<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PM2 beendet und startet MM andauernd nach Update]]></title><description><![CDATA[<p dir="auto">Guten Morgen, mein MM funktioniert nachdem Update nicht mehr richtig.<br />
Es wird automatisch beendet und neugestartet von pm2.</p>
<p dir="auto">Hier der PM2 LOG:</p>
<pre><code>0|mm     | &gt; magicmirror@2.23.0 start
0|mm     | &gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
0|mm     | [15.04.2023 11:09.43.757] [LOG]   Starting MagicMirror: v2.23.0
0|mm     | [15.04.2023 11:09.43.773] [LOG]   Loading config ...
0|mm     | [15.04.2023 11:09.43.781] [DEBUG] config template file not exists, no envsubst
0|mm     | [15.04.2023 11:09.43.793] [LOG]   Loading module helpers ...
0|mm     | [15.04.2023 11:09.43.836] [LOG]   Initializing new module helper ...
0|mm     | [15.04.2023 11:09.43.839] [LOG]   Module helper loaded: updatenotification
0|mm     | [15.04.2023 11:09.43.841] [LOG]   No helper found for module: clock.
0|mm     | [15.04.2023 11:09.43.850] [LOG]   Initializing new module helper ...
0|mm     | [15.04.2023 11:09.43.852] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.23.0
0|mm     | [15.04.2023 11:09.43.856] [LOG]   Version is ok!
0|mm     | [15.04.2023 11:09.43.859] [LOG]   Module helper loaded: MMM-Fuel
0|mm     | [15.04.2023 11:09.44.347] [LOG]   Initializing new module helper ...
0|mm     | [15.04.2023 11:09.44.349] [LOG]   Module helper loaded: calendar
0|mm     | [15.04.2023 11:09.44.350] [LOG]   No helper found for module: compliments.
0|mm     | [15.04.2023 11:09.44.353] [LOG]   No helper found for module: weather.
0|mm     | [15.04.2023 11:09.44.358] [LOG]   Initializing new module helper ...
0|mm     | [15.04.2023 11:09.44.359] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
0|mm     | [15.04.2023 11:09.45.297] [LOG]   Initializing new module helper ...
0|mm     | [15.04.2023 11:09.45.302] [LOG]   Module helper loaded: MMM-Jast
0|mm     | [15.04.2023 11:09.45.304] [LOG]   All module helpers loaded.
0|mm     | [15.04.2023 11:09.45.332] [LOG]   Starting server on port 8080 ...
0|mm     | [15.04.2023 11:09.45.871] [LOG]   Server started ...
0|mm     | [15.04.2023 11:09.45.876] [LOG]   Connecting socket for: updatenotification
0|mm     | [15.04.2023 11:09.45.878] [LOG]   Starting module helper: updatenotification
0|mm     | [15.04.2023 11:09.45.879] [LOG]   Connecting socket for: MMM-Fuel
0|mm     | [15.04.2023 11:09.45.880] [LOG]   Starting module helper: MMM-Fuel
0|mm     | [15.04.2023 11:09.45.882] [LOG]   Connecting socket for: calendar
0|mm     | [15.04.2023 11:09.45.884] [LOG]   Starting node helper for: calendar
0|mm     | [15.04.2023 11:09.45.885] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
0|mm     | [15.04.2023 11:09.45.887] [LOG]   MMM-DWD-WarnWeather helper started...
0|mm     | [15.04.2023 11:09.45.890] [LOG]   Connecting socket for: MMM-Jast
0|mm     | [15.04.2023 11:09.45.892] [LOG]   MMM-Jast helper method started...
0|mm     | [15.04.2023 11:09.45.894] [LOG]   Sockets connected &amp; modules started ...
0|mm     | [15.04.2023 11:09.46.027] [LOG]   Launching application.
0|mm     | [15654:0415/110946.854883:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
0|mm     | [15689:0415/110947.076938:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
0|mm     | [15662:0415/110947.157042:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
0|mm     | [15.04.2023 11:09.50.379] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/ZEICHENFOLGEgroup.calendar.google.com/private-ZEICHENFOLGE/basic.ics - Interval: 300000
0|mm     | [15.04.2023 11:09.53.215] [WARN]  MMM-Fuel: Filtered stationIds list is empty
0|mm     | [15.04.2023 11:09.55.354] [INFO]  Calendar-Fetcher: Broadcasting 134 events.
0|mm     | [15.04.2023 11:09.55.570] [INFO]  Checking git for module: MMM-Fuel
0|mm     | [15.04.2023 11:09.55.666] [INFO]  Checking git for module: MMM-DWD-WarnWeather
0|mm     | [15.04.2023 11:09.55.727] [INFO]  Checking git for module: MMM-Jast
0|mm     | [15.04.2023 11:09.55.782] [INFO]  Checking git for module: MagicMirror
PM2      | pm2 has been killed by signal, dumping process list before exit...
PM2      | Deleting process 0
PM2      | Stopping app:mm id:0
0|mm     | [15.04.2023 11:11.04.768] [LOG]   Shutting down server...
0|mm     | [15.04.2023 11:11.04.772] [LOG]   Stopping module helper: updatenotification
0|mm     | [15.04.2023 11:11.04.773] [LOG]   Stopping module helper: MMM-Fuel
0|mm     | [15.04.2023 11:11.04.774] [LOG]   Stopping module helper: calendar
0|mm     | [15.04.2023 11:11.04.776] [LOG]   Stopping module helper: MMM-DWD-WarnWeather
0|mm     | [15.04.2023 11:11.04.777] [LOG]   Stopping module helper: MMM-Jast
0|mm     | [15.04.2023 11:11.04.779] [LOG]   Node_helpers stopped ...
PM2      | App [mm:0] exited with code [0] via signal [SIGTERM]
0|mm     | [15620:0415/111104.849464:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to zygote
0|mm     | [15620:0415/111104.871342:ERROR:network_service_instance_impl.cc(521)] Network service crashed, restarting service.
0|mm     | [15620:0415/111104.886158:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to zygote
0|mm     | [15620:0415/111104.897434:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
0|mm     | [15620:0415/111104.905143:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
0|mm     | [15620:0415/111104.910341:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
0|mm     | [15620:0415/111104.917887:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
0|mm     | [15620:0415/111104.922896:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
PM2      | pid=15596 msg=process killed
PM2      | Exited peacefully
<p dir="auto">Hat jemand zufällig eine Idee was los ist??</p>
]]></description><link>https://forum.magicmirror.builders/topic/17733/pm2-beendet-und-startet-mm-andauernd-nach-update</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 08:02:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17733.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Apr 2023 09:30:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PM2 beendet und startet MM andauernd nach Update on Mon, 17 Apr 2023 10:42:34 GMT]]></title><description><![CDATA[<p dir="auto">Ich hab jetzt den Raspberry komplett neu aufgesetzt und MM neu installiert - jetzt geht es wieder</p>
]]></description><link>https://forum.magicmirror.builders/post/108914</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108914</guid><dc:creator><![CDATA[35110]]></dc:creator><pubDate>Mon, 17 Apr 2023 10:42:34 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 beendet und startet MM andauernd nach Update on Sun, 16 Apr 2023 11:30:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/35110" aria-label="Profile: 35110">@<bdi>35110</bdi></a> can u email me the ~/MagicMirror/installers/upgrade.log</p>
<p dir="auto">same userid at gmail</p>
]]></description><link>https://forum.magicmirror.builders/post/108880</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108880</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 16 Apr 2023 11:30:58 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 beendet und startet MM andauernd nach Update on Sun, 16 Apr 2023 06:42:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">NODE v16.19.0<br />
NPM v 8.19.3</p>
<p dir="auto">Update via Script</p>
<pre><code>bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
]]></description><link>https://forum.magicmirror.builders/post/108874</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108874</guid><dc:creator><![CDATA[35110]]></dc:creator><pubDate>Sun, 16 Apr 2023 06:42:26 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 beendet und startet MM andauernd nach Update on Sat, 15 Apr 2023 12:49:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/35110" aria-label="Profile: 35110">@<bdi>35110</bdi></a> how did u update mm?</p>
<p dir="auto">can u provide output of</p>
<p dir="auto">node -v<br />
npm -v</p>
]]></description><link>https://forum.magicmirror.builders/post/108863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108863</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Apr 2023 12:49:42 GMT</pubDate></item></channel></rss>
