<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Make your Mirror touch]]></title><description><![CDATA[<p dir="auto">Do you think its possible to install a touch sensor to turn on the mirror?</p>
]]></description><link>https://forum.magicmirror.builders/topic/17963/make-your-mirror-touch</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 20:12:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17963.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Aug 2023 19:08:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Make your Mirror touch on Mon, 21 Aug 2023 06:40:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/max-0" aria-label="Profile: Max-0">@<bdi>Max-0</bdi></a></p>
<ul>
<li>What you mean is “powering on a Raspberry PI by touch without any additional device”, NO.</li>
<li>What you mean is “powering on a Display(previously powered off) by touch without any additional device”, Possible or not by the kind of the touch-sensor. Built-In touch sensor in a display would not be possible, but an external touch-frame connected to Raspberry Pi could be used to give signals  for that control to Raspberry Pi.</li>
<li>What you mean is “Waking on a Display(previously slept/hibernated) by touch without any additional device”, YES. But your display('s control board) should support that kind of feature.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/110645</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110645</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 21 Aug 2023 06:40:02 GMT</pubDate></item><item><title><![CDATA[Reply to Make your Mirror touch on Mon, 21 Aug 2023 00:12:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/max-0" aria-label="Profile: Max-0">@<bdi>Max-0</bdi></a> yes it’s possible. don’t know if anyone has done that</p>
]]></description><link>https://forum.magicmirror.builders/post/110644</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110644</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Aug 2023 00:12:07 GMT</pubDate></item></channel></rss>
