<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can't get seconds to not show up?]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/8876/mmm-digclock">MMM-DigClock</a></p>
<p dir="auto">I can’t get to remove seconds.</p>
<pre><code>            {
                    module: "MMM-DigClock",
                    position: "middle_center",
                            showDate: false,
                            showSeconds: false,
                            timezone: "America/LosAngeles"
<p dir="auto">This is correct right?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17702/can-t-get-seconds-to-not-show-up</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Jul 2026 20:30:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17702.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Mar 2023 17:12:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can't get seconds to not show up? on Fri, 31 Mar 2023 18:37:14 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your prompt response!</p>
]]></description><link>https://forum.magicmirror.builders/post/108532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108532</guid><dc:creator><![CDATA[rsun]]></dc:creator><pubDate>Fri, 31 Mar 2023 18:37:14 GMT</pubDate></item><item><title><![CDATA[Reply to Can't get seconds to not show up? on Fri, 31 Mar 2023 18:07:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/rsun" aria-label="Profile: rsun">@<bdi>rsun</bdi></a> so, to work this temporarily</p>
<pre><code>git clone as normal
git fetch origin pull/2/head:seconds
git checkout seconds
]]></description><link>https://forum.magicmirror.builders/post/108531</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108531</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 31 Mar 2023 18:07:30 GMT</pubDate></item><item><title><![CDATA[Reply to Can't get seconds to not show up? on Fri, 31 Mar 2023 18:01:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rsun" aria-label="Profile: rsun">@<bdi>rsun</bdi></a> Hi,<br />
there is a bug in the original module which causes the <code>showSeconds</code> flag to be ignored.<br />
The issue is fixed in this fork <a href="https://github.com/justjim1220/MMM-DigClock/pull/2/commits/c160d3c4477ae2b535470f032dab34914f2f8356" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/justjim1220/MMM-DigClock/pull/2/commits/c160d3c4477ae2b535470f032dab34914f2f8356</a> but it has not been merged since nearly three years.</p>
]]></description><link>https://forum.magicmirror.builders/post/108530</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108530</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Fri, 31 Mar 2023 18:01:15 GMT</pubDate></item><item><title><![CDATA[Reply to Can't get seconds to not show up? on Fri, 31 Mar 2023 17:59:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rsun" aria-label="Profile: rsun">@<bdi>rsun</bdi></a> while the doc says there is a parameter to control seconds,   the code does not do anything with that parameter  or provide a way to remove seconds</p>
]]></description><link>https://forum.magicmirror.builders/post/108529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108529</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 31 Mar 2023 17:59:01 GMT</pubDate></item></channel></rss>
