<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problems with AlexaControl]]></title><description><![CDATA[<p dir="auto">Dear Magic Mirror Pros,</p>
<p dir="auto">I’ve encountered a problem that’s currently preventing the progress of my major project. Let me provide some background:</p>
<p dir="auto">Here’s my setup:</p>
<p dir="auto">I’m using a Windows 10 operating system.<br />
MagicMirror² and Alexa are installed on this Windows machine.<br />
I’ve also set up Fauxmo, MMM-pages, and MMM-AlexaControl modules.<br />
So, everything is operating well in the basic configuration of MagicMirror² on my Windows 10 system. Additionally, I have Alexa configured on the same Windows 10 device, ensuring both MagicMirror and Alexa are always on the same WiFi network. I’ve configured the Calendar and have successfully used voice commands via Alexa to create new calendar entries.</p>
<p dir="auto">However, I’ve hit a roadblock: I’m unable to switch pages using voice commands or the Alexa app. I am able to control the FAUXMO simulated devices, namely “Seite 1”, “Seite 2”, etc. For example, when I turn them on, they switch to 1 and to 0 when I turn them off. Despite this, I’m really struggling with page-switching—I just can’t get it to work, and I can’t identify the problem.</p>
<p dir="auto">To add to the confusion, there seems to be varying opinions about whether the pages module is necessary at all: some suggest it’s possible to manage without Pages, while others disagree. Lastly, I should mention that I’m not a developer—I have some basic knowledge of server and cloud services, but that’s about it.</p>
<p dir="auto">So, I really need your help to solve this problem. I appreciate any suggestions or guidance you can provide.</p>
<p dir="auto">The MM Config:</p>
<pre><code>/* MagicMirror² Config Sample
 * By Michael Teeuw https://michaelteeuw.nl
 * MIT Licensed.
 * see https://docs.magicmirror.builders/configuration/introduction.html
 * and https://docs.magicmirror.builders/modules/configuration.html
 * You can use environment variables using a `config.js.template` file instead of `config.js`
 * which will be converted to `config.js` while starting. For more information
 * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
let config = {
	address: "localhost",	// Address to listen on, can be:
	port: 8080,
	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
	language: "en",
	locale: "en-US",
	timeFormat: 24,
	units: "metric",
			module: "alert",
        module: 'MMM-pages',
                modules:
                    [[ "clock", "updatenotification", "MMM-AlexaControl", "newsfeed"],
                     [ "compliments", "calendar", "MMM-AlexaControl"]],
                fixed: ["MMM-AlexaControl"],
        module: "MMM-AlexaControl",
        position: "middle_center",
            image: true,
            height: 265,
            width: 265,
            devices: [
                    port: 11100,
                    handler: 'PAGE_CHANGED',
                    payload: function(payload) {
                        return { 'page': 0 };
                    port: 11101,
                        return { 'page': 1 };
            startPort: 11000,
            refresh: true,
            restart: true,
            stop: true,
            reboot: false,
            shutdown: false,
            pm2ProcessName: "pm2",
            monitorToggle: true,
            vcgencmd: true,
            usb: false
.... and so on
<p dir="auto">The MMM-AlexaControl JS:</p>
<pre><code>
 * Magic Mirror
 * Module: MMM-AlexaControl
 * By JoChef2
 * MIT Licensed.
Module.register("MMM-AlexaControl",{
	defaults:{
    image: true,
    height: 265,
    width: 265,
    pages: 3,
devices: {
    "Seite 1": {
        port: 11100,
    "Seite 2": {
        port: 11101,
        notifications: [],  //  empty array for your notification devices
        commands: [],       // empty array for your command devices
        startPort: 11000,   //  the lowest used port
        refresh: true,      //  refresh your Mirror
        restart: true,      //  restart your Mirror with pm2
        stop: true,         //  stops your Mirror with pm2
        reboot: false,      //  reboot your pi
        shutdown: false,    //  shutdown your pi
        pm2ProcessName: "mm",  //  name of your pm2 process
        monitorToggle: true,   //  switch your monitor on and off
        vcgencmd: 'vcgencmd',  //  command you use for monitor toggle
        cecAddress: "0.0.0.0", //  Address for the cec-client
        usb: false          // toggle usb power of your pi
    getTranslations: function(){            // add more translations
        return {
            en: "translations/en.json",
            de: "translations/de.json"
    start: function(){
        Log.log('Starting module: ' + this.name);
        // send all translations to node_helper
        this.sendSocketNotification('TRANSLATIONS', {"monitor": this.translate("MONITOR"), "shutdown": this.translate("SHUTDOWN"), "reboot": this.translate("REBOOT"), "page": this.translate("PAGE"), "refresh": this.translate("REFRESH"), "restart": this.translate("RESTART"), "stop": this.translate("STOP"), "usb": this.translate("USB"), "deviceName":this.translate(this.config.deviceName)});
        this.sendSocketNotification('SET_DEVICE', this.config);  // send the config to node_helper
    getDom: function(){             // returns only an image or an empty div (necessary for MMM-Pages)
        if(this.config.image){
            let img = document.createElement("img");
            img.classList = "img";
            img.src = "MMM-AlexaControl/AlexaLogoGrey.png";
            img.height = this.config.height;
            img.width = this.config.width;
            return img;
        }else{
            return document.createElement("div");
        if(notification === "PAGE_CHANGED"){              //  change pages of MMM-Pages
            this.sendNotification("PAGE_CHANGED", payload);
        if(notification === "ACTION"){                    //  refresh the Mirror
            if(payload === "refresh"){
                window.location.reload(true);
        if(notification === "CUSTOM"){
            this.sendNotification(payload[0], payload[1]);  //  send any notification to any module
        if(notification =='MONITOR_ACTION'){
            Log.log('RECEIVE monitor NOTIFICATION='+payload)
            this.sendNotification(notification,payload)
<p dir="auto">Node Fauxmo index.js:</p>
<pre><code>'use strict';
const FauxMo = require('node-fauxmo');
let fauxMo = new FauxMo(
    devices: [
        port: 11000,
        handler: function(action) {
            console.log('Seite 1:', action);
        port: 11001,
            console.log('Seite 2:', action);
        port: 11002,
            console.log('Seite 3:', action);
<p dir="auto">And the MMM-Pages is basically untouched… so default Config entrys in there.</p>
<p dir="auto">Any hints what i am doing wrong?</p>
<p dir="auto">Best Regards</p>
<p dir="auto">The Noob :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/17797/problems-with-alexacontrol</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 13:04:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17797.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 May 2023 14:58:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problems with AlexaControl on Sat, 20 May 2023 23:10:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oldskoolz" aria-label="Profile: oldskoolz">@<bdi>oldskoolz</bdi></a></p>
<p dir="auto">rule 1…  never change MagicMirror or a module source code, it breaks the ability to update. all config goes in MagicMirror/config/config.js</p>
<p dir="auto">you don’t add devices for pages, all you do is set the number of pages you want to navigate to … pages: 3<br />
this will give you devices for page 1,  page 2 and page 3<br />
in the npm start output you should see the number of devices created<br />
that you can access via</p>
<pre><code>Alexa turn on page 2
<p dir="auto">as the devices are fake outlets</p>
<p dir="auto">if u want a different voice command, you can use an actual alexa routine</p>
<pre><code class="language-text">select voice
   go to page 2
action
   smart home devices
  page 2
     power on
<p dir="auto">alexa does not provide any symbolic replacement functions<br />
go to page {n}<br />
replace n with a number on execute</p>
]]></description><link>https://forum.magicmirror.builders/post/109416</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109416</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 20 May 2023 23:10:54 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with AlexaControl on Sat, 20 May 2023 19:47:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oldskoolz" aria-label="Profile: oldskoolz">@<bdi>oldskoolz</bdi></a> just got home. you don’t do anything w the fauxmo file the ac module does everything</p>
]]></description><link>https://forum.magicmirror.builders/post/109414</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109414</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 20 May 2023 19:47:38 GMT</pubDate></item></channel></rss>
