<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Touchscreen monitor&#x2F;mirror NO IR FRAME]]></title><description><![CDATA[<p dir="auto">Can I use the touch screen monitor independently. I am not interested in using an IR frame.</p>
<p dir="auto">I am looking to implement a magic mirror in my home for calendar, schedules and IoT access. I have seen some good touchscreen answers but nothing without the use of IR frames in some capacity or another.</p>
<p dir="auto">Display: 24" capacitive touchscreen monitor. 60hz ref. rate.<br />
Mirror: Two way mirrors “smart mirror” tempered 5mm<br />
Pi: raspberry pi 3b+</p>
]]></description><link>https://forum.magicmirror.builders/topic/17792/touchscreen-monitor-mirror-no-ir-frame</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 04:24:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17792.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 May 2023 17:36:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Touchscreen monitor&#x2F;mirror NO IR FRAME on Fri, 19 May 2023 19:44:34 GMT]]></title><description><![CDATA[<p dir="auto">Use MMM-Touch.</p>
]]></description><link>https://forum.magicmirror.builders/post/109407</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109407</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Fri, 19 May 2023 19:44:34 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen monitor&#x2F;mirror NO IR FRAME on Fri, 19 May 2023 19:27:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdrmichael" aria-label="Profile: mrdrmichael">@<bdi>mrdrmichael</bdi></a> I understand, lots of development to go…</p>
<p dir="auto">MagicMirror is a browser based, single page application. a composite info panel.</p>
]]></description><link>https://forum.magicmirror.builders/post/109406</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109406</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 19 May 2023 19:27:07 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen monitor&#x2F;mirror NO IR FRAME on Fri, 19 May 2023 19:19:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you for the response. I ordered the 24" display I am going to run some tests before applying a mirror. Even though most applications are output based I am hoping to integrate some input such as the calendar and minor IoT accesses.</p>
<p dir="auto">I have not gone too in depth on the project but its like a running application that can be switched between like a process.</p>
]]></description><link>https://forum.magicmirror.builders/post/109405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109405</guid><dc:creator><![CDATA[mrdrmichael]]></dc:creator><pubDate>Fri, 19 May 2023 19:19:38 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen monitor&#x2F;mirror NO IR FRAME on Fri, 19 May 2023 17:50:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdrmichael" aria-label="Profile: mrdrmichael">@<bdi>mrdrmichael</bdi></a> I ‘think’ so as there is a small touch screen for pi.  I do not know how they interface for apps.  thru the browser for things like mm, …</p>
<p dir="auto">note that most modules are not input enabled, as a ‘mirror’ hangs on the wall and is usually output only.</p>
<p dir="auto">you won’t be able to put glass or film over the monitor.</p>
]]></description><link>https://forum.magicmirror.builders/post/109404</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109404</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 19 May 2023 17:50:08 GMT</pubDate></item></channel></rss>
