<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[rotating the screen doesn't work]]></title><description><![CDATA[<p dir="auto">Hey there,</p>
<p dir="auto">it’s been quite a while since I installed my MM.<br />
Now there was the time for an upgrade of the monitor and I decided to do it with a freshly installed pi to start fresh. That worked fine and I got it running very soon. Only problem is the rotation of the screen:<br />
As far as I know the old methom with boot/config.txt doesn’t work anymore, but I have to use xrandr.<br />
I can use <code> DISPLAY=:0 xrandr --output HDMI-1 --rotate right</code> in console to rotate, but when using <code>@xrandr --output HDMI-1 --rotate right</code> in <code>/etc/xdg/lxsession/LXDE-pi/autostart</code> it has no effect.<br />
What is to now correct way of doing it?</p>
<p dir="auto">Thanks a lot in advance,<br />
Anduril</p>
<pre><code class="language-~">  Operating System: Raspbian GNU/Linux 11 (bullseye)
            Kernel: Linux 6.1.21-v8+
      Architecture: arm64
]]></description><link>https://forum.magicmirror.builders/topic/17998/rotating-the-screen-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 04:33:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/17998.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Sep 2023 13:19:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to rotating the screen doesn't work on Sun, 17 Sep 2023 18:36:44 GMT]]></title><description><![CDATA[<p dir="auto">well the problem was I think about privileges to issue the xrandr command from a shell. I got it worked out with <code>xhost +</code> and it works fine now. Thanks a lot for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/110950</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110950</guid><dc:creator><![CDATA[AnduriI]]></dc:creator><pubDate>Sun, 17 Sep 2023 18:36:44 GMT</pubDate></item><item><title><![CDATA[Reply to rotating the screen doesn't work on Fri, 15 Sep 2023 18:50:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andurii" aria-label="Profile: AnduriI">@<bdi>AnduriI</bdi></a> is your <code>@xrandr</code> a copy/paste that @ symbol should not be there I don’t think</p>
<p dir="auto">You might want to read this which comes from the official Raspberry Pi site.<br />
Screenshot is of the Rotating your Screen function from my MM</p>
<p dir="auto"><a href="https://www.raspberrypi.com/documentation/computers/configuration.html#rotating-your-display" target="_blank" rel="noopener noreferrer nofollow ugc">Rotating your Display</a></p>
<p dir="auto"><img src="/assets/uploads/files/1694803703552-screenshot-2023-09-15-144032.png" alt="Screenshot 2023-09-15 144032.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/110928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110928</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Fri, 15 Sep 2023 18:50:46 GMT</pubDate></item><item><title><![CDATA[Reply to rotating the screen doesn't work on Wed, 13 Sep 2023 19:22:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andurii" aria-label="Profile: AnduriI">@<bdi>AnduriI</bdi></a></p>
<p dir="auto">you can change this in the raspian os gui somewhere in the menu.</p>
<p dir="auto">See also <a href="https://forum.magicmirror.builders/topic/16795/rpi-3b-with-bullseye-can-t-rotate-screen/13">https://forum.magicmirror.builders/topic/16795/rpi-3b-with-bullseye-can-t-rotate-screen/13</a></p>
]]></description><link>https://forum.magicmirror.builders/post/110900</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110900</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 13 Sep 2023 19:22:11 GMT</pubDate></item></channel></rss>
