<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[new release 2.25 requires node 18 or higher.]]></title><description><![CDATA[<p dir="auto">if you use my upgrade script, it will upgrade to<br />
node 20 and npm  10.</p>
<p dir="auto">if not, you have to manually upgrade node &amp; npm  before doing the npm install on the mm upgrade</p>
<p dir="auto">node 18 drops long term support(lts) at the end of October</p>
]]></description><link>https://forum.magicmirror.builders/topic/18030/new-release-2-25-requires-node-18-or-higher</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 11:13:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18030.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Oct 2023 21:49:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to new release 2.25 requires node 18 or higher. on Mon, 02 Oct 2023 18:55:57 GMT]]></title><description><![CDATA[<p dir="auto">note I am advising falling back to node 18 on buster,</p>
<p dir="auto">the install and upgrade scripts have been fixed to handle node upgrade/install correctly</p>
<p dir="auto">please advise your results if there are issues in new forum posts.</p>
<p dir="auto">this topic is locked.</p>
]]></description><link>https://forum.magicmirror.builders/post/111204</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111204</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 Oct 2023 18:55:57 GMT</pubDate></item></channel></rss>
