<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR-Sensor-Lite modification]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/17518/pir-problem">PIR problem</a></p>
<p dir="auto">I have also been experiencing similar problems with my PIR sensor since upgrading to Bullseye.  After trying numerous modules, I inquired about suggestions for updated modules that have been known to work with Bullseye and posted a request in the forum (<a href="https://forum.magicmirror.builders/topic/17810/pir-sensor-for-raspbian-11">https://forum.magicmirror.builders/topic/17810/pir-sensor-for-raspbian-11</a>).  It seems that many have chosen to go with the MMM-PIR-Sensor-Lite module, so I will pose my question here.</p>
<p dir="auto">My PIR sensor appears to function properly and after the standby timeout, the HDMI output will turn off (I am using the ‘xrandr’ command type).  However, this results in my monitor detecting a missing signal and it will put up a “No Signal” indication on the screen.  Further, after a certain time, it will turn the monitor OFF, which requires that I need to push buttons in order to turn it back on again.  My understanding is that I need to use HDMI CEC commands in order to instruct the monitor to turn off, which will prevent the “No Signal” indication from appearing.  This was a completely working feature in my Magic Mirror prior to upgrading to Bullseye.</p>
<p dir="auto">I used the EXT-Pir and EXT-Screen modules (<a href="https://wiki.bugsounet.fr/" target="_blank" rel="noopener noreferrer nofollow ugc">https://wiki.bugsounet.fr/</a>) in the past and they were able to accomplish the task.  However, I don’t have enough skill to examine the code to determine how the commands are being sent to turn off my monitor.  The EXT-Screen module simply required that I choose a mode (mode:4 - use HDMI CEC) in the configuration and it successfully controlled the monitor.  What I would need is to have these commands implemented in a PIR sensor module, or I would need some guidance on how to implement these codes in the MMM-PIR-Sensor-Lite module.</p>
<p dir="auto">Any insight you might have would be appreciated…</p>
]]></description><link>https://forum.magicmirror.builders/topic/17813/mmm-pir-sensor-lite-modification</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 15:54:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17813.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 May 2023 15:15:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Tue, 30 May 2023 16:30:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> got it</p>
]]></description><link>https://forum.magicmirror.builders/post/109581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109581</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 30 May 2023 16:30:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Tue, 30 May 2023 16:17:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/109574">MMM-PIR-Sensor-Lite modification</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> sure give me access</p>
<p dir="auto">sended ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/109579</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109579</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Tue, 30 May 2023 16:17:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Mon, 29 May 2023 22:47:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> sure give me access</p>
]]></description><link>https://forum.magicmirror.builders/post/109574</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109574</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 May 2023 22:47:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Mon, 29 May 2023 21:14:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freddy_boy" aria-label="Profile: Freddy_boy">@<bdi>Freddy_boy</bdi></a> perfect !</p>
<p dir="auto">You understand now why i prefer works alone :D</p>
<p dir="auto">I repeat again … If someone have the time to maintened this new module,<br />
I will add a contributor access :)</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>: this module can be referenced on the third party module page ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/109570</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109570</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Mon, 29 May 2023 21:14:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Mon, 29 May 2023 19:20:18 GMT]]></title><description><![CDATA[<p dir="auto">Terrific!  I just installed MMM-Pir and it works properly as before.  I am using mode 4 (HDMI CEC) and the monitor responds as expected.  Thanks very much for the quick response!  You guys are a real credit to this open source project!</p>
]]></description><link>https://forum.magicmirror.builders/post/109566</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109566</guid><dc:creator><![CDATA[Freddy_boy]]></dc:creator><pubDate>Mon, 29 May 2023 19:20:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Mon, 29 May 2023 19:18:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> Hi,<br />
sorry but at the moment a do not have plans to maintain more modules than i already do.<br />
In addition i do not see a reason why there should be a need for a additional screensave module.<br />
Most of the features are present in the exiting ones. I do not like the idea of putting the GPIO logic and screensave logic into the same module and had problems with it in my setup in the past. Thats why i created the two separted modules.<br />
I forked MMM-Screen as i wanted to check if there is a easy way to implement the CEC logic to my screensave module. I do not think it would be a big deal. The problem is that i do not have a CEC aware monitor at the moment and do not have the time to build a dev environment with my tv.</p>
]]></description><link>https://forum.magicmirror.builders/post/109565</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109565</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Mon, 29 May 2023 19:18:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Mon, 29 May 2023 18:41:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> said in <a href="/post/109547">MMM-PIR-Sensor-Lite modification</a>:</p>
<p dir="auto">I will create <a href="https://github.com/bugsounet/MMM-Pir" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Pir</a></p>
<p dir="auto">It’s done.<br />
It’s based with my <code>EXT-Screen</code> and <code>EXT-Pir</code> plugins<br />
I have rewrite and clean it for MMM using</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a>:<br />
do you want to try to maintened it ?<br />
I can add you as contributor<br />
(I see that you fork <code>EXT-Screen</code>)<br />
I have really no time for any MMM :/</p>
]]></description><link>https://forum.magicmirror.builders/post/109563</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109563</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Mon, 29 May 2023 18:41:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Mon, 29 May 2023 18:34:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freddy_boy" aria-label="Profile: Freddy_boy">@<bdi>Freddy_boy</bdi></a><br />
Hi, my <a href="https://github.com/Tom-Hirschberger/MMM-Screen-Powersave-Notification" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Screen-Powersave-Notification</a>  module can do this job. It has a <code>hideInsteadShutoff</code>option.<br />
You need my <a href="https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-GPIO-Notifications</a> in addition.<br />
I wrote a <a href="https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/blob/master/examples/HC-SR501/HC-SR501-GPIO4-README-EN.md" target="_blank" rel="noopener noreferrer nofollow ugc">Guide</a> of how to configure the modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/109562</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109562</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Mon, 29 May 2023 18:34:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Mon, 29 May 2023 12:03:54 GMT]]></title><description><![CDATA[<p dir="auto">Really…</p>
<p dir="auto">Should I recode a module by merging screen and pir plugins ??</p>
<p dir="auto">Yes, I can do it but… I not really interested to maintened it<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>: if I add you to contributor, you are able to “maintened” it ?</p>
]]></description><link>https://forum.magicmirror.builders/post/109547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109547</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Mon, 29 May 2023 12:03:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 23:20:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freddy_boy" aria-label="Profile: Freddy_boy">@<bdi>Freddy_boy</bdi></a> dang, this module also doesn’t alert other modules…</p>
<p dir="auto">too much to change quickly…   sorry</p>
]]></description><link>https://forum.magicmirror.builders/post/109522</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109522</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 May 2023 23:20:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 23:06:44 GMT]]></title><description><![CDATA[<p dir="auto">I assume that I would need to re-configure the MMM-PIR-Sensor-Lite module to prevent the command from turning OFF the HDMI.  How do I do that?</p>
]]></description><link>https://forum.magicmirror.builders/post/109521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109521</guid><dc:creator><![CDATA[Freddy_boy]]></dc:creator><pubDate>Fri, 26 May 2023 23:06:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 22:25:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freddy_boy" aria-label="Profile: Freddy_boy">@<bdi>Freddy_boy</bdi></a> you can try my MMM-SleepWake<br />
<a href="https://github.com/sdetweil/MMM-SleepWake" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-SleepWake</a></p>
<p dir="auto">it listens for pir sensor or lite to signal user presence</p>
<p dir="auto">and mode HIDE will hide all the modules and show them again when a user appears</p>
<p dir="auto">I built this to use this with a webcam as I don’t have any pirs, and none of my monitors will behave (big ‘no power’ warning when hdmi goes off)</p>
<p dir="auto">I just added the code for sensor-lite, just a check …</p>
]]></description><link>https://forum.magicmirror.builders/post/109520</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109520</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 May 2023 22:25:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 20:52:54 GMT]]></title><description><![CDATA[<p dir="auto">As I dig more into this, I am finding that there seem to be a lot of reports that some LG monitors do not support using the Standby command.  I am not certain of how this was working before, but now I am beginning to suspect that the Magic Mirror app simply went hidden when the timeout occurred.  Perhaps the monitor was ON all along, but the app disappeared from the screen?  I don’t know if this applies in my situation, because I can’t seem to make any of the CEC commands work at all.</p>
<p dir="auto">I attempted to turn OFF the monitor, and then issue the CEC ON command, but that also did not work.  It appears to be some fundamental issue with the CEC commands that I may not be able to use.  Are you aware of any modules that simply blackout the Magic Mirror app using the PIR sensor?  I know that isn’t really saving as much energy, but it might be worthwhile implementing…</p>
]]></description><link>https://forum.magicmirror.builders/post/109517</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109517</guid><dc:creator><![CDATA[Freddy_boy]]></dc:creator><pubDate>Fri, 26 May 2023 20:52:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 20:03:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freddy_boy" aria-label="Profile: Freddy_boy">@<bdi>Freddy_boy</bdi></a> google is your friend… sort of…lol…  i would search the messages…</p>
]]></description><link>https://forum.magicmirror.builders/post/109516</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109516</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 May 2023 20:03:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 19:59:37 GMT]]></title><description><![CDATA[<p dir="auto">Here is the last portion of the debug log when I attempt to issue the standby command:</p>
<p dir="auto">WARNING: [            3123]     FIXME: LG seems to have bugged out. resetting to ‘in transition standby to on’. the return button will not work<br />
DEBUG:   [            3123]     Recorder 1 (1): power status changed from ‘on’ to ‘in transition from standby to on’<br />
DEBUG:   [            3123]     &lt;&lt; Recorder 1 (1) -&gt; TV (0): in transition from standby to on<br />
TRAFFIC: [            3123]     &lt;&lt; 10:90:02<br />
DEBUG:   [            3123]     &gt;&gt; TV (0) -&gt; Recorder 1 (1): give device power status (8F)<br />
DEBUG:   [            3175]     expected response not received (90: report power status)<br />
DEBUG:   [            3189]     CLinuxCECAdapterCommunication::Process - ioctl CEC_RECEIVE - rx_status=01 len=2 addr=01 opcode=46<br />
DEBUG:   [            3276]     CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=3 addr=10 opcode=90<br />
TRAFFIC: [            3276]     &lt;&lt; 10:8f<br />
DEBUG:   [            3276]     Recorder 1 (1): power status changed from ‘in transition from standby to on’ to ‘on’<br />
DEBUG:   [            3366]     CLinuxCECAdapterCommunication::Process - ioctl CEC_RECEIVE - rx_status=01 len=3 addr=01 opcode=89<br />
DEBUG:   [            3428]     CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=2 addr=10 opcode=8f<br />
TRAFFIC: [            3429]     &gt;&gt; 01:90:00<br />
DEBUG:   [            3429]     TV (0): power status changed from ‘unknown’ to ‘on’<br />
DEBUG:   [            3429]     expected response received (90: report power status)<br />
DEBUG:   [            3429]     &gt;&gt; TV (0) -&gt; Recorder 1 (1): report power status (90)<br />
NOTICE:  [            3429]     &lt;&lt; putting ‘TV’ (0) in standby mode<br />
TRAFFIC: [            3429]     &lt;&lt; 10:36<br />
TRAFFIC: [            3429]     &gt;&gt; 01:1a:01<br />
DEBUG:   [            3429]     &gt;&gt; TV (0) -&gt; Recorder 1 (1): give deck status (1A)<br />
DEBUG:   [            3494]     CLinuxCECAdapterCommunication::Process - ioctl CEC_RECEIVE - rx_status=01 len=2 addr=01 opcode=46<br />
DEBUG:   [            3557]     CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=2 addr=10 opcode=36<br />
DEBUG:   [            3557]     unregistering all CEC clients<br />
NOTICE:  [            3557]     unregistering client: libCEC version = 6.0.2, client version = 6.0.2, firmware version = 0, logical address(es) = Recorder 1 (1) , physical address: 1.0.0.0, compiled on Linux-5.10.63-v8+ … , features: P8_USB, DRM, P8_detect, randr, RPi, Exynos, Linux, AOCEC<br />
DEBUG:   [            3557]     Recorder 1 (1): power status changed from ‘on’ to ‘unknown’<br />
DEBUG:   [            3557]     Recorder 1 (1): vendor = Unknown (000000)<br />
DEBUG:   [            3557]     Recorder 1 (1): CEC version unknown<br />
DEBUG:   [            3557]     Recorder 1 (1): osd name set to ‘Recorder 1’<br />
DEBUG:   [            3557]     Recorder 1 (1): device status changed into ‘unknown’<br />
DEBUG:   [            3557]     CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0<br />
TRAFFIC: [            3557]     &gt;&gt; 01:46<br />
DEBUG:   [            3558]     CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0<br />
TRAFFIC: [            3558]     &gt;&gt; 01:89:01<br />
TRAFFIC: [            3558]     &gt;&gt; 01:46<br />
DEBUG:   [            3558]     CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=1000<br />
DEBUG:   [            3558]     &gt;&gt; TV (0) -&gt; Recorder 1 (1): give osd name (46)<br />
DEBUG:   [            3558]     &gt;&gt; TV (0) -&gt; Recorder 1 (1): vendor command (89)<br />
DEBUG:   [            4564]     CLinuxCECAdapterCommunication::Process - stopped - m_path=/dev/cec0 m_fd=4<br />
DEBUG:   [            4564]     CLinuxCECAdapterCommunication::Close - m_path=/dev/cec0 m_fd=4</p>
<p dir="auto">This seems to indicate that it will not take the command, and returns the monitor to the ON state.  But I don’t know where to look next…</p>
]]></description><link>https://forum.magicmirror.builders/post/109515</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109515</guid><dc:creator><![CDATA[Freddy_boy]]></dc:creator><pubDate>Fri, 26 May 2023 19:59:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 19:39:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freddy_boy" aria-label="Profile: Freddy_boy">@<bdi>Freddy_boy</bdi></a> I have not studied the CEC commands</p>
]]></description><link>https://forum.magicmirror.builders/post/109514</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109514</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 May 2023 19:39:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 19:35:41 GMT]]></title><description><![CDATA[<p dir="auto">Yes, but this used to work previously.  I suspect that none of the commands are working (even if no error message is returned).  I attempted other commands, and they also do not seem to work.  For example, I tried to change HDMI inputs, and the monitor remains at the same input.  I think I need to determine if I can get ANY HDMI CEC command to work at all.   It seems to be a missing step somewhere…</p>
]]></description><link>https://forum.magicmirror.builders/post/109513</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109513</guid><dc:creator><![CDATA[Freddy_boy]]></dc:creator><pubDate>Fri, 26 May 2023 19:35:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 19:23:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freddy_boy" aria-label="Profile: Freddy_boy">@<bdi>Freddy_boy</bdi></a> ok, I have a CEC tv which I can turn OFF, but not back on…</p>
]]></description><link>https://forum.magicmirror.builders/post/109511</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109511</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 May 2023 19:23:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 18:50:26 GMT]]></title><description><![CDATA[<p dir="auto">I have also tried:<br />
sudo echo ‘standby 0.0.0.0’ | sudo cec-client -s -d 1</p>
<p dir="auto">but got the same result…</p>
]]></description><link>https://forum.magicmirror.builders/post/109508</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109508</guid><dc:creator><![CDATA[Freddy_boy]]></dc:creator><pubDate>Fri, 26 May 2023 18:50:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 18:37:55 GMT]]></title><description><![CDATA[<p dir="auto">Update:  I’m not sure how it happened, but I believe that my monitor had the controls disabled.  It is an LG monitor using Simplink, and when I enable it, I can now see the device:</p>
<p dir="auto">pi@raspberrypi:~ $ echo ‘scan’ | cec-client -s -d 1<br />
opening a connection to the CEC adapter…<br />
requesting CEC bus information …<br />
CEC bus information</p>
<p dir="auto">===================<br />
device #0: TV<br />
address:       0.0.0.0<br />
active source: yes<br />
vendor:        LG<br />
osd string:    TV<br />
CEC version:   1.3a<br />
power status:  on<br />
language:      eng</p>
<p dir="auto">device #1: Recorder 1<br />
address:       1.0.0.0<br />
active source: no<br />
vendor:        LG<br />
osd string:    CECTester<br />
language:      eng</p>
<p dir="auto">currently active source: TV (0)</p>
<p dir="auto">However, when I attempt to turn OFF the monitor using the CEC control commands, it doesn’t seem to work.  The commands appear to be working (ie. no error messages returned), but the monitor remains ON when I issue the standby command.  I also use the ‘power’ command to check the status of the monitor, and it confirms that it is ON.</p>
<p dir="auto">pi@raspberrypi:~ $ echo ‘pow 0.0.0.0’ | cec-client -s -d 1<br />
pi@raspberrypi:~ $ echo ‘standby 0.0.0.0’ | cec-client -s -d 1<br />
pi@raspberrypi:~ $</p>
]]></description><link>https://forum.magicmirror.builders/post/109507</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109507</guid><dc:creator><![CDATA[Freddy_boy]]></dc:creator><pubDate>Fri, 26 May 2023 18:37:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 18:00:23 GMT]]></title><description><![CDATA[<p dir="auto">From SSH connection:</p>
vendor:        Pulse Eight<br />
CEC version:   1.4<br />
language:      eng</p>
<p dir="auto">currently active source: unknown (-1)<br />
]]></description><link>https://forum.magicmirror.builders/post/109506</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109506</guid><dc:creator><![CDATA[Freddy_boy]]></dc:creator><pubDate>Fri, 26 May 2023 18:00:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 16:55:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freddy_boy" aria-label="Profile: Freddy_boy">@<bdi>Freddy_boy</bdi></a> said in <a href="/post/109504">MMM-PIR-Sensor-Lite modification</a>:</p>
<p dir="auto">Also, the files are difficult to view, as the entire code is written on a single line, so you need to search for text strings to find anything.</p>
<p dir="auto">yes, he has minified the code to  prevent others using it…  or learning form it…</p>
<p dir="auto">does this work to list the cec devices?</p>
<pre><code>echo 'scan' | cec-client -s -d 1
]]></description><link>https://forum.magicmirror.builders/post/109505</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109505</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 May 2023 16:55:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 16:16:25 GMT]]></title><description><![CDATA[<p dir="auto">I attempted to run the CEC commands manually, but that doesn’t work.  I just keep getting active source unknown error message.  Unfortunately, I don’t have the original EXT-Screen module because I attempted to perform an update on the module, so I only have the updated module.  Perhaps the updated module has updated code?  But I don’t know where to look for the required commands.   I’ve looked at the EXT-Screen.js file and the node_helper.js file and I don’t see anything that looks like a CEC command.  Also, the files are difficult to view, as the entire code is written on a single line, so you need to search for text strings to find anything.</p>
]]></description><link>https://forum.magicmirror.builders/post/109504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109504</guid><dc:creator><![CDATA[Freddy_boy]]></dc:creator><pubDate>Fri, 26 May 2023 16:16:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor-Lite modification on Fri, 26 May 2023 15:35:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freddy_boy" aria-label="Profile: Freddy_boy">@<bdi>Freddy_boy</bdi></a> you could copy it out of the ext screen module which worked… (if u still have the older repo installed somewhere)</p>
<p dir="auto">thats what I did when I was testing PIR and other sensors a year or so ago</p>
]]></description><link>https://forum.magicmirror.builders/post/109502</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109502</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 May 2023 15:35:47 GMT</pubDate></item></channel></rss>
