<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change Res to 2560 x 1080 ?]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/1794/change-res-to-2560-x-1080</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 08:06:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1794.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 18 Feb 2017 14:38:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Change Res to 2560 x 1080 ? on Sun, 19 Feb 2017 12:59:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnnyboy" aria-label="Profile: johnnyboy">@<bdi>johnnyboy</bdi></a><br />
In fact the # marks single lines as a comment and as such the statement on this line will not be interpreted.<br />
Good you found it in the end!</p>
]]></description><link>https://forum.magicmirror.builders/post/14982</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14982</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Sun, 19 Feb 2017 12:59:21 GMT</pubDate></item><item><title><![CDATA[Reply to Change Res to 2560 x 1080 ? on Sat, 18 Feb 2017 14:53:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnnyboy" aria-label="Profile: johnnyboy">@<bdi>johnnyboy</bdi></a> Did you try this (a bit further down in the thread)? <a href="https://www.raspberrypi.org/forums/viewtopic.php?f=29&amp;t=24679" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/forums/viewtopic.php?f=29&amp;t=24679</a></p>
]]></description><link>https://forum.magicmirror.builders/post/14936</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14936</guid><dc:creator><![CDATA[RedNax]]></dc:creator><pubDate>Sat, 18 Feb 2017 14:53:39 GMT</pubDate></item></channel></rss>
