1:8090]]></title><description><![CDATA[<p dir="auto">When I boot up the MagicMirror I will get a blank screen with a cursor.  The message in the log is the following.  If I simply change the port to anything else, 8080 then the mirror boots up fine.  If I get the error I switch it back to 8090 and it goes away again.  I have nothing running on the machine. It is a raspberry pi II with only MagicMirror.  TIA</p>
<pre><code>/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
0|MagicMir | [19.02.2023 07:55.11.006] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8090
0|MagicMir |     at Server.setupListenHandle [as _listen2] (node:net:1432:16)
0|MagicMir |     at listenInCluster (node:net:1480:12)
0|MagicMir |     at GetAddrInfoReqWrap.doListen [as callback] (node:net:1629:7)
0|MagicMir |     at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:111:8) {
0|MagicMir |   code: 'EADDRINUSE',
0|MagicMir |   errno: -98,
0|MagicMir |   syscall: 'listen',
0|MagicMir |   address: '127.0.0.1',
0|MagicMir |   port: 8090
0|MagicMir | }
0|MagicMir | [19.02.2023 07:55.11.008] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|MagicMir | [19.02.2023 07:55.11.010] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
0|MagicMir | [2472:0219/075514.107308:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
0|MagicMir | [2505:0219/075514.639247:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
]]></description><link>https://forum.magicmirror.builders/topic/17632/eaddrinuse-address-already-in-use-127-0-0-1-8090</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 02:35:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17632.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Feb 2023 13:41:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to EADDRINUSE: address already in use 127.0.0.1:8090 on Sat, 04 Mar 2023 23:05:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/theaddies" aria-label="Profile: theaddies">@<bdi>theaddies</bdi></a> sorry. no idea myself.</p>
<p dir="auto">I gave up long ago trying to remember the 900 different ways to auto start things on the myriad different  platforms.</p>
]]></description><link>https://forum.magicmirror.builders/post/108103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108103</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Mar 2023 23:05:11 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE: address already in use 127.0.0.1:8090 on Sat, 04 Mar 2023 21:49:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for the reply but I have no idea what I see did</p>
]]></description><link>https://forum.magicmirror.builders/post/108102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108102</guid><dc:creator><![CDATA[theaddies]]></dc:creator><pubDate>Sat, 04 Mar 2023 21:49:53 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE: address already in use 127.0.0.1:8090 on Sat, 04 Mar 2023 14:53:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/theaddies" aria-label="Profile: theaddies">@<bdi>theaddies</bdi></a> you must have added it as part of the manual install instructions</p>
<p dir="auto">do the reverse to take it out…</p>
]]></description><link>https://forum.magicmirror.builders/post/108098</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108098</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Mar 2023 14:53:14 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE: address already in use 127.0.0.1:8090 on Sat, 04 Mar 2023 13:14:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I suppose this makes sense but I killed it and it immediately restarted. I don’t know how to remove it.</p>
]]></description><link>https://forum.magicmirror.builders/post/108096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108096</guid><dc:creator><![CDATA[theaddies]]></dc:creator><pubDate>Sat, 04 Mar 2023 13:14:38 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE: address already in use 127.0.0.1:8090 on Sat, 04 Mar 2023 13:12:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I found /usr/bin node serveronly.</p>
<p dir="auto">is that the culpirit?</p>
]]></description><link>https://forum.magicmirror.builders/post/108095</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108095</guid><dc:creator><![CDATA[theaddies]]></dc:creator><pubDate>Sat, 04 Mar 2023 13:12:11 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE: address already in use 127.0.0.1:8090 on Sun, 19 Feb 2023 22:53:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/theaddies" aria-label="Profile: theaddies">@<bdi>theaddies</bdi></a> look for running processes</p>
<p dir="auto">pm2 stop all<br />
ps -ef |  grep  node</p>
<p dir="auto">or</p>
<p dir="auto">ps -ef | grep npm</p>
]]></description><link>https://forum.magicmirror.builders/post/107953</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107953</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 19 Feb 2023 22:53:38 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE: address already in use 127.0.0.1:8090 on Sun, 19 Feb 2023 22:29:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for the reply. I think I did have 2 instances at one time, but I deleted the other one. It does not show up on pm2 status. Is there anything else to remove? Thansk.</p>
]]></description><link>https://forum.magicmirror.builders/post/107960</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107960</guid><dc:creator><![CDATA[theaddies]]></dc:creator><pubDate>Sun, 19 Feb 2023 22:29:06 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE: address already in use 127.0.0.1:8090 on Sun, 19 Feb 2023 13:59:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/theaddies" aria-label="Profile: theaddies">@<bdi>theaddies</bdi></a> that means something is using the port , maybe you have two instances of mm trying to run</p>
<p dir="auto">do</p>
<p dir="auto">pm2 status</p>
<p dir="auto">are there 2 apps defined?</p>
]]></description><link>https://forum.magicmirror.builders/post/107948</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107948</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 19 Feb 2023 13:59:12 GMT</pubDate></item></channel></rss>
