<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/6770/mmm-flightsabove-display-all-flights-in-the-sky-above-you">MMM-FlightsAbove - Display all flights in the sky above you</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/17900/i-m-getting-error-mesa-loader-failed-to-open-swrast-usr-lib-dri-swrast_dri-so-cannot-open-shared-object-file-permission-denied</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 16:07:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17900.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Jul 2023 01:54:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied on Mon, 17 Jul 2023 11:46:48 GMT]]></title><description><![CDATA[<p dir="auto">Excellent, It works now .  thanks a lot ,</p>
]]></description><link>https://forum.magicmirror.builders/post/110285</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110285</guid><dc:creator><![CDATA[vpanse]]></dc:creator><pubDate>Mon, 17 Jul 2023 11:46:48 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied on Mon, 17 Jul 2023 11:35:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vpanse" aria-label="Profile: vpanse">@<bdi>vpanse</bdi></a> said in <a href="/post/110280">I'm getting error -MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied</a>:</p>
<p dir="auto">Cannot find module ‘fetch-ponyfill’</p>
<p dir="auto">yes, unfortunately this module does not document in it’s package.json all the library dependencies it requires.</p>
<p dir="auto">so, for each one you have to do<br />
npm install  xxxxx<br />
where xxxxx is the missing library from the message above (in single quotes)</p>
<p dir="auto">the module hasn’t been updated since 2018, so no idea if it still works after all that</p>
<p dir="auto">your other post was marked as spam, which I cannot override</p>
]]></description><link>https://forum.magicmirror.builders/post/110283</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110283</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Jul 2023 11:35:06 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied on Mon, 17 Jul 2023 04:24:51 GMT]]></title><description><![CDATA[<p dir="auto">I did many changes suggested in Form but still little different issue</p>
<p dir="auto">[17.07.2023 05:21.57.786] [ERROR] (node:932) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch-ponyfill’<br />
Require stack:</p>
<ul>
<li>/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/lib/radar.js</li>
<li>/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/node_helper.js</li>
<li>/home/vinayak/MagicMirror/js/app.js</li>
<li>/home/vinayak/MagicMirror/js/electron.js</li>
<li>/home/vinayak/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js</li>
<li>at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)<br />
at n._resolveFilename (node:electron/js2c/browser_init:2:117469)<br />
at Module._resolveFilename (/home/vinayak/MagicMirror/node_modules/module-alias/index.js:49:29)<br />
at Module._load (node:internal/modules/cjs/loader:927:27)<br />
at f._load (node:electron/js2c/asar_bundle:2:13330)<br />
at Module.require (node:internal/modules/cjs/loader:1148:19)<br />
at require (node:internal/modules/cjs/helpers:110:18)<br />
at Object. (/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/lib/radar.js:36:17)<br />
at Module._compile (node:internal/modules/cjs/loader:1269:14)<br />
at Module._extensions…js (node:internal/modules/cjs/loader:1324:10)<br />
at Module.load (node:internal/modules/cjs/loader:1124:32)<br />
at Module._load (node:internal/modules/cjs/loader:965:12)<br />
at Object. (/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/node_helper.js:43:15)<br />
(Use <code>electron --trace-warnings ...</code> to show where the warning was created)<br />
[17.07.2023 05:21.57.787] [ERROR] (node:932) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a c&gt;</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/110280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110280</guid><dc:creator><![CDATA[vpanse]]></dc:creator><pubDate>Mon, 17 Jul 2023 04:24:51 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied on Sun, 16 Jul 2023 21:37:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">or forgot to run <code>npm install</code> in the module folder of MMM-FlightsAbove</p>
]]></description><link>https://forum.magicmirror.builders/post/110275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110275</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sun, 16 Jul 2023 21:37:24 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied on Sun, 16 Jul 2023 18:40:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vpanse" aria-label="Profile: vpanse">@<bdi>vpanse</bdi></a>  see<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
<pre><code>Cannot find module ‘pinkie-promise’
]]></description><link>https://forum.magicmirror.builders/post/110274</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110274</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 16 Jul 2023 18:40:46 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied on Sun, 16 Jul 2023 17:45:04 GMT]]></title><description><![CDATA[<p dir="auto">I already did try that , it does not work for modules<br />
<a href="https://github.com/mykle1/MMM-BMW-CC" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/mykle1/MMM-BMW-CC</a> and<br />
<a href="https://github.com/E3V3A/MMM-FlightsAbove" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/E3V3A/MMM-FlightsAbove</a>.<br />
Still getting error as below.<br />
require stack:</p>
<ul>
<li>/home/vinayak/MagicMirror/modules/MMM-BMW-CC/node_helper.js</li>
at Object. (/home/vinayak/MagicMirror/modules/MMM-BMW-CC/node_helper.js:8:17)<br />
at loadModule (/home/vinayak/MagicMirror/js/app.js:180:19)<br />
[16.07.2023 18:40.43.267] [ERROR] (node:989) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin&gt;MESA-LOADER: failed to retrieve device information<br />
MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)<br />
failed to load driver: kms_swrast<br />
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)<br />
failed to load swrast driver</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/110273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110273</guid><dc:creator><![CDATA[vpanse]]></dc:creator><pubDate>Sun, 16 Jul 2023 17:45:04 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied on Sat, 15 Jul 2023 11:16:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vpanse" aria-label="Profile: vpanse">@<bdi>vpanse</bdi></a> see the post directly above your</p>
]]></description><link>https://forum.magicmirror.builders/post/110251</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110251</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Jul 2023 11:16:29 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied on Sat, 15 Jul 2023 02:53:51 GMT]]></title><description><![CDATA[<h1>I’m trying to run <a href="https://github.com/E3V3A/MMM-FlightsAbove" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/E3V3A/MMM-FlightsAbove</a><br />
but getting following errors</h1>
<p dir="auto">GMESA-LOADER: failed to retrieve device information<br />
MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib&gt;failed to load driver: kms_swrast<br />
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-lin&gt;failed to load swrast driver<br />
/home/vinayak/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT<br />
[10.07.2023 02:06.43.861] [ERROR] (node:7189) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘pinkie-promise’<br />
Require stack:</p>
<ul>
at n._resolveFilename (node:electron/js2c/browser_init:2:117457)<br />
at Object. (/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/lib/radar.js:36:53)<br />
[10.07.2023 02:06.43.861] [ERROR] (node:7189) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by thr&gt;MESA-LOADER: failed to retrieve device information<br />
MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib&gt;<br />
=================================================================</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/110250</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110250</guid><dc:creator><![CDATA[vpanse]]></dc:creator><pubDate>Sat, 15 Jul 2023 02:53:51 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m getting error -MESA-LOADER: failed to open swrast: &#x2F;usr&#x2F;lib&#x2F;dri&#x2F;swrast_dri.so: cannot open shared object file: Permission denied on Mon, 10 Jul 2023 11:01:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vpanse" aria-label="Profile: vpanse">@<bdi>vpanse</bdi></a>  yes, it’s a display driver config issue on the base is.  no good fix</p>
<p dir="auto">but you can suppress the messages</p>
<p dir="auto">where you do npm start</p>
<p dir="auto">add</p>
<p dir="auto">export ELECTRON_DISABLE_GPU=1</p>
<p dir="auto">before the npm start line</p>
<p dir="auto">if you use my install scripts, the file to modify is<br />
~/MagicMirror/installers/mm.sh</p>
]]></description><link>https://forum.magicmirror.builders/post/110198</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110198</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Jul 2023 11:01:00 GMT</pubDate></item></channel></rss>
