<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2.24.0 - Calendar Error. Could not fetch calendar]]></title><description><![CDATA[<p dir="auto">Is work before update to 2.24.0</p>
<p dir="auto">[02.07.2023 21:19.56.057] [ERROR] Calendar Error. Could not fetch calendar:  <a href="http://localhost:8080/modules/calendars/190C3BC4-1E8B-43Fkkk4-9EBE438.ics" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/modules/calendars/190C3BC4-1E8B-43Fkkk4-9EBE438.ics</a> FetchError: request to <a href="http://localhost:8080/modules/calendars/190C3BC4-1E8B-43F4E-89BE438.ics" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/modules/calendars/190C3BC4-1E8B-43F4E-89BE438.ics</a> failed, reason: connect ECONNREFUSED ::1:8080<br />
at ClientRequest. (/home/pi/MagicMirror/node_modules/node-fetch/lib/index.js:1505:11)<br />
at ClientRequest.emit (node:events:513:28)<br />
at Socket.socketErrorListener (node:_http_client:502:9)<br />
at Socket.emit (node:events:513:28)<br />
at emitErrorNT (node:internal/streams/destroy:151:8)<br />
at emitErrorCloseNT (node:internal/streams/destroy:116:3)<br />
at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {<br />
type: ‘system’,<br />
errno: ‘ECONNREFUSED’,<br />
code: ‘ECONNREFUSED’</p>
]]></description><link>https://forum.magicmirror.builders/topic/17877/2-24-0-calendar-error-could-not-fetch-calendar</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 18:42:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17877.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 02 Jul 2023 20:15:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2.24.0 - Calendar Error. Could not fetch calendar on Mon, 03 Jul 2023 17:08:17 GMT]]></title><description><![CDATA[<p dir="auto">The error is fix with : <a href="https://github.com/MichMich/MagicMirror/issues/3147" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/3147</a></p>
]]></description><link>https://forum.magicmirror.builders/post/110068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110068</guid><dc:creator><![CDATA[Assassins]]></dc:creator><pubDate>Mon, 03 Jul 2023 17:08:17 GMT</pubDate></item><item><title><![CDATA[Reply to 2.24.0 - Calendar Error. Could not fetch calendar on Mon, 03 Jul 2023 06:42:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> yes, is me  there 😉</p>
]]></description><link>https://forum.magicmirror.builders/post/110055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110055</guid><dc:creator><![CDATA[Assassins]]></dc:creator><pubDate>Mon, 03 Jul 2023 06:42:42 GMT</pubDate></item><item><title><![CDATA[Reply to 2.24.0 - Calendar Error. Could not fetch calendar on Sun, 02 Jul 2023 21:16:46 GMT]]></title><description><![CDATA[<p dir="auto">see <a href="https://github.com/MichMich/MagicMirror/issues/3147" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/3147</a></p>
]]></description><link>https://forum.magicmirror.builders/post/110045</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110045</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sun, 02 Jul 2023 21:16:46 GMT</pubDate></item><item><title><![CDATA[Reply to 2.24.0 - Calendar Error. Could not fetch calendar on Sun, 02 Jul 2023 20:28:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> The folder is there, and all the files</p>
]]></description><link>https://forum.magicmirror.builders/post/110044</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110044</guid><dc:creator><![CDATA[Assassins]]></dc:creator><pubDate>Sun, 02 Jul 2023 20:28:19 GMT</pubDate></item><item><title><![CDATA[Reply to 2.24.0 - Calendar Error. Could not fetch calendar on Sun, 02 Jul 2023 20:26:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/assassins" aria-label="Profile: Assassins">@<bdi>Assassins</bdi></a> if you didn’t make a special folder called calendars</p>
<p dir="auto">that might be an issue</p>
<p dir="auto">if you open a browser and go to that url what happens?</p>
]]></description><link>https://forum.magicmirror.builders/post/110043</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110043</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Jul 2023 20:26:39 GMT</pubDate></item></channel></rss>
