<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM on Windows - Updated now get black screen]]></title><description><![CDATA[<p dir="auto">I was running an old version of Magic Mirror on a Windows 10 build and I decided to update my version.<br />
After updating, I got an error because my package.json still referenced display so I changed it to:</p>
<pre><code>"main": "js/electron.js",
	"scripts": {
		"start": ./node_modules/.bin/electron js/electron.js",
		"start:dev": ./node_modules/.bin/electron js/electron.js dev",
<p dir="auto">When I run npm start, I get this:</p>
<pre><code>PS C:\Users\CompName\MagicMirror&gt; npm start
npm ERR! code EJSONPARSE
npm ERR! path C:\Users\CompName\MagicMirror/package.json
npm ERR! JSON.parse Unexpected token "." (0x2E) in JSON at position 172 while parsing near "...pts\": {\r\n\t\t\"start\": ./node_modules/.bin/..."
npm ERR! JSON.parse Failed to parse JSON data.
npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
npm ERR!     C:\Users\CompName\AppData\Local\npm-cache\_logs\2023-04-17T12_59_59_873Z-debug-0.log
<p dir="auto">Any help is greatly appreciated!</p>
]]></description><link>https://forum.magicmirror.builders/topic/17738/mm-on-windows-updated-now-get-black-screen</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 12:42:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17738.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Apr 2023 13:01:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM on Windows - Updated now get black screen on Mon, 17 Apr 2023 18:25:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/beachjosh77" aria-label="Profile: beachjosh77">@<bdi>beachjosh77</bdi></a> yes, you STILL have to follow the special windows instructions</p>
<p dir="auto">package.json is updated and replaced every release…</p>
<p dir="auto"><a href="https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems</a></p>
]]></description><link>https://forum.magicmirror.builders/post/108927</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108927</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Apr 2023 18:25:11 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Windows - Updated now get black screen on Mon, 17 Apr 2023 19:40:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> That worked, thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/108936</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108936</guid><dc:creator><![CDATA[beachjosh77]]></dc:creator><pubDate>Mon, 17 Apr 2023 19:40:56 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Windows - Updated now get black screen on Mon, 17 Apr 2023 18:26:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/beachjosh77" aria-label="Profile: beachjosh77">@<bdi>beachjosh77</bdi></a> said in <a href="/post/108926">MM on Windows - Updated now get black screen</a>:</p>
<p dir="auto">EJSONPARSE</p>
<p dir="auto">maybe you edited, but you messed it up</p>
]]></description><link>https://forum.magicmirror.builders/post/108929</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108929</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Apr 2023 18:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Windows - Updated now get black screen on Mon, 17 Apr 2023 18:25:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I forgot to mention, I also ran npm install in fonts and vendors and changed package.json to remove the display again</p>
]]></description><link>https://forum.magicmirror.builders/post/108928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108928</guid><dc:creator><![CDATA[beachjosh77]]></dc:creator><pubDate>Mon, 17 Apr 2023 18:25:37 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Windows - Updated now get black screen on Mon, 17 Apr 2023 18:25:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/beachjosh77" aria-label="Profile: beachjosh77">@<bdi>beachjosh77</bdi></a> yes, you STILL have to follow the special windows instructions</p>
]]></description><link>https://forum.magicmirror.builders/post/108927</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108927</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Apr 2023 18:25:11 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Windows - Updated now get black screen on Mon, 17 Apr 2023 18:23:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you for replying,<br />
I followed your instructions and ran:</p>
<pre><code>cd ~/MagicMirror
git checkout develop
git pull
npm install
<p dir="auto">but I still get</p>
<pre><code>npm ERR! code EJSONPARSE
npm ERR! JSON.parse Unexpected token "." (0x2E) in JSON at position 181 while parsing near "...ts\": {\r\n\t\t\"start\":  ./node_modules/.bin/..."
npm ERR!     C:\Users\CompName\AppData\Local\npm-cache\_logs\2023-04-17T18_21_14_409Z-debug-0.log
]]></description><link>https://forum.magicmirror.builders/post/108926</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108926</guid><dc:creator><![CDATA[beachjosh77]]></dc:creator><pubDate>Mon, 17 Apr 2023 18:23:22 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Windows - Updated now get black screen on Mon, 17 Apr 2023 14:13:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/beachjosh77" aria-label="Profile: beachjosh77">@<bdi>beachjosh77</bdi></a> also,  there is a bug, for windows , so you have to get the next version develop branch<br />
<a href="https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code">https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code</a></p>
]]></description><link>https://forum.magicmirror.builders/post/108917</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108917</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Apr 2023 14:13:45 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Windows - Updated now get black screen on Mon, 17 Apr 2023 14:03:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/beachjosh77" aria-label="Profile: beachjosh77">@<bdi>beachjosh77</bdi></a> yes?  you have to do all the install steps again</p>
<p dir="auto">manually npm install in fonts and vendors and change package.json.</p>
<p dir="auto">see the doc</p>
]]></description><link>https://forum.magicmirror.builders/post/108916</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108916</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Apr 2023 14:03:14 GMT</pubDate></item></channel></rss>
