<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[OpenWeatherMapForecast [WARN]]]></title><description><![CDATA[<p dir="auto">MM2.23.0, MarcLandis OpenWeatherMapForecast clone<br />
[WARN]  No /home/manager/MagicMirror/js/… /modules/MMM-OpenWeatherMapForecast.js found for module MMM-…</p>
<p dir="auto">I have the MMM-OpenWeather{…}   in …/MagicMirror/modules/default/<br />
What did I do to screw up the path? More importantly, what do I do to unscrew it?<br />
Of course, the module doesn’t load</p>
]]></description><link>https://forum.magicmirror.builders/topic/17743/openweathermapforecast-warn</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 23:42:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17743.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Apr 2023 01:23:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to OpenWeatherMapForecast [WARN] on Thu, 20 Apr 2023 02:25:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mildgeorge" aria-label="Profile: MildGeorge">@<bdi>MildGeorge</bdi></a> nothing EVER gets added to the default folder<br />
read the two topics in my signature below.<br />
I didn’t write them</p>
<p dir="auto">fix do</p>
<pre><code>cd ~/MagicMirror/modules/default
mv MMM-O* ..
<p dir="auto">then  restart MagicMirror</p>
<p dir="auto">but,  at least the new warning feature worked!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/108989</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108989</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Apr 2023 02:25:53 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast [WARN] on Tue, 02 May 2023 13:43:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mildgeorge" aria-label="Profile: MildGeorge">@<bdi>MildGeorge</bdi></a> I tried open weather maps it work two months ago it seems to be broken . I decided to just go on 3rd modules<br />
And get one that works . Look up weather try one out my only show the weather temperatures in Romford as still use the same I’d and added api code from open weather maps .</p>
<p dir="auto">Hope this helps</p>
]]></description><link>https://forum.magicmirror.builders/post/109143</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109143</guid><dc:creator><![CDATA[videogame95]]></dc:creator><pubDate>Tue, 02 May 2023 13:43:38 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast [WARN] on Thu, 20 Apr 2023 16:53:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mildgeorge" aria-label="Profile: MildGeorge">@<bdi>MildGeorge</bdi></a> AND never edit any of the files we ship or a module ships, as it will break updates…</p>
<p dir="auto">ALL config goes in config/config.js<br />
ALL css goes in css/custom.css</p>
]]></description><link>https://forum.magicmirror.builders/post/108996</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108996</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Apr 2023 16:53:16 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast [WARN] on Thu, 20 Apr 2023 16:50:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
for this noob, “nothing EVER gets added to the default folder” is invaluable. thanks.<br />
module now shows up - says “loading”, so I may be back looking for guidance.<br />
nothing worthwhile comes without effort…</p>
]]></description><link>https://forum.magicmirror.builders/post/108994</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108994</guid><dc:creator><![CDATA[MildGeorge]]></dc:creator><pubDate>Thu, 20 Apr 2023 16:50:00 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast [WARN] on Thu, 20 Apr 2023 02:25:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mildgeorge" aria-label="Profile: MildGeorge">@<bdi>MildGeorge</bdi></a> nothing EVER gets added to the default folder<br />
mv MMM-O* ..
]]></description><link>https://forum.magicmirror.builders/post/108989</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108989</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Apr 2023 02:25:53 GMT</pubDate></item></channel></rss>
