<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-ImagesPhotos issue]]></title><description><![CDATA[<p dir="auto">After install Magic Mirror will not auto boot after change to config file.<br />
Receiving this when attempting to run npm run start in he Magic Mirror folder.</p>
<p dir="auto">magicmirror@2.23.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">[13.06.2023 12:54.22.117] [LOG]   Starting MagicMirror: v2.23.0<br />
[13.06.2023 12:54.22.123] [LOG]   Loading config …<br />
[13.06.2023 12:54.22.126] [DEBUG] config template file not exists, no envsubst<br />
[13.06.2023 12:54.22.132] [LOG]   Loading module helpers …<br />
[13.06.2023 12:54.22.145] [LOG]   Initializing new module helper …<br />
[13.06.2023 12:54.22.146] [LOG]   Module helper loaded: MMM-PiTemp<br />
[13.06.2023 12:54.22.146] [LOG]   No helper found for module: MMM-connection-status.<br />
[13.06.2023 12:54.22.401] [LOG]   Initializing new module helper …<br />
[13.06.2023 12:54.22.402] [LOG]   Module helper loaded: MMM-nyc-transit<br />
[13.06.2023 12:54.22.408] [ERROR] (node:6269) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’<br />
Require stack:</p>
<ul>
<li>/home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js</li>
<li>/home/pi/MagicMirror/js/app.js</li>
<li>/home/pi/MagicMirror/js/electron.js</li>
<li>/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js</li>
<li>at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)<br />
at n._resolveFilename (node:electron/js2c/browser_init:2:109751)<br />
at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)<br />
at Module._load (node:internal/modules/cjs/loader:811:27)<br />
at f._load (node:electron/js2c/asar_bundle:2:13330)<br />
at Module.require (node:internal/modules/cjs/loader:1035:19)<br />
at require (node:internal/modules/cjs/helpers:102:18)<br />
at Object. (/home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js:10:15)<br />
at Module._compile (node:internal/modules/cjs/loader:1141:14)<br />
at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)<br />
at Module.load (node:internal/modules/cjs/loader:1011:32)<br />
at Module._load (node:internal/modules/cjs/loader:846:12)<br />
at loadModule (/home/pi/MagicMirror/js/app.js:184:19)<br />
(Use <code>electron --trace-warnings ...</code> to show where the warning was created)<br />
[13.06.2023 12:54.22.410] [ERROR] (node:6269) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag <code>--unhandled-rejections=strict</code> (see <a href="https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode</a>). (rejection id: 2)<br />
[13.06.2023 12:54.22.704] [LOG]   Launching application.<br />
MESA-LOADER: failed to retrieve device information<br />
MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)<br />
failed to load driver: kms_swrast<br />
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)<br />
failed to load swrast driver</li>
</ul>
<p dir="auto">Any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17845/mmm-imagesphotos-issue</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 09:09:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17845.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Jun 2023 17:01:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Fri, 16 Jun 2023 13:36:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Got it!   Solved!<br />
Sam, I can’t thank you enough for your time and patience.  I appreciate all of your help.  Over the years even!<br />
I dont mean to be an annoyance.  I find these issues daunting and beyond understanding at times.</p>
]]></description><link>https://forum.magicmirror.builders/post/109826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109826</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Fri, 16 Jun 2023 13:36:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Thu, 15 Jun 2023 23:21:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> correct, did you add the missing library request??</p>
<p dir="auto">the link says,</p>
<p dir="auto">read the messages output by MM at startup (which you showed above)<br />
find the not found message, which has the library name in it</p>
<p dir="auto">use the library name in an</p>
<pre><code>npm install  library_name_here
<p dir="auto">command while the current folder is the module folder</p>
<p dir="auto">I am trying to teach you how to resolve this on your own next time… vs just giving u the answer, and having to do that over and over</p>
]]></description><link>https://forum.magicmirror.builders/post/109821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109821</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Jun 2023 23:21:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Thu, 15 Jun 2023 21:56:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
After following your basic instructions I’m still having the issue.</p>
<p dir="auto">To clarify, after adding the modules config information, the mirror wont start up… removing the config information and saving auto starts the mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/109820</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109820</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Thu, 15 Jun 2023 21:56:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Wed, 14 Jun 2023 18:55:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I’m gonna give it a go later tonight</p>
]]></description><link>https://forum.magicmirror.builders/post/109813</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109813</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Wed, 14 Jun 2023 18:55:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Wed, 14 Jun 2023 14:16:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> are you back up and running?</p>
]]></description><link>https://forum.magicmirror.builders/post/109812</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109812</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Jun 2023 14:16:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Wed, 14 Jun 2023 13:04:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thank you Sam!!</p>
]]></description><link>https://forum.magicmirror.builders/post/109811</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109811</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Wed, 14 Jun 2023 13:04:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Wed, 14 Jun 2023 01:33:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> see the link I posted on what to do. no research needed<br />
<a href="https://forum.magicmirror.builders/topic/17845/mmm-imagesphotos-issue/2?_=1686706297079">https://forum.magicmirror.builders/topic/17845/mmm-imagesphotos-issue/2?_=1686706297079</a></p>
]]></description><link>https://forum.magicmirror.builders/post/109809</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109809</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Jun 2023 01:33:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Wed, 14 Jun 2023 00:50:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">i have not yet.  I’ll need to research how to do that properly…</p>
]]></description><link>https://forum.magicmirror.builders/post/109807</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109807</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Wed, 14 Jun 2023 00:50:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Tue, 13 Jun 2023 19:42:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> did u fix the missing library problem???   which is why MM doesn’t start???</p>
]]></description><link>https://forum.magicmirror.builders/post/109804</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109804</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 13 Jun 2023 19:42:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Tue, 13 Jun 2023 19:41:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
thanks Sam.  after adjusting the devDependencies in package.json then running npm install seemed to correct the install.</p>
<p dir="auto">I have auto start mirror enabled when making adjustments to config file.  However after adding the config info for this module, the mirror wont start.   maybe too old of a module…any suggestions on a better image viewer module?</p>
]]></description><link>https://forum.magicmirror.builders/post/109803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109803</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Tue, 13 Jun 2023 19:41:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Tue, 13 Jun 2023 18:54:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> ok, fun stuff…</p>
<p dir="auto">the module is so old that the development dependencies no longer exist…</p>
<p dir="auto">so</p>
<p dir="auto">edit the package.json</p>
<p dir="auto">and change this</p>
<pre><code>  "devDependencies": {
<p dir="auto">to this.</p>
<pre><code>  "devDependencies1": {
<p dir="auto">the rerun npm install</p>
<p dir="auto">another stupid thing, npm gives you the option to NOT  install the dev stuff. --omit=dev, BUT it still checks them and fails if they don’t work…</p>
<p dir="auto">so, we have to force them to not exist…</p>
]]></description><link>https://forum.magicmirror.builders/post/109802</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109802</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 13 Jun 2023 18:54:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Tue, 13 Jun 2023 18:05:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">This might be over my head…</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror/modules/MMM-ImagesPhotos $ npm install<br />
npm ERR! code ERESOLVE<br />
npm ERR! ERESOLVE could not resolve<br />
npm ERR!<br />
npm ERR! While resolving: magicmirror-images-photos@0.1.1<br />
npm ERR! Found: stylelint@14.16.1<br />
npm ERR! node_modules/stylelint<br />
npm ERR!   peer stylelint@“14.x” from grunt-stylelint@0.18.0<br />
npm ERR!   node_modules/grunt-stylelint<br />
npm ERR!     dev grunt-stylelint@“latest” from the root project<br />
npm ERR!<br />
npm ERR! Could not resolve dependency:<br />
npm ERR! dev stylelint-config-standard@“latest” from the root project<br />
npm ERR!<br />
npm ERR! Conflicting peer dependency: stylelint@15.7.0<br />
npm ERR!   peer stylelint@“^15.5.0” from stylelint-config-standard@33.0.0<br />
npm ERR!   node_modules/stylelint-config-standard<br />
npm ERR!<br />
npm ERR! Fix the upstream dependency conflict, or retry<br />
npm ERR! this command with --force, or --legacy-peer-deps<br />
npm ERR! to accept an incorrect (and potentially broken) dependency resolution.<br />
npm ERR!<br />
npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.</p>
<p dir="auto">npm ERR! A complete log of this run can be found in:<br />
npm ERR!     /home/pi/.npm/_logs/2023-06-13T18_03_53_057Z-debug-0.log</p>
]]></description><link>https://forum.magicmirror.builders/post/109800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109800</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Tue, 13 Jun 2023 18:05:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ImagesPhotos issue on Tue, 13 Jun 2023 17:52:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> see <a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/109799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109799</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 13 Jun 2023 17:52:12 GMT</pubDate></item></channel></rss>
