<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Axis camera display]]></title><description><![CDATA[<p dir="auto">has anyone been able to get axis cameras to display on their mirror?  I tried with a couple of the iFrame modules and had no success.  Curious if anyone has had success.   Ideally I can get it to rotate between two different camera streams.   I’m currently using the smartwebdisplay module and I jut get a text readout saying “updated requested at…” and then it shows the interval.  The two various url options I have used are the ones listed on this page.   <a href="https://www.axis.com/support/faq/FAQ30473" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.axis.com/support/faq/FAQ30473</a></p>
<p dir="auto">I don’t get any errors, just nothing pulling up.    I am considering trying the webview (<a href="https://github.com/Iketaki/MMM-WebView" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Iketaki/MMM-WebView</a>) or rtsp modules, but want to see if anyone has had success before I keep trying things to no avail.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17850/axis-camera-display</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 06:03:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17850.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Jun 2023 03:43:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Axis camera display on Sun, 25 Jun 2023 03:07:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a></p>
<p dir="auto">haven’t tried EmbedURL to run two streams yet, but WebView did work, so that’s a huge plus.</p>
]]></description><link>https://forum.magicmirror.builders/post/109910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109910</guid><dc:creator><![CDATA[alex2]]></dc:creator><pubDate>Sun, 25 Jun 2023 03:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to Axis camera display on Sun, 25 Jun 2023 03:06:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a><br />
Thank you.  running WebView and it appears to work.  Much appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/post/109909</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109909</guid><dc:creator><![CDATA[alex2]]></dc:creator><pubDate>Sun, 25 Jun 2023 03:06:41 GMT</pubDate></item><item><title><![CDATA[Reply to Axis camera display on Thu, 22 Jun 2023 14:18:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a><br />
Hi, if the stream works wit MMM-Webview you can use <a href="https://github.com/Tom-Hirschberger/MMM-EmbedURL" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-EmbedURL</a> to either embed one ore more streams. If you want to embed the streams at different positions the module supports multi instance by default.</p>
]]></description><link>https://forum.magicmirror.builders/post/109893</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109893</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Thu, 22 Jun 2023 14:18:06 GMT</pubDate></item><item><title><![CDATA[Reply to Axis camera display on Wed, 21 Jun 2023 23:27:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alex2" aria-label="Profile: alex2">@<bdi>alex2</bdi></a><br />
MMM-WebVeiw worked for one camera but I can not get more than one instance to run Like i do with MMM-RTSPStream but I had to go back to the OS before bullseye.</p>
]]></description><link>https://forum.magicmirror.builders/post/109890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109890</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Wed, 21 Jun 2023 23:27:56 GMT</pubDate></item><item><title><![CDATA[Reply to Axis camera display on Tue, 20 Jun 2023 13:44:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a><br />
So you’re saying this is related to the bullseye OS?   Odd as in the native pi browser my links work. Also, to clarify, I do embed the user:pass into the url.</p>
]]></description><link>https://forum.magicmirror.builders/post/109868</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109868</guid><dc:creator><![CDATA[alex2]]></dc:creator><pubDate>Tue, 20 Jun 2023 13:44:24 GMT</pubDate></item><item><title><![CDATA[Reply to Axis camera display on Tue, 20 Jun 2023 06:17:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alex2" aria-label="Profile: alex2">@<bdi>alex2</bdi></a> Sadly, with the loss of OMXplayer, camera support on the Pi is somewhat weak regardless of brand. I actually reverted to the previous OS, and use a command line OMXPlayer to bring up a camera on top of my window.</p>
]]></description><link>https://forum.magicmirror.builders/post/109867</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109867</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Tue, 20 Jun 2023 06:17:57 GMT</pubDate></item></channel></rss>
