<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there a Difference between these ???]]></title><description><![CDATA[<p dir="auto">Does config.js see a difference between these?<br />
{<br />
ipAddress: “192.168.178.31”,<br />
icon: “database”,<br />
colorStateOnline: “green”,<br />
colorStateOffline: “red”,<br />
},</p>
<p dir="auto">{  ipAddress: “192.168.178.31”,  name: “QNAP1”,  icon: database",   colorStateOnline: “green”,  colorStateOffline: “red”  },</p>
<p dir="auto">I only ask because I can not get the color State’s to work.</p>
]]></description><link>https://forum.magicmirror.builders/topic/17918/is-there-a-difference-between-these</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 08:29:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17918.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Jul 2023 23:01:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there a Difference between these ??? on Sun, 23 Jul 2023 12:19:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/experimentor" aria-label="Profile: ExperiMentor">@<bdi>ExperiMentor</bdi></a> the extra comma is not an error…</p>
]]></description><link>https://forum.magicmirror.builders/post/110346</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110346</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 23 Jul 2023 12:19:38 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Sun, 23 Jul 2023 06:20:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> Both versions have an error (different errors).</p>
<ul>
<li>
<p dir="auto">list itemThe single line example has " (quote marks) missing in “database” that you need to add.</p>
</li>
<li>
<p dir="auto">list itemThe multi-line example has an extra , (comma) after “red” that you need to delete.</p>
</li>
</ul>
<p dir="auto">This is like programming: precise details matter and stop things working if you get them wrong</p>
]]></description><link>https://forum.magicmirror.builders/post/110345</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110345</guid><dc:creator><![CDATA[ExperiMentor]]></dc:creator><pubDate>Sun, 23 Jul 2023 06:20:06 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Sun, 23 Jul 2023 04:01:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> the 3backtics of the code block must be on a separate line. start and end</p>
]]></description><link>https://forum.magicmirror.builders/post/110337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110337</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 23 Jul 2023 04:01:25 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Sun, 23 Jul 2023 02:09:31 GMT]]></title><description><![CDATA[<p dir="auto">Ok, I get it I did not post it correctly.<br />
What I am trying to get at does it matter if the line is one line of text or does it need to be several lines to make it read correctly in MM?</p>
]]></description><link>https://forum.magicmirror.builders/post/110334</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110334</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Sun, 23 Jul 2023 02:09:31 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Fri, 21 Jul 2023 11:33:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> yes, that was my point</p>
]]></description><link>https://forum.magicmirror.builders/post/110325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110325</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Jul 2023 11:33:55 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Fri, 21 Jul 2023 04:27:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> oh, I C&amp;P’d that. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/110324</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110324</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Fri, 21 Jul 2023 04:27:48 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Fri, 21 Jul 2023 00:19:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> your post has the bad quotes<br />
that’s all I was saying, even tho in code block</p>
]]></description><link>https://forum.magicmirror.builders/post/110320</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110320</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 21 Jul 2023 00:19:14 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Thu, 20 Jul 2023 21:11:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> (that wasn’t a copy. It was escaped. backslash ` )</p>
]]></description><link>https://forum.magicmirror.builders/post/110319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110319</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 20 Jul 2023 21:11:32 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Thu, 20 Jul 2023 20:11:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> however</p>
<p dir="auto">if u copy/paste from outside a code block backtics</p>
<p dir="auto">the bad quotes(curved/slanted) are copied, as in your example</p>
<p dir="auto">and will not be corrected, and will cause problems in config.js</p>
]]></description><link>https://forum.magicmirror.builders/post/110318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110318</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Jul 2023 20:11:46 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Thu, 20 Jul 2023 19:25:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> To expand on <a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> comment - To post code, please use the button<br />
that looks like this: <img src="/assets/uploads/files/1689881059940-1967f487-8ada-4dad-af09-500c3dfb3cb4-image.png" alt="1967f487-8ada-4dad-af09-500c3dfb3cb4-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">that button puts this ``` into your text, allowing you to get code posted like this to make it readable:</p>
<pre><code>{
icon: “database”,
]]></description><link>https://forum.magicmirror.builders/post/110316</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110316</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 20 Jul 2023 19:25:46 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a Difference between these ??? on Thu, 20 Jul 2023 03:44:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> Hi,</p>
<p dir="auto">please use the code ticks to post code.</p>
<p dir="auto">Yes there is a difference, you missed a " before database in the second one.</p>
]]></description><link>https://forum.magicmirror.builders/post/110313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110313</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Thu, 20 Jul 2023 03:44:31 GMT</pubDate></item></channel></rss>
