<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need help for tests suite]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rejas" aria-label="Profile: rejas">@<bdi>rejas</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
I’m trying to do a new test file</p>
<p dir="auto">As I said before, I’m not very good with the tests suite<br />
so I’m trying to understand ;)</p>
<p dir="auto">How can I execute it directly without invoking all tests?</p>
<p dir="auto">Thanks for your advice guys</p>
]]></description><link>https://forum.magicmirror.builders/topic/18015/need-help-for-tests-suite</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 16:55:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18015.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 Sep 2023 10:34:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need help for tests suite on Sat, 23 Sep 2023 19:05:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> don’t worry, I have a real job too ;)<br />
I will just make a PR (draft),</p>
<p dir="auto">After, we will see if we push it or not<br />
Sincerely, for me, this PR will not really important, it is mainly to understand how it works<br />
I will mention you in the PR to give me your opinion (that’s just what matters to me)</p>
]]></description><link>https://forum.magicmirror.builders/post/111064</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111064</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sat, 23 Sep 2023 19:05:26 GMT</pubDate></item><item><title><![CDATA[Reply to Need help for tests suite on Sat, 23 Sep 2023 18:54:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a></p>
<p dir="auto">sure, I will try it … but since I have a real job, I will give my answers in the evening …</p>
]]></description><link>https://forum.magicmirror.builders/post/111063</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111063</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 23 Sep 2023 18:54:55 GMT</pubDate></item><item><title><![CDATA[Reply to Need help for tests suite on Sat, 23 Sep 2023 18:51:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> in some (few) days, i will try to apply some suite tests for <code>AnimateIn</code> / <code>AnimateOut</code> feature</p>
<p dir="auto">Can you supervise me and advise me if necessary?</p>
<p dir="auto">I will comment as much as possible so that you understand what I want to do</p>
<p dir="auto">I really want to understand this kind of test because it’s completely new for me :p</p>
]]></description><link>https://forum.magicmirror.builders/post/111062</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111062</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sat, 23 Sep 2023 18:51:37 GMT</pubDate></item><item><title><![CDATA[Reply to Need help for tests suite on Sat, 23 Sep 2023 15:55:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> Thx ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/111055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111055</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sat, 23 Sep 2023 15:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to Need help for tests suite on Sat, 23 Sep 2023 13:46:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a></p>
<p dir="auto">from mm folder <code>npx jest tests/...&lt;filename&gt;</code></p>
]]></description><link>https://forum.magicmirror.builders/post/111044</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111044</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 23 Sep 2023 13:46:28 GMT</pubDate></item></channel></rss>
