<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Double use MM?]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/1773/double-use-mm</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 09:01:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1773.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Feb 2017 23:11:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Double use MM? on Thu, 16 Feb 2017 01:58:12 GMT]]></title><description><![CDATA[<p dir="auto">I have my MM running Amazon’s Alexa, as well, using <a href="https://github.com/alexa/alexa-avs-sample-app" target="_blank" rel="noopener noreferrer nofollow ugc">this software.</a></p>
<p dir="auto">Running both seems to make the Alexa app a bit buggier, though</p>
]]></description><link>https://forum.magicmirror.builders/post/14666</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14666</guid><dc:creator><![CDATA[psm9]]></dc:creator><pubDate>Thu, 16 Feb 2017 01:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to Double use MM? on Thu, 16 Feb 2017 00:59:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnnyboy" aria-label="Profile: johnnyboy">@<bdi>johnnyboy</bdi></a> Naaaaawwww was  perfectly legit question.</p>
<p dir="auto">You can minimize the mirror software and use it as a computer if you’d like… just like using a regular computer :)</p>
]]></description><link>https://forum.magicmirror.builders/post/14660</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14660</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 16 Feb 2017 00:59:45 GMT</pubDate></item><item><title><![CDATA[Reply to Double use MM? on Wed, 15 Feb 2017 23:19:24 GMT]]></title><description><![CDATA[<p dir="auto">No, you can use it as a regular desktop of you want, just install a browser and the music player of choice on the same linux dist. as the MM.</p>
<p dir="auto">Basically you run MM as any other software/app on a computer.</p>
]]></description><link>https://forum.magicmirror.builders/post/14648</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14648</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Wed, 15 Feb 2017 23:19:24 GMT</pubDate></item></channel></rss>
