<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Notion]]></title><description><![CDATA[<p dir="auto">I´ve downloaded the MMM-Notion Module and when i start the mirror it just says: Could not find database with ID: (my id). Make sure the relevant pages and databases are shared with your integration. So here are my question: Do I have to add the integration to the page and the database? (the id is correct and the secret key as well). And in the config it says under databases.layout.properties :“Required List of Properties, which will displayed on the view. Please use the exact name like in Notion. If leaving empty, there will be no properties visible” and i don´t know what that means</p>
]]></description><link>https://forum.magicmirror.builders/topic/17979/mmm-notion</link><generator>RSS for Node</generator><lastBuildDate>Fri, 05 Jun 2026 22:46:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17979.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Aug 2023 15:59:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Notion on Mon, 28 Aug 2023 22:26:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/max-0" aria-label="Profile: Max-0">@<bdi>Max-0</bdi></a> I think you should post an issue on the module GitHub page to engage the  module author</p>
]]></description><link>https://forum.magicmirror.builders/post/110776</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110776</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Aug 2023 22:26:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Notion on Mon, 28 Aug 2023 20:13:37 GMT]]></title><description><![CDATA[<p dir="auto">now i´ve tried different database ids and now, instead of an the error, there is an error showing up for only half a second when the module refreshes itself every minute which says: TypeError:Cannot read properties of undefined (reading ‘type’)</p>
]]></description><link>https://forum.magicmirror.builders/post/110773</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110773</guid><dc:creator><![CDATA[Max 0]]></dc:creator><pubDate>Mon, 28 Aug 2023 20:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Notion on Mon, 28 Aug 2023 18:33:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> yes but when i create an integration i can´t select the capibilities</p>
]]></description><link>https://forum.magicmirror.builders/post/110774</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110774</guid><dc:creator><![CDATA[Max 0]]></dc:creator><pubDate>Mon, 28 Aug 2023 18:33:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Notion on Mon, 28 Aug 2023 16:33:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/max-0" aria-label="Profile: Max-0">@<bdi>Max-0</bdi></a> did you do all the steps in the how to use section of the doc ?</p>
<p dir="auto"><a href="https://github.com/choffmann/MMM-Notion#how-to-use" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/choffmann/MMM-Notion#how-to-use</a></p>
]]></description><link>https://forum.magicmirror.builders/post/110769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110769</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Aug 2023 16:33:06 GMT</pubDate></item></channel></rss>
