<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Launching Server mode via SSH]]></title><description><![CDATA[<p dir="auto">I have successfully installed MM2 on my Ubuntu server, made sure that IP range of network is added to config.js and also made sure that port 8080 is open on Ubutu server.</p>
<p dir="auto">When I try “npm run server” via SSH I get the following:</p>
<p dir="auto">magicmirror@2.22.0 server<br />
node ./serveronly</p>
<p dir="auto">node:internal/modules/cjs/loader:959<br />
throw err;<br />
^</p>
<p dir="auto">Error: Cannot find module ‘module-alias/register’<br />
Require stack:</p>
<ul>
<li>/home/gideon/MagicMirror/js/app.js</li>
<li>/home/gideon/MagicMirror/serveronly/index.js<br />
at Module._resolveFilename (node:internal/modules/cjs/loader:956:15)<br />
at Module._load (node:internal/modules/cjs/loader:804:27)<br />
at Module.require (node:internal/modules/cjs/loader:1022:19)<br />
at require (node:internal/modules/cjs/helpers:102:18)<br />
at Object. (/home/gideon/MagicMirror/js/app.js:9:1)<br />
at Module._compile (node:internal/modules/cjs/loader:1120:14)<br />
at Module._extensions…js (node:internal/modules/cjs/loader:1174:10)<br />
at Module.load (node:internal/modules/cjs/loader:998:32)<br />
at Module._load (node:internal/modules/cjs/loader:839:12)<br />
at Module.require (node:internal/modules/cjs/loader:1022:19) {<br />
code: ‘MODULE_NOT_FOUND’,<br />
requireStack: [<br />
‘/home/gideon/MagicMirror/js/app.js’,<br />
‘/home/gideon/MagicMirror/serveronly/index.js’<br />
]<br />
}</li>
</ul>
<p dir="auto">Node.js v18.7.0</p>
<p dir="auto">Any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17679/launching-server-mode-via-ssh</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 10:10:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17679.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Mar 2023 11:02:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Launching Server mode via SSH on Mon, 20 Mar 2023 13:23:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/netranger" aria-label="Profile: NetRanger">@<bdi>NetRanger</bdi></a> working w you on discord</p>
]]></description><link>https://forum.magicmirror.builders/post/108294</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108294</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Mar 2023 13:23:40 GMT</pubDate></item></channel></rss>
