<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Install on Windows 10]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">I have  several MM on Raspberry (Zero W, Zero2W, 3 and 4) and was trying to install another one on a W10 tablet…</p>
<p dir="auto">But I can’t :D</p>
<p dir="auto">I followed this : <a href="https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10">https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10</a><br />
I did a npm install in MagicMirror/vendors and /fonts<br />
I changed the “start” : “DISPLAY="$etc…” in package.json with<br />
“start”: “node_modules/.bin/electron js…etc”<br />
But I still get  ‘node_modules’ is not recognized as an internal or external command’ when I npm start in the MagicMirror folder</p>
<p dir="auto">I’m a bit lost with Xindows ;)</p>
]]></description><link>https://forum.magicmirror.builders/topic/17795/install-on-windows-10</link><generator>RSS for Node</generator><lastBuildDate>Fri, 14 Aug 2026 18:26:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17795.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 May 2023 18:01:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Install on Windows 10 on Sat, 20 May 2023 19:42:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roadrunner451" aria-label="Profile: Roadrunner451">@<bdi>Roadrunner451</bdi></a></p>
<p dir="auto">see <a href="https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems</a></p>
<p dir="auto">There is another Problem with the current version, see <a href="https://github.com/MichMich/MagicMirror/issues/3083" target="_blank" rel="noopener noreferrer nofollow ugc">this issue</a> for more info and workaround.</p>
]]></description><link>https://forum.magicmirror.builders/post/109411</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109411</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 20 May 2023 19:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to Install on Windows 10 on Sun, 21 May 2023 10:50:11 GMT]]></title><description><![CDATA[<p dir="auto">Never mind, I found it :)</p>
<p dir="auto">And it works, thanks again !</p>
]]></description><link>https://forum.magicmirror.builders/post/109422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109422</guid><dc:creator><![CDATA[Roadrunner451]]></dc:creator><pubDate>Sun, 21 May 2023 10:50:11 GMT</pubDate></item><item><title><![CDATA[Reply to Install on Windows 10 on Sun, 21 May 2023 09:39:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
Thank you for your answer, I didn’t modify “start:dev”</p>
<p dir="auto">Now I’m stuck with the “another problem” you mentionned and I feel like a newbie as I can’t find electron.js to correct it …</p>
<p dir="auto">Thanks in advance !</p>
]]></description><link>https://forum.magicmirror.builders/post/109421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109421</guid><dc:creator><![CDATA[Roadrunner451]]></dc:creator><pubDate>Sun, 21 May 2023 09:39:25 GMT</pubDate></item><item><title><![CDATA[Reply to Install on Windows 10 on Sat, 20 May 2023 19:42:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roadrunner451" aria-label="Profile: Roadrunner451">@<bdi>Roadrunner451</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/109411</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109411</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 20 May 2023 19:42:39 GMT</pubDate></item></channel></rss>
