<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Installation don´t work]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I started a new installation with the guide, but when I came to the point : <code>npm run install-mm</code><br />
I get the Error message: command not found.</p>
<p dir="auto">What is wrong?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17761/new-installation-don-t-work</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 00:20:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17761.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 May 2023 07:23:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 19:57:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xeroxu" aria-label="Profile: xeroxu">@<bdi>xeroxu</bdi></a> ah, you didn’t copy the line exactly as it was on GitHub…</p>
<p dir="auto">when u have the mouse over the line to copy, a little box will appear to copy the text<br />
it should be</p>
<pre><code>bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
<p dir="auto">this uses curl to download the text. and then bash to execute it</p>
]]></description><link>https://forum.magicmirror.builders/post/109132</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109132</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 May 2023 19:57:29 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Tue, 02 May 2023 10:14:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xeroxu" aria-label="Profile: xeroxu">@<bdi>xeroxu</bdi></a> great! thanks for the follow up</p>
]]></description><link>https://forum.magicmirror.builders/post/109139</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109139</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 May 2023 10:14:18 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Tue, 02 May 2023 07:14:46 GMT]]></title><description><![CDATA[<p dir="auto">It finally works :thumbs_up:</p>
<p dir="auto">Thanks a lot</p>
]]></description><link>https://forum.magicmirror.builders/post/109137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109137</guid><dc:creator><![CDATA[xeroxu]]></dc:creator><pubDate>Tue, 02 May 2023 07:14:46 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 20:22:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">ah ok my fault, i‘ll try it and gonna report the results.</p>
<p dir="auto">Thx for y patience</p>
]]></description><link>https://forum.magicmirror.builders/post/109133</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109133</guid><dc:creator><![CDATA[xeroxu]]></dc:creator><pubDate>Mon, 01 May 2023 20:22:35 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 19:57:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xeroxu" aria-label="Profile: xeroxu">@<bdi>xeroxu</bdi></a> ah, you didn’t copy the line exactly as it was on GitHub…</p>
it should be</p>
]]></description><link>https://forum.magicmirror.builders/post/109132</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109132</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 May 2023 19:57:29 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 19:52:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/109125">New Installation don´t work</a>:</p>
<p dir="auto">/home/pi</p>
<p dir="auto">yes open a terminal and put in : curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh</a></p>
<p dir="auto">and after i press enter a lot of lines scroll down.</p>
<p dir="auto">but in the home/pi/ directory is no install.log</p>
]]></description><link>https://forum.magicmirror.builders/post/109131</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109131</guid><dc:creator><![CDATA[xeroxu]]></dc:creator><pubDate>Mon, 01 May 2023 19:52:43 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 17:04:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xeroxu" aria-label="Profile: xeroxu">@<bdi>xeroxu</bdi></a> said in <a href="/post/109122">New Installation don´t work</a>:</p>
<p dir="auto">but also it doesn´t work,</p>
<p dir="auto">you did open a terminal window and paste that command string in, right?</p>
]]></description><link>https://forum.magicmirror.builders/post/109126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109126</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 May 2023 17:04:09 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 17:02:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xeroxu" aria-label="Profile: xeroxu">@<bdi>xeroxu</bdi></a> this</p>
<pre><code> ~/install.log
<p dir="auto">means the file</p>
<pre><code>install.log
<p dir="auto">located in</p>
<pre><code>the users home folder
<p dir="auto">on my pi, logged on as use pi,  the home folder is</p>
<pre><code>/home/pi
<p dir="auto">you can easily do</p>
<pre><code>cd ~
<p dir="auto">to get there</p>
<p dir="auto">the log is created ONLY from the scripted install.</p>
]]></description><link>https://forum.magicmirror.builders/post/109125</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109125</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 May 2023 17:02:45 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 15:38:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
sorry, but I can´t find the install.logfile. either in the MagicMirror directory or or the main directory of  the pi.</p>
]]></description><link>https://forum.magicmirror.builders/post/109124</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109124</guid><dc:creator><![CDATA[xeroxu]]></dc:creator><pubDate>Mon, 01 May 2023 15:38:49 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 15:01:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xeroxu" aria-label="Profile: xeroxu">@<bdi>xeroxu</bdi></a> can u email me the ~/install.log file so I can see what the issue is<br />
my email is same userid at gmail</p>
]]></description><link>https://forum.magicmirror.builders/post/109123</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109123</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 May 2023 15:01:52 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 17:03:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">so, now I tried the automated script ant copied  :</p>
<pre><code>curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh
<p dir="auto">but also it doesn´t work, maybe my  sd card is  damaged?</p>
]]></description><link>https://forum.magicmirror.builders/post/109122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109122</guid><dc:creator><![CDATA[xeroxu]]></dc:creator><pubDate>Mon, 01 May 2023 17:03:05 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 13:22:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
yes did</p>
<p dir="auto">git clone &amp; cd MagicMirror</p>
<p dir="auto">I´ll gonna try your script</p>
<p dir="auto">Thx for your answer</p>
<p dir="auto">I gonna repeat whats gonna happen when i tried it</p>
]]></description><link>https://forum.magicmirror.builders/post/109121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109121</guid><dc:creator><![CDATA[xeroxu]]></dc:creator><pubDate>Mon, 01 May 2023 13:22:58 GMT</pubDate></item><item><title><![CDATA[Reply to New Installation don´t work on Mon, 01 May 2023 11:40:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xeroxu" aria-label="Profile: xeroxu">@<bdi>xeroxu</bdi></a> after you did the</p>
<pre><code>git clone
<p dir="auto">did you</p>
<pre><code>cd MagicMirror
<p dir="auto">my automated script install might help, see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/109120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109120</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 May 2023 11:40:26 GMT</pubDate></item></channel></rss>
