<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarEXT2 mulitple time zones]]></title><description><![CDATA[<p dir="auto">I’ve been runing the EXT2 calendar for sometime now… I have 2 google calendars and one outlook calendar that it pulls data from to displays on my MM. The issue i am having is when meeting are set in a regions outside of mine it use that person region… Say India time and its 12 hours different from what i am on… Do you know how to change it to use only local time.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17905/mmm-calendarext2-mulitple-time-zones</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 02:02:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17905.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Jul 2023 16:52:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarEXT2 mulitple time zones on Fri, 14 Jul 2023 05:16:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pastormingle" aria-label="Profile: pastormingle">@<bdi>pastormingle</bdi></a><br />
“forceLocalTZ” option in the calendar might be.<br />
<a href="https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/main/docs/Configuration/Calendar.md#default-values-of-calendar" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/main/docs/Configuration/Calendar.md#default-values-of-calendar</a><br />
But not sure it would fix your issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/110242</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110242</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Fri, 14 Jul 2023 05:16:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarEXT2 mulitple time zones on Thu, 13 Jul 2023 22:36:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> only the data parser.</p>
<p dir="auto">he does all the magic</p>
]]></description><link>https://forum.magicmirror.builders/post/110238</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110238</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Jul 2023 22:36:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarEXT2 mulitple time zones on Thu, 13 Jul 2023 22:20:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> You maintain the calendar module it’s reading from, no?</p>
]]></description><link>https://forum.magicmirror.builders/post/110237</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110237</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 13 Jul 2023 22:20:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarEXT2 mulitple time zones on Thu, 13 Jul 2023 21:38:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> I am not a maintainer of any of <a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> beautiful modules</p>
]]></description><link>https://forum.magicmirror.builders/post/110233</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110233</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Jul 2023 21:38:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarEXT2 mulitple time zones on Thu, 13 Jul 2023 17:31:01 GMT]]></title><description><![CDATA[<p dir="auto">I don’t remember if there’s an option for that in the abandoned EXT2, I don’t believe so.</p>
<p dir="auto">However, if you’d switch to EXT3 and/or EXT3Agenda as appropriate, you’d get full support from MMRize and sdetweil, who are the maintainers of the two modules used (EXT3/EXT3Agenda and calendar). Bonus, it’s a much easier config to do the same things.</p>
]]></description><link>https://forum.magicmirror.builders/post/110232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110232</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 13 Jul 2023 17:31:01 GMT</pubDate></item></channel></rss>
