<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Position and size of module]]></title><description><![CDATA[<p dir="auto">I try to adjust the position and size of the text clock, that it fits below the weather module. Any idea?<br />
<img src="/assets/uploads/files/1680207829959-position.jpg" alt="Position.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/17700/position-and-size-of-module</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 16:28:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17700.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Mar 2023 20:23:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Position and size of module on Sat, 01 Apr 2023 19:35:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> I had to adjust some numbers in main.css to lower the clock module. Now is fits perfectly.</p>
]]></description><link>https://forum.magicmirror.builders/post/108551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108551</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Sat, 01 Apr 2023 19:35:47 GMT</pubDate></item><item><title><![CDATA[Reply to Position and size of module on Sat, 01 Apr 2023 19:02:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> Please tell me you didn’t edit main.css!</p>
<p dir="auto">In that same directory, please establish “custom.css” and move your css there.</p>
<p dir="auto">You won’t be able to upgrade and keep main.css if you edit main.css directly.</p>
]]></description><link>https://forum.magicmirror.builders/post/108550</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108550</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 01 Apr 2023 19:02:30 GMT</pubDate></item><item><title><![CDATA[Reply to Position and size of module on Fri, 31 Mar 2023 08:08:06 GMT]]></title><description><![CDATA[<p dir="auto">thx - the position is top right for the weather and bottom right for the clock. I fixed the position now in the main css and weater css with trail and error with several adjustments in regards to position, font size and icon size.<br />
Now I’m looking for an overall solution to resize the modules …</p>
]]></description><link>https://forum.magicmirror.builders/post/108498</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108498</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Fri, 31 Mar 2023 08:08:06 GMT</pubDate></item><item><title><![CDATA[Reply to Position and size of module on Fri, 31 Mar 2023 07:58:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> Position is easy. change the position in the config.js to match the Weather module, and move it’s config to after the weather module.</p>
<p dir="auto">As for size, that’s CSS, and I don’t use the standard module, so I don’t know how to do it.</p>
]]></description><link>https://forum.magicmirror.builders/post/108497</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108497</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Fri, 31 Mar 2023 07:58:02 GMT</pubDate></item></channel></rss>
