<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Weather module hourly template] Add another column for UV Index in hourly.njk with correct spacing]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/17779/weather-module-hourly-template-add-another-column-for-uv-index-in-hourly-njk-with-correct-spacing</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 23:25:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17779.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 07 May 2023 14:31:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Weather module hourly template] Add another column for UV Index in hourly.njk with correct spacing on Sun, 21 May 2023 17:03:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rene1695" aria-label="Profile: Rene1695">@<bdi>Rene1695</bdi></a> A misconfigured docker sadly overwrote my js files on reboot and i hadn’t had the time to recreate it until now.<br />
I cannot seem to upload my files here but you can look at my github repo where i synced all the changes. Watch out for a pull request to main, however that could take a while to end up in the releases.<br />
<a href="https://github.com/OWL4C/MagicMirror/tree/develop/modules/default/weather" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/OWL4C/MagicMirror/tree/develop/modules/default/weather</a><br />
Of note are: weather.css (as <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> detailed to add a border)<br />
providers/openmeteo.js (since it is free and more detailed than the other ones i use openmeteo and only know how to integrate it from them, maybe you can get the api reference for others, it should be similar to openmeteo.js though)<br />
hourly.njk (which adds the table entry, if the config.js has showUV_Index set to true)<br />
and obviously config.js<br />
As of yet hourly and current is implemented and i am trying to set up an max_UV for forecast.</p>
<p dir="auto">However there is one more bug: UV=0 does not get ignored like rain=0 but actually shows 0 0 0 0  etc. Not gamebreaking but still.</p>
]]></description><link>https://forum.magicmirror.builders/post/109430</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109430</guid><dc:creator><![CDATA[OWL]]></dc:creator><pubDate>Sun, 21 May 2023 17:03:47 GMT</pubDate></item><item><title><![CDATA[Reply to [Weather module hourly template] Add another column for UV Index in hourly.njk with correct spacing on Sat, 13 May 2023 20:34:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/owl" aria-label="Profile: OWL">@<bdi>OWL</bdi></a><br />
Hey, could you Provide your js files? I am also trying to add the uv index. So far, i was able to change the ndk and set a new variable to the constructor. But the variable is empty and I dont Understand How to add the data to the request and the „forecast“ Object.</p>
<p dir="auto">Many thanks For any help!</p>
]]></description><link>https://forum.magicmirror.builders/post/109353</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109353</guid><dc:creator><![CDATA[Rene1695]]></dc:creator><pubDate>Sat, 13 May 2023 20:34:10 GMT</pubDate></item><item><title><![CDATA[Reply to [Weather module hourly template] Add another column for UV Index in hourly.njk with correct spacing on Sun, 21 May 2023 17:35:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/owl" aria-label="Profile: OWL">@<bdi>OWL</bdi></a> all style is css</p>
<p dir="auto">using the developers console and elements tab you can see the current and try different spacings, borders etc. til u get what u want. then save that to custom.css</p>
]]></description><link>https://forum.magicmirror.builders/post/109294</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109294</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 21 May 2023 17:35:02 GMT</pubDate></item></channel></rss>
