<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-UKTide - error on load]]></title><description><![CDATA[<p dir="auto">New to Magic Mirrors, so feeling things out at this stage.</p>
<p dir="auto">After installing <a href="https://github.com/Captsi/MMM-UKTide" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Captsi/MMM-UKTide</a> on a fresh RPi 4 Magic Mirror setup I encounter the following error, which prevents the mirror from loading (whereas if I remove this module from the config.js the mirror loads just fine.</p>
<p dir="auto">Any suggestions?</p>
<pre><code>pi@minecraft:~/MagicMirror $ npm start
&gt;
&gt; &gt; magicmirror@2.24.0 start
&gt; &gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
&gt;
&gt; [27.08.2023 16:24.34.781] [LOG]   Starting MagicMirror: v2.24.0
&gt; [27.08.2023 16:24.34.789] [LOG]   Loading config ...
&gt; [27.08.2023 16:24.34.792] [DEBUG] config template file not exists, no envsubst
&gt; [27.08.2023 16:24.34.798] [LOG]   Loading module helpers ...
&gt; [27.08.2023 16:24.34.800] [LOG]   No helper found for module: alert.
&gt; [27.08.2023 16:24.34.824] [LOG]   Initializing new module helper ...
&gt; [27.08.2023 16:24.34.825] [LOG]   Module helper loaded: updatenotification
&gt; [27.08.2023 16:24.35.142] [LOG]   Initializing new module helper ...
&gt; [27.08.2023 16:24.35.143] [LOG]   Module helper loaded: calendar
&gt; [27.08.2023 16:24.35.145] [LOG]   No helper found for module: clock.
&gt; [27.08.2023 16:24.35.151] [ERROR] (node:6501) UnhandledPromiseRejectionWarning: Error: Cannot find module 'request'
&gt; Require stack:
&gt; - /home/pi/MagicMirror/modules/MMM-UKTide/node_helper.js
&gt; - /home/pi/MagicMirror/js/app.js
&gt; - /home/pi/MagicMirror/js/electron.js
&gt; - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
&gt; -
&gt;     at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)
&gt;     at n._resolveFilename (node:electron/js2c/browser_init:2:117457)
&gt;     at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
&gt;     at Module._load (node:internal/modules/cjs/loader:927:27)
&gt;     at f._load (node:electron/js2c/asar_bundle:2:13330)
&gt;     at Module.require (node:internal/modules/cjs/loader:1148:19)
&gt;     at require (node:internal/modules/cjs/helpers:110:18)
&gt;     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-UKTide/node_helper.js:12:15)
&gt;     at Module._compile (node:internal/modules/cjs/loader:1269:14)
&gt;     at Module._extensions..js (node:internal/modules/cjs/loader:1324:10)
&gt;     at Module.load (node:internal/modules/cjs/loader:1124:32)
&gt;     at Module._load (node:internal/modules/cjs/loader:965:12)
&gt;     at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
&gt; (Use `electron --trace-warnings ...` to show where the warning was created)
&gt; [27.08.2023 16:24.35.151] [ERROR] (node:6501) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
&gt;
]]></description><link>https://forum.magicmirror.builders/topic/17975/mmm-uktide-error-on-load</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 11:38:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17975.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Aug 2023 15:29:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-UKTide - error on load on Sun, 27 Aug 2023 16:32:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/olitills" aria-label="Profile: olitills">@<bdi>olitills</bdi></a> said in <a href="/post/110749">MMM-UKTide - error on load</a>:</p>
<p dir="auto">) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’</p>
<p dir="auto">see<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/110750</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110750</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 27 Aug 2023 16:32:30 GMT</pubDate></item></channel></rss>
