<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-DBF suddenly does not work]]></title><description><![CDATA[<p dir="auto">Hello,<br />
my MM works fine but since a few days the module MMM-DBF does not work any longer. No text is shown and sometimes it´s comming back again but after a few hours it´s gone again, even after a restart of the Raspi.</p>
<p dir="auto">I installed the whole MM new but it´s the same mistake.</p>
<p dir="auto">Anybody else with this problem?? MMM-DBF did work fine for a year or longer without any problems.</p>
<p dir="auto">Thanks for your help…</p>
<p dir="auto">Volkae</p>
]]></description><link>https://forum.magicmirror.builders/topic/17640/mmm-dbf-suddenly-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 09:59:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17640.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Feb 2023 20:41:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Wed, 24 May 2023 13:53:27 GMT]]></title><description><![CDATA[<p dir="auto">Now the module works fine but since the last update on yesterday there is a Message on my MM that there is an update for your module available.</p>
<p dir="auto">I did</p>
<p dir="auto">git pull<br />
npm install --omit=dev</p>
<p dir="auto">in the module-folder from your module but the update-message is still shown in the MM</p>
]]></description><link>https://forum.magicmirror.builders/post/109464</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109464</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Wed, 24 May 2023 13:53:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Tue, 21 Mar 2023 21:30:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/volkae" aria-label="Profile: Volkae">@<bdi>Volkae</bdi></a> I was able to get the ID easily. I’ll write you a direct message as it doesn’t belong here with this module.</p>
]]></description><link>https://forum.magicmirror.builders/post/108327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108327</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Tue, 21 Mar 2023 21:30:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Mon, 20 Mar 2023 17:37:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
It seems Hamburg Elbgaustraße ist not in the DB-Profile. Cannot find the station-id.</p>
]]></description><link>https://forum.magicmirror.builders/post/108300</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108300</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Mon, 20 Mar 2023 17:37:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Sun, 19 Mar 2023 19:15:58 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Are you sure that the problem is not the data stream from DB?</p>
<p dir="auto">No, I’m not sure. You could contact the operator of the API and ask if he sees anything suspicious at the station.</p>
<p dir="auto">How long did you test the stations?</p>
<p dir="auto">Only 10 hours. At the moment I don’t have the possibility for longer tests.</p>
<p dir="auto">It would be nice if we could find and eliminate the cause of the problem. I just don’t have the capacity to delve deeper into this at the moment. An alternative would be to switch to the following module for this station: <a href="https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas</a></p>
]]></description><link>https://forum.magicmirror.builders/post/108275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108275</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Sun, 19 Mar 2023 19:15:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Sun, 19 Mar 2023 12:50:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
now my npm is 9.6.1 but nothing changed<br />
At this moment “Hamburg Eidelstedt” does work, “Hamburg Elbgaustraße” does not work<br />
Are you sure that the problem is not the data stream from DB?<br />
How long did you test the stations?<br />
Sometimes it works fine for more than 15 hours or more…</p>
]]></description><link>https://forum.magicmirror.builders/post/108267</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108267</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Sun, 19 Mar 2023 12:50:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Sat, 11 Mar 2023 16:13:56 GMT]]></title><description><![CDATA[<p dir="auto">A shot in the blue: Update your npm. I have version 9.6.1.</p>
]]></description><link>https://forum.magicmirror.builders/post/108202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108202</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Sat, 11 Mar 2023 16:13:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Sat, 11 Mar 2023 12:07:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
Node = v16.19.1<br />
npm = v8.19.3<br />
MM is the newest version</p>
<p dir="auto">It´s frozen after 20 hours and more. Even after a restart of the raspi  MMM-DBF does not show anything (New an old version of MMM-DBF).</p>
]]></description><link>https://forum.magicmirror.builders/post/108193</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108193</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Sat, 11 Mar 2023 12:07:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Sat, 11 Mar 2023 00:23:28 GMT]]></title><description><![CDATA[<p dir="auto">I have now run “Hamburg Elbgaustraße” for two hours without any problems.</p>
<p dir="auto">Which version of MagicMirror, which of node (<code>node -v</code>) and which of npm (<code>npm -v</code>) do you use?</p>
]]></description><link>https://forum.magicmirror.builders/post/108188</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108188</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Sat, 11 Mar 2023 00:23:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Thu, 09 Mar 2023 09:49:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
Hey Kristjan,<br />
thank you for your post.<br />
Maybe there is a problem with a few stations.<br />
If it shows “Hamburg HBF” it works correctly since two days,<br />
if it shows “Hamburg Eidelstedt” it works for a few hours correctly and then it stopps,<br />
if it shows “Hamburg Elbgaustraße” it does not work (it worked fine before).</p>
<p dir="auto">Do you think there is a problem with the data-stream from DB?</p>
]]></description><link>https://forum.magicmirror.builders/post/108164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108164</guid><dc:creator><![CDATA[Volkae]]></dc:creator><pubDate>Thu, 09 Mar 2023 09:49:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Mon, 06 Mar 2023 00:53:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/volkae" aria-label="Profile: Volkae">@<bdi>Volkae</bdi></a> Please try my fork:</p>
<p dir="auto"><code>git clone https://github.com/KristjanESPERANTO/MMM-DBF</code></p>
<p dir="auto">Let me know if it runs more stable.</p>
]]></description><link>https://forum.magicmirror.builders/post/108120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108120</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Mon, 06 Mar 2023 00:53:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DBF suddenly does not work on Tue, 28 Feb 2023 21:21:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/volkae" aria-label="Profile: Volkae">@<bdi>Volkae</bdi></a> it’s 3 years since last update. my guess is the service changed</p>
<p dir="auto">I’d post an issue to the module GitHub. but w 3 years since last update I’m not optimistic…</p>
]]></description><link>https://forum.magicmirror.builders/post/108056</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108056</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 28 Feb 2023 21:21:18 GMT</pubDate></item></channel></rss>
