<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror doesn't start after updating to 2.23]]></title><description><![CDATA[<p dir="auto">It’s running on a RPi3B+</p>
<p dir="auto">I upgraded from 2.22 using the sdetweil script, and it went through it without errors.</p>
<p dir="auto">If I ask pm2 MagicMirror is online.<br />
The log file looks like this:</p>
<pre><code>pi@bathmirror:~/MagicMirror $ pm2 logs MagicMirror
[TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
/home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
0|MagicMir | &gt; magicmirror@2.23.0 start
0|MagicMir | &gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
0|MagicMir |
0|MagicMir |
/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
0|MagicMir | [30079:0526/061428.523308:ERROR:node_bindings.cc(552)] Failed to initialize node environment in process: browser , with error: Uncaught SyntaxError: Unexpected token ':'
0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
<p dir="auto">I don’t think it’s the ‘request’ thing, I did the search for request, and commented out all the modules that used that.</p>
<p dir="auto">The config looks like this:</p>
<pre><code>let config = {
	address: "xxx",
	port: 8080,
	basePath: "/",
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","xxx/24"],
	language: "da",
	locale: "da-DK",
	timeFormat: 24,
	units: "metric",
//			module: "MMM-ModuleScheduler",
//			config: {
//				global_schedule: [
//					{from: "0 5 * * *", to: "0 10 * * *", groupClass: "morning_schedule"},
//					{from: "0 18 * * *", to: "0 23 * * *", groupClass: "evening_schedule"},
//					{from: "0 5 * * 1-5", to: "0 10 * * 1-5", groupClass: "weekday_morning_schedule"},
//					{from: "0 6 * * *", to: "0 20 * * *", groupClass: "day_schedule"},
//					{from: "0 0 * * 1-5", to: "59 23 * * 1-5", groupClass: "weekdays_schedule"},
//					{from: "30 5 * * *", to: "59 23 * * *", groupClass: "complimenttime"}
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "Kalenderdage",
			classes: "day_schedule small",
				maximumEntries: 6,
				fetchInterval: 12000000 ,
						symbol: "calendar-check",
						url: "https://calendar.google.com/xxx"
//						url: "https://www.google.com/xxx"
//						url: "webcal://p01-calendarws.icloud.com/ca/subscribe/1/IsLh6fUURb4n_nA6vhWYUmlEe98rz2BN8BhioUPzrC2HVohwJIUCbGuGeTwczZWvXjTqU7vicBATXHojb1p5fn8ub3RCBUwKfHm3jXJDzFE"
			module: "compliments",
			position: "lower_third",
			classes: "complimenttime bold xlarge bright",
				remoteFile: "xxx",
				updateInterval: 120000,
				morningStartTime: 05,
				morningEndTime: 10,
				afternoonStartTime: 15,
				afternoonEndTime: 18,
			module: "weather",
			classes: "day_schedule",
				type: "current",
				units: "metric",
				timeFormat: 24,
				decimalSymbol: ",",
				initialLoadDelay: 0,
				onlyTemp: false,
				locationID: xxx,
				apiKey: "xxx"
			module: "weather",
				type: "forecast",
				units: "metric",
				timeFormat: 24,
				decimalSymbol: ",",
				onlyTemp: true,
				maxNumberOfDays: 7,
				colored: true,
				appendLocationNameToHeader: false,
				locationID: xxx,
				apiKey: "xxx"
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "Ekstra Bladet",
						url: "https://ekstrabladet.dk/rssfeed/all/"
						title: "DR nyheder",
						url: "https://www.dr.dk/nyheder/service/feeds/allenyheder"
						title: "BT",
						url: "https://www.bt.dk/bt/seneste/rss"
						title: "Berlingske.dk",
						url: "https://www.berlingske.dk/content/3/rss"
						title: "TV2 Ã˜st",
						url: "https://www.tv2east.dk/rss"
				updateInterval: 30000,
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
			module: "MMM-News-QR",
				updateType : "push",
				animationSpeed: 2500,
				colorDark: "#fff",
				colorLight: "#000",
				imageSize: 100
			module: "MMM-Remote-Control",
				apiKey: 'xxx',
				showModuleApiMenu: true,
				pm2ProcessName: 'MagicMirror',
//			module: "MMM-Screencast",
//			position: "'bottom_right", // This position is for a hidden &lt;div /&gt; and not the screencast window
//			config: {
//				position: "bottomRight",
//				castName: "Spejl",
//				height: 300,
//				width: 500,
//			module: "MMM-MyCommute",
//			position: "bottom_right",
//			classes: "xsmall",
//			header: "Trafik",
//			config: {
//				apiKey: "xxx",
//				startTime: "05:00",
//				endTime: "12:00",
////				hideDays: [0,6],
//				origin: "xxx",
//				destinations: [
//						destination: "xxx",
//						label: "xxx",
//						mode: "driving",
//						color: "#82E5AA"
//						label: "xxx",
//						mode: "driving",
//						color: "#82E5AA"
<p dir="auto">I tried running the upgrade again, with force, it didn’t help, and this is the output</p>
<pre><code>pi@bathmirror:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
doing test run = false
update log will be in /home/pi/MagicMirror/installers/upgrade.log
Check current Node installation ...
Node currently installed. Checking version number.
Minimum Node version: v16.13.1
Installed Node version: v16.15.1
No Node.js upgrade necessary.
Check current NPM installation ...
NPM currently installed. Checking version number.
Minimum npm version: V7.11.2
Installed npm version: V8.11.0
No npm upgrade necessary.
saving custom.css
upgrading from version 2.23.0 to 2.23.0
fetching latest revisions
updating MagicMirror runtime, please wait
&gt; magicmirror@2.23.0 postinstall
&gt; npm run install-vendor &amp;&amp; npm run install-fonts &amp;&amp; echo "MagicMirror² installation finished successfully!
&gt; "
&gt; magicmirror@2.23.0 install-vendor
&gt; echo "Installing vendor files ...
&gt; " &amp;&amp; cd vendor &amp;&amp; npm install --loglevel=error --no-audit --no-fund --no-update-notifier
up to date in 17s
&gt; magicmirror@2.23.0 install-fonts
&gt; echo "Installing fonts ...
&gt; " &amp;&amp; cd fonts &amp;&amp; npm install --loglevel=error --no-audit --no-fund --no-update-notifier
up to date in 3s
&gt; magicmirror@2.23.0 prepare
&gt; [ -f node_modules/.bin/husky ] &amp;&amp; husky install || echo no husky installed.
no husky installed.
added 325 packages, changed 1 package, and audited 327 packages in 3m
80 packages are looking for funding
  run `npm fund` for details
2 vulnerabilities (1 moderate, 1 high)
To address all issues, run:
  npm audit fix
Run `npm audit` for details.
Checking for modules with removed libraries
processing dependency changes for active modules with package.json files
processing for module MMM-Remote-Control please wait
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
added 40 packages, and audited 41 packages in 15s
8 packages are looking for funding
found 0 vulnerabilities
processing complete for module MMM-Remote-Control
restoring custom.css
]]></description><link>https://forum.magicmirror.builders/topic/17811/magicmirror-doesn-t-start-after-updating-to-2-23</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 09:20:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17811.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 May 2023 04:26:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror doesn't start after updating to 2.23 on Fri, 26 May 2023 05:23:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fribse" aria-label="Profile: fribse">@<bdi>fribse</bdi></a> Ok, that is weird, after doing the force, and waiting for quite a while, it works again???<br />
So I’m changing it to solved, running the update once more, with “force”, made it work</p>
]]></description><link>https://forum.magicmirror.builders/post/109497</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109497</guid><dc:creator><![CDATA[fribse]]></dc:creator><pubDate>Fri, 26 May 2023 05:23:39 GMT</pubDate></item></channel></rss>
