<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Exiting GPU process due to errors during initialization]]></title><description><![CDATA[<p dir="auto">I installed a freh installation from MagicMirror on a RPI3 with  <strong>2023-02-21-raspios-bullseye-armhf</strong> Image.</p>
<p dir="auto">I updated Pi, Electron; NodeJs</p>
<p dir="auto">Bu follwed the Erros i become…</p>
<p dir="auto">1784:0319/124629.513027:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization<br />
[1824:0319/124630.051065:ERROR:gpu_memory_buffer_support_x11.cc(49)] dri3 extension not supported.<br />
[1798:0319/124630.130077:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17676/exiting-gpu-process-due-to-errors-during-initialization</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 05:12:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17676.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Mar 2023 12:24:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Exiting GPU process due to errors during initialization on Tue, 25 Jul 2023 17:59:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/merowinger" aria-label="Profile: Merowinger">@<bdi>Merowinger</bdi></a> this is a pi config issue with the display driver</p>
<p dir="auto">in the short term you can turn off use of the <a href="http://gou.by" target="_blank" rel="noopener noreferrer nofollow ugc">gou.by</a> electron by adding</p>
<pre><code>export ELECTRON_DISABLE_GPU=1
<p dir="auto">before<br />
npm start</p>
<p dir="auto">if u are using my install script and pm2, then the little startup script is</p>
<pre><code>~/MagicMirror/installers/mm.sh
]]></description><link>https://forum.magicmirror.builders/post/110365</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110365</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Jul 2023 17:59:19 GMT</pubDate></item><item><title><![CDATA[Reply to Exiting GPU process due to errors during initialization on Tue, 25 Jul 2023 13:58:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sebi76-0" aria-label="Profile: Sebi76-0">@<bdi>Sebi76-0</bdi></a>  I updated to 2.24.0 and got this problem right now. Strange that nobody can help</p>
]]></description><link>https://forum.magicmirror.builders/post/110364</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110364</guid><dc:creator><![CDATA[Merowinger]]></dc:creator><pubDate>Tue, 25 Jul 2023 13:58:14 GMT</pubDate></item></channel></rss>
