<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Scenes not working with Calendars]]></title><description><![CDATA[<p dir="auto">Im new to all this. Ive managed to figure a lot of this out but I cant figure out why MMM-scenes wont work with my calendar modules. Is it due to MMM-CalendarExt3? If so is there a work around? Ill add the code to the calendar here.<br />
I finally got it to work after removing the code below:<br />
{<br />
module: “MMM-CalendarExt3”,<br />
position: “bottom”,<br />
title: “”,<br />
config: {<br />
mode: “week”,<br />
instanceId: “basicCalendar”,<br />
locale: ‘en-US’,<br />
maxEventLines: 5,<br />
firstDayOfWeek: 0,<br />
calendarSet: [‘apple’,‘outlook’],<br />
weekIndex: -1,<br />
weeksInView: 4,<br />
fontSixe: ‘10px’,<br />
eventHeight: ‘25px’,<br />
}<br />
},</p>
<pre><code>{
		header: "Upcoming Sports",
					symbol: "",
					url: "https://calendar.google.com/calendar",
					symbol: "",
					url: "https://calendar.google.com/calendar/ic",
		header: "apple",
		position: "",
					symbol: "",
					url: "webcal://p137-caldav.icloud.com/published/2/MTAzNz",
				symbol: "",
					url: "https://outlook.live.com/owa/",
]]></description><link>https://forum.magicmirror.builders/topic/17675/mmm-scenes-not-working-with-calendars</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 22:54:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17675.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 18 Mar 2023 23:22:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Scenes not working with Calendars on Wed, 22 Mar 2023 20:00:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> thank you. I got everything working great now. Thanks for all your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/108342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108342</guid><dc:creator><![CDATA[hawkeyepilot69]]></dc:creator><pubDate>Wed, 22 Mar 2023 20:00:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes not working with Calendars on Mon, 20 Mar 2023 23:13:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hawkeyepilot69" aria-label="Profile: hawkeyepilot69">@<bdi>hawkeyepilot69</bdi></a></p>
<p dir="auto">I want to see the “race” and “stars” schedule in the default calendar and “apple” and “outlook” in my MMM-CalendarExt3. this is the way I have it currently set up.</p>
<ol>
<li>
<p dir="auto">To show only specific calendars in CX3, you can use <code>calendarSet: ,</code>, In your case;<br />
<code>calendarSet: ["apple", "outlook"],</code> would be.</p>
</li>
<li>
<p dir="auto">To hide specific calendars in default calendar module; as far as I know, there is no feature in the default calendar module. Sorry, that is not my fault.</p>
</li>
</ol>
<p dir="auto">2-1. But if you use two instances of the default calendar module, one with “race” and “stars”, the other with “apple” and “outlook”, you can hide one by CSS adjusting or removing <code>position</code> value.</p>
]]></description><link>https://forum.magicmirror.builders/post/108309</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108309</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 20 Mar 2023 23:13:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes not working with Calendars on Mon, 20 Mar 2023 10:09:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hawkeyepilot69" aria-label="Profile: hawkeyepilot69">@<bdi>hawkeyepilot69</bdi></a><br />
So now the issue is not the Scene thing but calendar thing how to manage to show only special events or calendars, right?</p>
]]></description><link>https://forum.magicmirror.builders/post/108288</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108288</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 20 Mar 2023 10:09:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes not working with Calendars on Sun, 19 Mar 2023 20:28:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> I got the scenes to work. It seems like it has a problem when i try to set two different groups of calendars. One group for the default calendar and another default calendar group for my MMM-CalendarExt3 to use. I dont want to see all the calendars on the default calendar but the only way to get everything to work is to have all of them there. I was trying to have 2 separate default calendars, one that is shown for 2 certain calendars and the other that is hidden to display the events I want to see on my MMM-calendarExt3. How can I go about hiding some events on the default calendar or creating 2 default calendars one that is shown and one that is not?```<br />
{<br />
module: “calendar”,<br />
header: “Upcoming Sports”,<br />
position: “top_left”,<br />
classes:“scene3”,<br />
hiddenOnStartup: true,<br />
config: {<br />
colored: true,<br />
calendars: [<br />
{<br />
symbol: “”,<br />
url: “”,<br />
<pre><code>			},
					symbol: "",
					url: "",
					color: "#03C04A",
					symbol: "",
					url: "",
				symbol: "",
					url: "",
<pre><code class="language-f">I want to see the "race" and "stars" schedule in the default calendar and "apple" and "outlook" in my MMM-CalendarExt3. this is the way I have it currently set up.</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/108278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108278</guid><dc:creator><![CDATA[hawkeyepilot69]]></dc:creator><pubDate>Sun, 19 Mar 2023 20:28:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes not working with Calendars on Sun, 19 Mar 2023 13:43:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hawkeyepilot69" aria-label="Profile: hawkeyepilot69">@<bdi>hawkeyepilot69</bdi></a><br />
Could you send me the full config.js? <a href="mailto:eouia0819@gmail.com" target="_blank" rel="noopener noreferrer nofollow ugc">eouia0819@gmail.com</a></p>
<p dir="auto">I’m in business trip now, so I’ll see a few days later.</p>
]]></description><link>https://forum.magicmirror.builders/post/108270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108270</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Sun, 19 Mar 2023 13:43:33 GMT</pubDate></item></channel></rss>
