<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-OpenWeatherMapForecast loading issue?]]></title><description><![CDATA[<p dir="auto">I screwed up loading the last MM update and lost all of my content, so I had to start over again, I used to use MMM-OpenWeatherForecast, when I reinstalled it I got just a “loading” display on my mirror? So I thought id try MMM-OpenWeatherMapForecast, but I’m still getting the same thing, just the “loading” on the module, I’ve tried a few other weather modules and they seem to work fine, but I would really like to use one of these? I have tried changing the node helper api call to 3.0, but that doesn’t work either, well not for me anyway? Has anyone had this issue and got it resolved, I did a search but the only thing I can find is changing the api info in node helper? Any direction would be much appreciated!</p>
]]></description><link>https://forum.magicmirror.builders/topic/17735/mmm-openweathermapforecast-loading-issue</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 06:09:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17735.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Apr 2023 13:39:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Mon, 01 May 2023 01:13:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/videogame95" aria-label="Profile: videogame95">@<bdi>videogame95</bdi></a> watch out, there are limited number of requests per day.  once you hit it, nothing…</p>
]]></description><link>https://forum.magicmirror.builders/post/109118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109118</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 May 2023 01:13:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Mon, 01 May 2023 00:21:32 GMT]]></title><description><![CDATA[<p dir="auto">Once your git things working get mini adapter use copy sd card on the pi it take a while but things go wrong you can start agin with your copy .<br />
Yes it happen to me .</p>
]]></description><link>https://forum.magicmirror.builders/post/109117</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109117</guid><dc:creator><![CDATA[videogame95]]></dc:creator><pubDate>Mon, 01 May 2023 00:21:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Mon, 01 May 2023 00:18:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a><br />
Hi yes mine not loading try reloading a new app key from open weather maps wait 2 hour before starting  it up . create a new api you can delete you old one<br />
Add I’d try Romford 2639192<br />
Test<br />
Get eventing read go  out shopping or if your like I can wait ha ha</p>
<p dir="auto">Not sure if it’s going to work I am going to try this on my one tomorrow.<br />
Good luck<br />
It may be broke .</p>
]]></description><link>https://forum.magicmirror.builders/post/109116</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109116</guid><dc:creator><![CDATA[videogame95]]></dc:creator><pubDate>Mon, 01 May 2023 00:18:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Mon, 01 May 2023 00:11:41 GMT]]></title><description><![CDATA[<p dir="auto">I just read it take 2 hours for your app to be activated so put a new one in . You can delete you old one in weather maps  creat a new one like say<br />
Romford  it should then appear and say activated<br />
Add to your file again wait .<br />
I am having a simpler  problem as mine isn’t loading<br />
So going try again tomorrow.</p>
<p dir="auto">Best of luck lots of  people are having  similar issues.<br />
If in the UK make shore its not us . Its easy make that mistake. ID 2639192  Romford  test this ID</p>
]]></description><link>https://forum.magicmirror.builders/post/109115</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109115</guid><dc:creator><![CDATA[videogame95]]></dc:creator><pubDate>Mon, 01 May 2023 00:11:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Tue, 18 Apr 2023 13:36:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a> eh?</p>
<p dir="auto">just edit the file with nano and add that stuff to the end on new lines</p>
]]></description><link>https://forum.magicmirror.builders/post/108951</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108951</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Apr 2023 13:36:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Tue, 18 Apr 2023 13:35:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> the file is there, I just can seem to figure out what line to put it at, I have tried a couple spots but all it does is kill the module?</p>
]]></description><link>https://forum.magicmirror.builders/post/108950</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108950</guid><dc:creator><![CDATA[croc_dad72]]></dc:creator><pubDate>Tue, 18 Apr 2023 13:35:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Tue, 18 Apr 2023 13:33:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a> it goes in css/custom.css</p>
<p dir="auto">if the file doesn’t exist, create it</p>
]]></description><link>https://forum.magicmirror.builders/post/108949</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108949</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Apr 2023 13:33:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Tue, 18 Apr 2023 13:32:28 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> can you help me with one last thing? I can’t seem to figure out where this code gets put into the .css for adjusting the width of the module? Any guidance would be much appreciated!</p>
<pre><code>.MMM-OpenWeatherMapForecast .module-content {
  width: 500px; /* adjust this to taste */
]]></description><link>https://forum.magicmirror.builders/post/108948</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108948</guid><dc:creator><![CDATA[croc_dad72]]></dc:creator><pubDate>Tue, 18 Apr 2023 13:32:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Mon, 17 Apr 2023 15:47:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Well don’t I feel stupid, I had forgot I had two different api’s should have tried that first, thanks again for helping a noob!</p>
]]></description><link>https://forum.magicmirror.builders/post/108920</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108920</guid><dc:creator><![CDATA[croc_dad72]]></dc:creator><pubDate>Mon, 17 Apr 2023 15:47:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Mon, 17 Apr 2023 14:28:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a> said in <a href="/post/108918">MMM-OpenWeatherMapForecast loading issue?</a>:</p>
<p dir="auto">unexpected response code ** 401</p>
<p dir="auto">401 is access denied…</p>
<p dir="auto">so, wrong apikey for this</p>
]]></description><link>https://forum.magicmirror.builders/post/108919</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108919</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Apr 2023 14:28:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Mon, 17 Apr 2023 14:26:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ok thanks, now that I installed it right, im still just getting the loading on the module? Here is the start up code:backhand_index_pointing_down_light_skin_tone:<br />
Thanks for your help, time,  and patients!</p>
<pre><code>macserver@EDITHs-MacBook-Pro magicmirror % npm run server
&gt; magicmirror@2.23.0 server
&gt; node ./serveronly
[17.04.2023 09:18.24.710] [LOG]   Starting MagicMirror: v2.23.0
[17.04.2023 09:18.24.714] [LOG]   Loading config ...
[17.04.2023 09:18.24.716] [DEBUG] config template file not exists, no envsubst
[17.04.2023 09:18.24.718] [LOG]   Loading module helpers ...
[17.04.2023 09:18.24.719] [LOG]   No helper found for module: alert.
[17.04.2023 09:18.24.724] [LOG]   Initializing new module helper ...
[17.04.2023 09:18.24.725] [LOG]   Module helper loaded: updatenotification
[17.04.2023 09:18.24.725] [LOG]   No helper found for module: clock.
[17.04.2023 09:18.24.936] [LOG]   Initializing new module helper ...
[17.04.2023 09:18.24.937] [LOG]   Module helper loaded: MMM-quote-of-the-day
[17.04.2023 09:18.25.043] [LOG]   Initializing new module helper ...
[17.04.2023 09:18.25.044] [LOG]   Module helper loaded: MMM-MyCalendar
[17.04.2023 09:18.25.162] [LOG]   Initializing new module helper ...
[17.04.2023 09:18.25.162] [LOG]   Module helper loaded: MMM-GooglePhotos
[17.04.2023 09:18.25.163] [WARN]  No /Users/macserver/MagicMirror/js/../modules//.js found for module: .
[17.04.2023 09:18.25.163] [LOG]   No helper found for module: .
[17.04.2023 09:18.25.237] [LOG]   Initializing new module helper ...
[17.04.2023 09:18.25.238] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
[17.04.2023 09:18.25.238] [LOG]   No helper found for module: MMM-WiFiPassword.
[17.04.2023 09:18.25.247] [LOG]   Initializing new module helper ...
[17.04.2023 09:18.25.248] [LOG]   Module helper loaded: MMM-Memo
[17.04.2023 09:18.25.257] [LOG]   Initializing new module helper ...
[17.04.2023 09:18.25.257] [LOG]   Module helper loaded: newsfeed
[17.04.2023 09:18.25.257] [LOG]   All module helpers loaded.
[17.04.2023 09:18.25.265] [LOG]   Starting server on port 8080 ...
[17.04.2023 09:18.25.267] [WARN]  You're using a full whitelist configuration to allow for all IPs
[17.04.2023 09:18.25.272] [LOG]   Server started ...
[17.04.2023 09:18.25.273] [LOG]   Connecting socket for: updatenotification
[17.04.2023 09:18.25.273] [LOG]   Starting module helper: updatenotification
[17.04.2023 09:18.25.277] [LOG]   Connecting socket for: MMM-quote-of-the-day
[17.04.2023 09:18.25.277] [LOG]   MMM-quote-of-the-day helper started
[17.04.2023 09:18.25.279] [LOG]   Connecting socket for: MMM-MyCalendar
[17.04.2023 09:18.25.279] [LOG]   Starting node helper for: MMM-MyCalendar
[17.04.2023 09:18.25.279] [LOG]   Connecting socket for: MMM-GooglePhotos
[17.04.2023 09:18.25.279] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
[17.04.2023 09:18.25.279] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
[17.04.2023 09:18.25.280] [LOG]   Connecting socket for: MMM-Memo
[17.04.2023 09:18.25.280] [LOG]   Connecting socket for: newsfeed
[17.04.2023 09:18.25.280] [LOG]   Starting node helper for: newsfeed
[17.04.2023 09:18.25.280] [LOG]   Sockets connected &amp; modules started ...
[17.04.2023 09:18.25.281] [LOG]
Ready to go! Please point your browser to: http://0.0.0.0:8080
[17.04.2023 09:18.46.468] [LOG]   MMM-quote-of-the-day received a socket notification: INIT_HELPER - Payload: [object Object]
[17.04.2023 09:18.46.469] [LOG]   MMM-quote-of-the-day received a socket notification: GET_QUOTE - Payload: [object Object]
[17.04.2023 09:18.46.486] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/1madff72%40gmail.com/private-43dd7100efe15087f221915e4f97e343/basic.ics - Interval: 300000
[17.04.2023 09:18.46.596] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/cn5vlg6g97kjq9ksrcjp8925mc%40group.calendar.google.com/private-778f10708543b8098fb7e8d1110b1a59/basic.ics - Interval: 300000
[17.04.2023 09:18.46.599] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/kelland07%40gmail.com/private-46e66ed170d59dba9545ad0b253efa4d/basic.ics - Interval: 300000
[17.04.2023 09:18.46.601] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/ffshnike%40gmail.com/private-ac06b64ac6c1f2d26b142f93eb60205b/basic.ics - Interval: 300000
[17.04.2023 09:18.46.603] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/rfci1sthlecnfqoj0ecfd69csg%40group.calendar.google.com/private-385b5ae26bc6e915d62515d10228616b/basic.ics - Interval: 300000
[17.04.2023 09:18.46.604] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
[17.04.2023 09:18.46.611] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
[17.04.2023 09:18.46.617] [INFO]  Checking git for module: MMM-quote-of-the-day
[17.04.2023 09:18.46.887] [LOG]   {
  status: 200,
  statusText: 'OK',
  headers: {
    date: 'Mon, 17 Apr 2023 14:18:46 GMT',
    'content-type': 'application/json',
    'transfer-encoding': 'chunked',
    connection: 'close',
    vary: 'Accept-Encoding',
    'cf-cache-status': 'DYNAMIC',
    'report-to': '{"endpoints":[{"url":"https:\\/\\/a.nel.cloudflare.com\\/report\\/v3?s=i0x2oG767LUHoIXj0%2FO1UAkLAmijYeRqAKnlW7sUCjzMQ7b0%2BbhVKNlj5hGJUu6yYUOclI28Mmr3DB1OpO0Ut2Ti91vOl0icEMQibHyfMmJyA6U%2FBquphR3igj8vsBTf04oGQ8k%3D"}],"group":"cf-nel","max_age":604800}',
    nel: '{"success_fraction":0,"report_to":"cf-nel","max_age":604800}',
    'x-content-type-options': 'nosniff',
    server: 'cloudflare',
    'cf-ray': '7b954c9a197313ce-ORD',
    'alt-svc': 'h3=":443"; ma=86400, h3-29=":443"; ma=86400'
    transitional: {
      silentJSONParsing: true,
      forcedJSONParsing: true,
      clarifyTimeoutError: false
    adapter: [Function: httpAdapter],
    transformRequest: [ [Function: transformRequest] ],
    transformResponse: [ [Function: transformResponse] ],
    timeout: 0,
    xsrfCookieName: 'XSRF-TOKEN',
    xsrfHeaderName: 'X-XSRF-TOKEN',
    maxContentLength: -1,
    maxBodyLength: -1,
    env: { FormData: [Function] },
    validateStatus: [Function: validateStatus],
    headers: {
      Accept: 'application/json, text/plain, */*',
      'User-Agent': 'axios/0.27.2'
    params: { lang: 'en' },
    method: 'get',
    url: 'http://api.forismatic.com/api/1.0/?method=getQuote&amp;format=json',
    data: undefined
  request: &lt;ref *1&gt; ClientRequest {
    _events: [Object: null prototype] {
      abort: [Function (anonymous)],
      aborted: [Function (anonymous)],
      connect: [Function (anonymous)],
      error: [Function (anonymous)],
      socket: [Function (anonymous)],
      timeout: [Function (anonymous)],
      finish: [Function: requestOnFinish]
    _eventsCount: 7,
    _maxListeners: undefined,
    outputData: [],
    outputSize: 0,
    writable: true,
    destroyed: false,
    _last: true,
    chunkedEncoding: false,
    shouldKeepAlive: false,
    maxRequestsOnConnectionReached: false,
    _defaultKeepAlive: true,
    useChunkedEncodingByDefault: false,
    sendDate: false,
    _removedConnection: false,
    _removedContLen: false,
    _removedTE: false,
    strictContentLength: false,
    _contentLength: 0,
    _hasBody: true,
    _trailer: '',
    finished: true,
    _headerSent: true,
    _closed: false,
    socket: Socket {
      connecting: false,
      _hadError: false,
      _parent: null,
      _host: 'api.forismatic.com',
      _closeAfterHandlingError: false,
      _readableState: [ReadableState],
      _events: [Object: null prototype],
      _eventsCount: 7,
      _writableState: [WritableState],
      allowHalfOpen: false,
      _sockname: null,
      _pendingData: null,
      _pendingEncoding: '',
      server: null,
      _server: null,
      parser: null,
      _httpMessage: [Circular *1],
      [Symbol(async_id_symbol)]: 1279,
      [Symbol(kHandle)]: [TCP],
      [Symbol(lastWriteQueueSize)]: 0,
      [Symbol(timeout)]: null,
      [Symbol(kBuffer)]: null,
      [Symbol(kBufferCb)]: null,
      [Symbol(kBufferGen)]: null,
      [Symbol(kCapture)]: false,
      [Symbol(kSetNoDelay)]: true,
      [Symbol(kSetKeepAlive)]: true,
      [Symbol(kSetKeepAliveInitialDelay)]: 60,
      [Symbol(kBytesRead)]: 0,
      [Symbol(kBytesWritten)]: 0
    _header: 'GET /api/1.0/?method=getQuote&amp;format=json&amp;lang=en HTTP/1.1\r\n' +
      'Accept: application/json, text/plain, */*\r\n' +
      'User-Agent: axios/0.27.2\r\n' +
      'Host: api.forismatic.com\r\n' +
      'Connection: close\r\n' +
      '\r\n',
    _keepAliveTimeout: 0,
    _onPendingData: [Function: nop],
    agent: Agent {
      _eventsCount: 2,
      defaultPort: 80,
      protocol: 'http:',
      options: [Object: null prototype],
      requests: [Object: null prototype] {},
      sockets: [Object: null prototype],
      freeSockets: [Object: null prototype] {},
      keepAliveMsecs: 1000,
      keepAlive: false,
      maxSockets: Infinity,
      maxFreeSockets: 256,
      scheduling: 'lifo',
      maxTotalSockets: Infinity,
      totalSocketCount: 1,
    socketPath: undefined,
    method: 'GET',
    maxHeaderSize: undefined,
    insecureHTTPParser: undefined,
    joinDuplicateHeaders: undefined,
    path: '/api/1.0/?method=getQuote&amp;format=json&amp;lang=en',
    _ended: true,
    res: IncomingMessage {
      _eventsCount: 4,
      socket: [Socket],
      httpVersionMajor: 1,
      httpVersionMinor: 1,
      httpVersion: '1.1',
      complete: true,
      rawHeaders: [Array],
      rawTrailers: [],
      aborted: false,
      upgrade: false,
      url: '',
      method: null,
      statusCode: 200,
      statusMessage: 'OK',
      client: [Socket],
      _consuming: false,
      _dumped: false,
      req: [Circular *1],
      responseUrl: 'http://api.forismatic.com/api/1.0/?method=getQuote&amp;format=json&amp;lang=en',
      redirects: [],
      [Symbol(kHeaders)]: [Object],
      [Symbol(kHeadersCount)]: 24,
      [Symbol(kTrailers)]: null,
      [Symbol(kTrailersCount)]: 0
    aborted: false,
    timeoutCb: null,
    upgradeOrConnect: false,
    parser: null,
    maxHeadersCount: null,
    reusedSocket: false,
    protocol: 'http:',
    _redirectable: Writable {
      _eventsCount: 3,
      _options: [Object],
      _ended: true,
      _ending: true,
      _redirectCount: 0,
      _redirects: [],
      _requestBodyLength: 0,
      _requestBodyBuffers: [],
      _onNativeResponse: [Function (anonymous)],
      _currentRequest: [Circular *1],
      _currentUrl: 'http://api.forismatic.com/api/1.0/?method=getQuote&amp;format=json&amp;lang=en',
    [Symbol(kBytesWritten)]: 0,
    [Symbol(kEndCalled)]: true,
    [Symbol(kNeedDrain)]: false,
    [Symbol(corked)]: 0,
    [Symbol(kOutHeaders)]: [Object: null prototype] {
      accept: [Array],
      'user-agent': [Array],
      host: [Array]
    [Symbol(errored)]: null,
    [Symbol(kUniqueHeaders)]: null
  data: {
    quoteText: 'We must learn our limits. We are all something, but none of us are everything. ',
    quoteAuthor: 'Blaise Pascal',
    senderName: '',
    senderLink: '',
    quoteLink: 'http://forismatic.com/en/22bd88b816/'
[17.04.2023 09:18.46.929] [INFO]  Checking git for module: MMM-MyCalendar
[17.04.2023 09:18.46.939] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
[17.04.2023 09:18.46.999] [INFO]  Checking git for module: MMM-GooglePhotos
[17.04.2023 09:18.47.055] [ERROR] [MMM-OpenWeatherMapForecast] 17-Apr-23 09:18 ** unexpected response code ** 401
[17.04.2023 09:18.47.102] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
[17.04.2023 09:18.47.110] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
[17.04.2023 09:18.47.179] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
[17.04.2023 09:18.47.216] [INFO]  Checking git for module: MMM-WiFiPassword
[17.04.2023 09:18.47.543] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
[17.04.2023 09:18.47.598] [INFO]  Checking git for module: MMM-Memo
[17.04.2023 09:18.47.831] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
[17.04.2023 09:18.47.857] [INFO]  Checking git for module: MagicMirror
[17.04.2023 09:18.49.035] [INFO]  Calendar-Fetcher: Broadcasting 2 events.
[17.04.2023 09:18.50.022] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
]]></description><link>https://forum.magicmirror.builders/post/108918</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108918</guid><dc:creator><![CDATA[croc_dad72]]></dc:creator><pubDate>Mon, 17 Apr 2023 14:26:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Sun, 16 Apr 2023 13:29:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a> you did not<br />
npm install<br />
in the module folder</p>
]]></description><link>https://forum.magicmirror.builders/post/108897</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108897</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 16 Apr 2023 13:29:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Sun, 16 Apr 2023 13:24:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/108870">MMM-OpenWeatherMapForecast loading issue?</a>:</p>
<p dir="auto">cd MMM-OpenWeatheMapForecast</p>
<p dir="auto">This is what I got after installing with the directions above.</p>
[16.04.2023 08:19.12.823] [LOG]   Starting MagicMirror: v2.23.0
[16.04.2023 08:19.12.827] [LOG]   Loading config ...
[16.04.2023 08:19.12.829] [DEBUG] config template file not exists, no envsubst
[16.04.2023 08:19.12.832] [LOG]   Loading module helpers ...
[16.04.2023 08:19.12.832] [LOG]   No helper found for module: alert.
[16.04.2023 08:19.12.837] [LOG]   Initializing new module helper ...
[16.04.2023 08:19.12.838] [LOG]   Module helper loaded: updatenotification
[16.04.2023 08:19.12.838] [LOG]   No helper found for module: clock.
[16.04.2023 08:19.13.037] [LOG]   Initializing new module helper ...
[16.04.2023 08:19.13.038] [LOG]   Module helper loaded: MMM-quote-of-the-day
[16.04.2023 08:19.13.140] [LOG]   Initializing new module helper ...
[16.04.2023 08:19.13.140] [LOG]   Module helper loaded: MMM-MyCalendar
[16.04.2023 08:19.13.254] [LOG]   Initializing new module helper ...
[16.04.2023 08:19.13.254] [LOG]   Module helper loaded: MMM-GooglePhotos
[16.04.2023 08:19.13.255] [WARN]  No /Users/macserver/MagicMirror/js/../modules//.js found for module: .
[16.04.2023 08:19.13.255] [LOG]   No helper found for module: .
[16.04.2023 08:19.13.257] [ERROR] Whoops! There was an uncaught exception...
[16.04.2023 08:19.13.260] [ERROR] Error: Cannot find module 'needle'
Require stack:
- /Users/macserver/MagicMirror/modules/MMM-OpenWeatherMapForecast/node_helper.js
- /Users/macserver/MagicMirror/js/app.js
- /Users/macserver/MagicMirror/serveronly/index.js
    at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
    at Module._resolveFilename (/Users/macserver/MagicMirror/node_modules/module-alias/index.js:49:29)
    at Module._load (node:internal/modules/cjs/loader:920:27)
    at Module.require (node:internal/modules/cjs/loader:1141:19)
    at require (node:internal/modules/cjs/helpers:110:18)
    at Object.&lt;anonymous&gt; (/Users/macserver/MagicMirror/modules/MMM-OpenWeatherMapForecast/node_helper.js:23:14)
    at Module._compile (node:internal/modules/cjs/loader:1254:14)
    at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
    at Module.load (node:internal/modules/cjs/loader:1117:32)
    at Module._load (node:internal/modules/cjs/loader:958:12)
    at loadModule (/Users/macserver/MagicMirror/js/app.js:184:19)
    at loadNextModule (/Users/macserver/MagicMirror/js/app.js:220:6)
    at loadNextModule (/Users/macserver/MagicMirror/js/app.js:222:6)
    at loadNextModule (/Users/macserver/MagicMirror/js/app.js:222:6) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/Users/macserver/MagicMirror/modules/MMM-OpenWeatherMapForecast/node_helper.js',
    '/Users/macserver/MagicMirror/js/app.js',
    '/Users/macserver/MagicMirror/serveronly/index.js'
[16.04.2023 08:19.13.261] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[16.04.2023 08:19.13.261] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
]]></description><link>https://forum.magicmirror.builders/post/108896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108896</guid><dc:creator><![CDATA[croc_dad72]]></dc:creator><pubDate>Sun, 16 Apr 2023 13:24:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Sat, 15 Apr 2023 18:43:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a> ok, do this</p>
<pre><code>ctrl-m to minimize MM if running
open a terminal window on you MM system
ctrl-alt-t
cd ~/Magicmirror/modules
mv MMM-OpenWeatherMapForecast  old OPWFC
git clone https://github.com/sdetweil/MMM-OpenWeatherMapForecast
npm install
cd ../..
<p dir="auto">if mm is running recycle it now<br />
if MM is NOT running do</p>
<pre><code>npm start
<p dir="auto">after it comes up, ctrl-m to minimize and look at the messages output</p>
]]></description><link>https://forum.magicmirror.builders/post/108870</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108870</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Apr 2023 18:43:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Sat, 15 Apr 2023 17:25:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> more of noob than I want to admit, I guess I don’t really know what all that means really! I guess id need more direction!</p>
]]></description><link>https://forum.magicmirror.builders/post/108868</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108868</guid><dc:creator><![CDATA[croc_dad72]]></dc:creator><pubDate>Sat, 15 Apr 2023 17:25:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Sat, 15 Apr 2023 14:27:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a> mv in the modules folder</p>
<p dir="auto">that message is from the old module</p>
]]></description><link>https://forum.magicmirror.builders/post/108867</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108867</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Apr 2023 14:27:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Sat, 15 Apr 2023 14:10:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/108865">MMM-OpenWeatherMapForecast loading issue?</a>:</p>
<p dir="auto">mv --help</p>
<p dir="auto">Thank you for the help, I installed your fork, and this is all I get at start up:</p>
<p dir="auto">“[15.04.2023 09:04.11.750] [LOG]   [MMM-OpenWeatherMapForecast] 15-Apr-23 09:04 ** ERROR ** null”?</p>
<p dir="auto">Im not sure where/when to run the command “mv --help”. Sorry im  more of noob yet, but learning!</p>
]]></description><link>https://forum.magicmirror.builders/post/108866</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108866</guid><dc:creator><![CDATA[croc_dad72]]></dc:creator><pubDate>Sat, 15 Apr 2023 14:10:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenWeatherMapForecast loading issue? on Sat, 15 Apr 2023 13:53:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a> this module hasn’t been  updated in quite a while</p>
<p dir="auto">it doesn’t report some errors</p>
<p dir="auto">can u try my fork?</p>
<p dir="auto"><a href="https://github.com/sdetweil/MMM-OpenWeatherMapForecast" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-OpenWeatherMapForecast</a></p>
<p dir="auto">rename your existing MMM-OpenWeatherMapForecast  module folder to some other name</p>
<p dir="auto">see the mv command (mv --help)</p>
<p dir="auto">then try again…<br />
it will report errors in the output where u start mm (npm start )</p>
]]></description><link>https://forum.magicmirror.builders/post/108865</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108865</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Apr 2023 13:53:35 GMT</pubDate></item></channel></rss>
