<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wifi connectivity]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
Finally got round to mounting my magic mirror project on the wall, however I was wondering how owners/creators manage to ensure good connectivity to wifi? After all some of the custom frames are very chunky!<br />
(Mine isn’t particularly thick, but wifi now seems a bit fickle)</p>
]]></description><link>https://forum.magicmirror.builders/topic/17862/wifi-connectivity</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 15:59:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17862.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Jun 2023 19:00:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wifi connectivity on Sun, 02 Jul 2023 22:06:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/magmar" aria-label="Profile: magmar">@<bdi>magmar</bdi></a> There is a product out called Screen Beam that does the same thing but instead of using AC wall sockets it uses your existing coax cable as an ethernet cable.<br />
Those devices that send data over your AC copper wire have been out for a while but they’ve never really caught on.</p>
]]></description><link>https://forum.magicmirror.builders/post/110048</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110048</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Sun, 02 Jul 2023 22:06:46 GMT</pubDate></item><item><title><![CDATA[Reply to Wifi connectivity on Sun, 02 Jul 2023 07:52:38 GMT]]></title><description><![CDATA[<p dir="auto">I have my mirror in a tricky location for WiFi. The mirror does not even have an outlet nearby, so I have a long power-cable running all the way to where my router is. This is actually the closest outlet, but a huge brick wall blocks the WiFi-signal.</p>
<p dir="auto">To solve the internet connectivity issues I decided to buy a HomePlug. These allow you to send Internet signals through power cables. One HomePlug is connected to my router, and the other one is located in the plugs installed inside my mirror frame. The Raspberry Pi connects with the HomePlug through Ethernet.</p>
<p dir="auto">This works very well for me, but I have both HomePlugs installed on each side of one power cable. This essentially makes my power cable double as an Ethernet cable. They are supposed to work through different sockets in different rooms as well, but I haven’t tested this myself. In other words you should be able to place one HomePlug by the router, and the other in any socket close to the mirror. The wires in the wall should handle the rest. Good luck 😊</p>
]]></description><link>https://forum.magicmirror.builders/post/110033</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110033</guid><dc:creator><![CDATA[magmar]]></dc:creator><pubDate>Sun, 02 Jul 2023 07:52:38 GMT</pubDate></item><item><title><![CDATA[Reply to Wifi connectivity on Sun, 25 Jun 2023 19:38:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bicolorbore586" aria-label="Profile: bicolorbore586">@<bdi>bicolorbore586</bdi></a> I had an unstable wifi connection for one of my mirror systems.<br />
and the front security cameras.</p>
<p dir="auto">so I installed a mesh wifi. Google,  and put one of the stations at the closest outlet</p>
]]></description><link>https://forum.magicmirror.builders/post/109916</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109916</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 25 Jun 2023 19:38:13 GMT</pubDate></item></channel></rss>
