<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Netatmo weather data in weather module]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">has a Netatmo owner already managed to feed the data from the standard weather module with the current temperature of the Netatmo outdoor module?<br />
Can be actually no big deal, but unfortunately I didn’t find anything corresponding here in the forum.</p>
<p dir="auto">Thanks and greetings,</p>
<p dir="auto">Docci</p>
]]></description><link>https://forum.magicmirror.builders/topic/17664/netatmo-weather-data-in-weather-module</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 10:22:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17664.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Mar 2023 17:55:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Netatmo weather data in weather module on Sun, 02 Apr 2023 05:24:16 GMT]]></title><description><![CDATA[<p dir="auto">@Docjump<br />
I am using both and the temperatures are quite close, difference is most of time below 0.3 °C. I don’t know which value is the more relevant one.<br />
And in some cases (sun directly over the Netatmo sensor) the difference is greater but the weather API seems the reliable one in this case.</p>
]]></description><link>https://forum.magicmirror.builders/post/108563</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108563</guid><dc:creator><![CDATA[Thierry7100]]></dc:creator><pubDate>Sun, 02 Apr 2023 05:24:16 GMT</pubDate></item><item><title><![CDATA[Reply to Netatmo weather data in weather module on Mon, 27 Mar 2023 22:15:41 GMT]]></title><description><![CDATA[<p dir="auto">Just disable the MM default weather module and use Netatmo</p>
]]></description><link>https://forum.magicmirror.builders/post/108422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108422</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Mon, 27 Mar 2023 22:15:41 GMT</pubDate></item><item><title><![CDATA[Reply to Netatmo weather data in weather module on Sun, 26 Mar 2023 08:01:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thierry7100" aria-label="Profile: Thierry7100">@<bdi>Thierry7100</bdi></a> said in <a href="/post/108268">Netatmo weather data in weather module</a>:</p>
<p dir="auto">Hi,</p>
<p dir="auto">There is a Netatmo module MMM-Netatmo. It is really nice, I am using it for 3 years now without any problem. It displays all sensors from my Netatmo waether station, indoor, outdoor, rain, anemometer…<br />
Best regards</p>
<p dir="auto">Thierry</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thierry7100" aria-label="Profile: Thierry7100">@<bdi>Thierry7100</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/laz" aria-label="Profile: Laz">@<bdi>Laz</bdi></a> : Thanks, but for sure I know this module. This was not my question. The main fact is, that the weather module shows another temperature than the netatmo module and that’s a bit annoying and confusing. I would rather trust my “physical” module, than a “theoretical” value from some weather-API.</p>
<p dir="auto">So no one combined netatmo-temperature measurement with the weather module, so far? I know it from Mirr.OS, where you can decide from which source the temperature is shown (whether API or netatmo).</p>
]]></description><link>https://forum.magicmirror.builders/post/108406</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108406</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 26 Mar 2023 08:01:04 GMT</pubDate></item><item><title><![CDATA[Reply to Netatmo weather data in weather module on Mon, 20 Mar 2023 11:19:21 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1679311044856-0afeeb92-258a-47c7-bc6e-6380f090acc6-image.png" alt="0afeeb92-258a-47c7-bc6e-6380f090acc6-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/108292</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108292</guid><dc:creator><![CDATA[Laz]]></dc:creator><pubDate>Mon, 20 Mar 2023 11:19:21 GMT</pubDate></item><item><title><![CDATA[Reply to Netatmo weather data in weather module on Sun, 19 Mar 2023 07:46:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
Best regards</p>
]]></description><link>https://forum.magicmirror.builders/post/108268</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108268</guid><dc:creator><![CDATA[Thierry7100]]></dc:creator><pubDate>Sun, 19 Mar 2023 07:46:08 GMT</pubDate></item><item><title><![CDATA[Reply to Netatmo weather data in weather module on Sat, 18 Mar 2023 13:08:52 GMT]]></title><description><![CDATA[<p dir="auto">That would be very nice.</p>
]]></description><link>https://forum.magicmirror.builders/post/108260</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108260</guid><dc:creator><![CDATA[MajorC]]></dc:creator><pubDate>Sat, 18 Mar 2023 13:08:52 GMT</pubDate></item></channel></rss>
