<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-octoprint]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">This is my second plugin. This module was sort of requested by <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> and I thought it would be a great idea, since octoprint has a larger user base.</p>
<p dir="auto"><img src="/assets/uploads/files/1685361386481-example.png" alt="example.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Just like the <a href="https://forum.magicmirror.builders/topic/17814/mmm-moonraker-for-klipper-3d-printers">moonraker module</a> I developed a module to display data from the Octoprint API.</p>
<p dir="auto">It has some minor differences when setting up, but it should look the same once everything is setup properly.</p>
<p dir="auto">You can find the repository, installation guide and config options on my github: <a href="https://github.com/btastic/MMM-octoprint" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/btastic/MMM-octoprint</a></p>
<p dir="auto">Feel free to discuss, ask questions or add suggestions for further development.</p>
<p dir="auto">Best regards<br />
Ben</p>
]]></description><link>https://forum.magicmirror.builders/topic/17816/mmm-octoprint</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 23:19:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17816.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 May 2023 11:58:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-octoprint on Sat, 11 Jan 2025 17:13:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xiexodusix" aria-label="Profile: xIExodusIx">@<bdi>xIExodusIx</bdi></a></p>
<p dir="auto">please don’t double post… all posts from users with reputation below 2 are reviewed (by me)… surprizingly I DO do other things than MM…!!</p>
<p dir="auto">from the doc, middle_center is all the way across the screen (magenta here)</p>
<p dir="auto"><a href="https://docs.magicmirror.builders/modules/configuration.html#position" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/configuration.html#position</a></p>
<p dir="auto"><img src="/assets/uploads/files/1736615471330-regions.png" alt="regions.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/122884</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122884</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Jan 2025 17:13:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Sat, 11 Jan 2025 17:01:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> &amp; <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
Yes, everything is working now, even the thumbnail and the layer progress are displayed. Only downside: It is displayed very, very small on the left edge of the screen. Not as I specified “middle_center”. I’m trying to figure out why.</p>
<p dir="auto">But thanks for your great and fast Help :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/122882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122882</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Sat, 11 Jan 2025 17:01:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Thu, 09 Jan 2025 11:32:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xiexodusix" aria-label="Profile: xIExodusIx">@<bdi>xIExodusIx</bdi></a> great!! thx for the feedback</p>
]]></description><link>https://forum.magicmirror.builders/post/122802</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122802</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Jan 2025 11:32:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Thu, 09 Jan 2025 10:19:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a> &amp; <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Danke für die Hilfe, es scheint zu funktionieren, jetzt wird nicht mehr nur “Lade…” angezeigt, sondern die angegebenen Druck-Infos. Ich muss das aber noch mit einem Druck-Auftrag testen.</p>
<p dir="auto">Thanks for the help, it seems to work, now it’s not just showing “loading…” anymore, now it shows the specified print information. But I still have to test this with a print job.</p>
<p dir="auto">Thank you :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/122801</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122801</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Thu, 09 Jan 2025 10:19:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Wed, 08 Jan 2025 15:10:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a> or just comment out</p>
<p dir="auto">// const fetch = require(“fetch”);</p>
]]></description><link>https://forum.magicmirror.builders/post/122764</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122764</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2025 15:10:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Wed, 08 Jan 2025 15:08:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xiexodusix" aria-label="Profile: xIExodusIx">@<bdi>xIExodusIx</bdi></a> Try this: Remove this line <code>const fetch = require("fetch");</code> from <code>node_helper.js</code> in the module directory. If it doesn’t work, show us the log output.</p>
]]></description><link>https://forum.magicmirror.builders/post/122763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122763</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Wed, 08 Jan 2025 15:08:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Wed, 08 Jan 2025 14:22:47 GMT]]></title><description><![CDATA[<p dir="auto">Interessantes Modul,<br />
leider wird bei mir außer “Lade…” nichts weiter angezeigt, auch nach 24 Std. nicht.</p>
<p dir="auto">Hard- &amp; Software Infos:<br />
Magic Mirror: 2.30 on Raspberry Pi4, 4GB<br />
OctoPrint: 1.10.3, Python: 3.11.2, OctoPi: 1.1.0 on Raspberry Pi4, 8GB</p>
]]></description><link>https://forum.magicmirror.builders/post/122762</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122762</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Wed, 08 Jan 2025 14:22:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Tue, 13 Jun 2023 18:40:24 GMT]]></title><description><![CDATA[<p dir="auto">Great module, but mine keeps flipping between fine and unavailable. When it flips to unavailable I look at the ip address and all looks fine…</p>
<p dir="auto">any idea what the issue is?</p>
]]></description><link>https://forum.magicmirror.builders/post/109801</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109801</guid><dc:creator><![CDATA[jasondreher]]></dc:creator><pubDate>Tue, 13 Jun 2023 18:40:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Mon, 29 May 2023 22:46:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/btastic" aria-label="Profile: btastic">@<bdi>btastic</bdi></a> I did install the plugins</p>
<p dir="auto">and went into thumbnails and scanned the gcode files…</p>
]]></description><link>https://forum.magicmirror.builders/post/109573</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109573</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 May 2023 22:46:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Mon, 29 May 2023 22:33:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/btastic" aria-label="Profile: btastic">@<bdi>btastic</bdi></a> Slick. I like it.</p>
]]></description><link>https://forum.magicmirror.builders/post/109572</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109572</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 29 May 2023 22:33:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Mon, 29 May 2023 21:19:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I added a fallback thumbnail</p>
<p dir="auto"><img src="/assets/uploads/files/1685395149464-b1mou4lexz.png" alt="b1MoU4LExz.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/109571</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109571</guid><dc:creator><![CDATA[btastic]]></dc:creator><pubDate>Mon, 29 May 2023 21:19:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Mon, 29 May 2023 20:24:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for the heads up, just added it.</p>
]]></description><link>https://forum.magicmirror.builders/post/109568</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109568</guid><dc:creator><![CDATA[btastic]]></dc:creator><pubDate>Mon, 29 May 2023 20:24:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Mon, 29 May 2023 20:24:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you for testing :) I fixed up the documentation to include a position.</p>
<p dir="auto">As for the missing thumbnails, did you install the plugin like I mentioned in the readme file? The plugins site also describes how to add thumbnails in your slicer software.</p>
<p dir="auto">You should only enable the <code>showThumbnail</code> flag once you have thumbnails working. Otherwise it can lead to unexpected behaviour, like you’re experiencing.</p>
<p dir="auto">The same for the layer progress. It can only be properly shown when the plugin and slicer are properly configured.</p>
<p dir="auto">I added some remarks about those flags in the readme file.</p>
]]></description><link>https://forum.magicmirror.builders/post/109567</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109567</guid><dc:creator><![CDATA[btastic]]></dc:creator><pubDate>Mon, 29 May 2023 20:24:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Mon, 29 May 2023 18:58:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/btastic" aria-label="Profile: btastic">@<bdi>btastic</bdi></a> also, in your css file, you should prefix the classes with your modulename</p>
<p dir="auto">.MMM-octoprint .colum</p>
<p dir="auto">as all the stylesheets are loaded into the same namespace…<br />
it could collide with another module defining the same class name</p>
]]></description><link>https://forum.magicmirror.builders/post/109564</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109564</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 May 2023 18:58:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Mon, 29 May 2023 17:53:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/btastic" aria-label="Profile: btastic">@<bdi>btastic</bdi></a></p>
<p dir="auto">you need a position:     set in the example , else nothing displays</p>
<p dir="auto">for some reason my gcode files dont have thumbnails…</p>
<p dir="auto">so the img src url ends up being</p>
<p dir="auto"><a href="http://octopi/undefined" target="_blank" rel="noopener noreferrer nofollow ugc">http://octopi/undefined</a></p>
<p dir="auto">you could pass th e endpoint and tail part of the url to the template<br />
and if the tail is undefined then do a messge instead of the img<br />
or construct the full url in the template</p>
]]></description><link>https://forum.magicmirror.builders/post/109561</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109561</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 May 2023 17:53:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-octoprint on Mon, 29 May 2023 12:23:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/btastic" aria-label="Profile: btastic">@<bdi>btastic</bdi></a> awesome…</p>
]]></description><link>https://forum.magicmirror.builders/post/109551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109551</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 May 2023 12:23:39 GMT</pubDate></item></channel></rss>
