<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[how to rotate in windows?]]></title><description><![CDATA[<p dir="auto">hi im currently testing out MM using GIT CMD and opening my view in web browser local host. are there any way to rotate the view to vertical? all various article and guide seems to point towards a rpi rotation and not a windows version.</p>
<p dir="auto">help appreciated. thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17872/how-to-rotate-in-windows</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 22:59:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17872.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Jun 2023 07:18:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to how to rotate in windows? on Sat, 01 Jul 2023 11:31:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> see <a href="https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi?_=1688210939324">https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi?_=1688210939324</a></p>
]]></description><link>https://forum.magicmirror.builders/post/110006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110006</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 01 Jul 2023 11:31:26 GMT</pubDate></item><item><title><![CDATA[Reply to how to rotate in windows? on Fri, 30 Jun 2023 14:35:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> you might be able to find something using css… never tried that myself</p>
]]></description><link>https://forum.magicmirror.builders/post/109995</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109995</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 30 Jun 2023 14:35:35 GMT</pubDate></item><item><title><![CDATA[Reply to how to rotate in windows? on Fri, 30 Jun 2023 14:14:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  but if I weee to rotate my screen, my entire screen will be vertical, including my terminal which is not what I want. My main computer screen is where I work on the git cmd and I open up another browser in the same screen monitor.  Is there any way to just rotate the browser showing the mm?</p>
]]></description><link>https://forum.magicmirror.builders/post/109994</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109994</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 30 Jun 2023 14:14:38 GMT</pubDate></item><item><title><![CDATA[Reply to how to rotate in windows? on Fri, 30 Jun 2023 11:16:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> you use the os to change screen rotation.</p>
<p dir="auto"><a href="https://www.tomshardware.com/how-to/rotate-the-screen-on-windows-11" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.tomshardware.com/how-to/rotate-the-screen-on-windows-11</a></p>
<p dir="auto">Google search is your friend</p>
]]></description><link>https://forum.magicmirror.builders/post/109993</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109993</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 30 Jun 2023 11:16:20 GMT</pubDate></item></channel></rss>
