<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Upgrade errors?]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> – Apparently, script upgrade broke node on my system - can you help me figure how how to fix?</p>
<p dir="auto">Thanks!</p>
<p dir="auto">On run:</p>
<pre><code>node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
<p dir="auto">upgrade output:</p>
<pre><code>doing test run = false
update log will be in /home/bkey1970/MagicMirror/installers/upgrade.log
Check current Node installation ...
Node currently installed. Checking version number.
Minimum Node version: v20.8.0
Installed Node version: v16.20.2
Node should be upgraded.
Installing Node.js ...
gpg: WARNING: unsafe ownership on homedir '/home/bkey1970/.gnupg'
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be upgraded:
  nodejs
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 27.0 MB of archives.
After this operation, 63.7 MB of additional disk space will be used.
Get:1 https://deb.nodesource.com/node_20.x buster/main armhf nodejs armhf 20.5.1-deb-1nodesource1 [27.0 MB]
Fetched 27.0 MB in 7s (4,153 kB/s)
apt-listchanges: Reading changelogs...
(Reading database ... 103684 files and directories currently installed.)
Preparing to unpack .../nodejs_20.5.1-deb-1nodesource1_armhf.deb ...
Unpacking nodejs (20.5.1-deb-1nodesource1) over (16.20.2-deb-1nodesource1) ...
Setting up nodejs (20.5.1-deb-1nodesource1) ...
Processing triggers for man-db (2.8.5-2) ...
node version is node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
Node.js installation Done! version=
Check current NPM installation ...
NPM currently installed. Checking version number.
Minimum npm version: V10.1.0
Installed npm version: V
npm should be upgraded.
Installing npm ...
E: Unable to correct problems, you have held broken packages.
npm installation Done! version=V
apply: line 318: [: -ge: unary operator expected
saving custom.css
upgrading from version 2.24.0 to 2.25.0
fetching latest revisions
updating MagicMirror runtime, please wait
apply: line 558: [: -ge: unary operator expected
Checking for modules with removed libraries
no modules found needing npm refresh
restoring custom.css
]]></description><link>https://forum.magicmirror.builders/topic/18031/upgrade-errors</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 17:17:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18031.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Oct 2023 23:24:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Upgrade errors? on Wed, 04 Oct 2023 04:45:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> said in <a href="/post/111268">Upgrade errors?</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> turns out there was an update to MMM-Wallpaper that missed due to all the bugs in upgrading. 😉</p>
<p dir="auto">…just in case this might be interesting for anyone: I had the same problems on my Raspberry Pi 4 Model B (Rev 1.2) with buster (armv71).</p>
<ul>
<li>node 20 gave me the `GLIBCXX_3.4.26’ not found (required by node) error</li>
<li>I had the “failed to load swrast driver”</li>
</ul>
<p dir="auto">I checked my modules, and the solution for my MM was (thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> here):</p>
<ul>
<li>installing node 18 (I did it manually like mentioned <a href="https://github.com/nodesource/distributions" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>)</li>
<li>removing “<a href="https://github.com/LukeSkywalker92/MMM-DWD-WarnWeather" target="_blank" rel="noopener noreferrer nofollow ugc">DWD Warn Weather</a>” (which caused the swrast error) from config.js</li>
</ul>
<p dir="auto">Now MagicMirror v2.25.0 is up and running! :beaming_face_with_smiling_eyes:</p>
<p dir="auto">Thank you for all your effort and your tireless support!<br />
May the code be with you.<br />
-kai</p>
]]></description><link>https://forum.magicmirror.builders/post/111299</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111299</guid><dc:creator><![CDATA[kai]]></dc:creator><pubDate>Wed, 04 Oct 2023 04:45:44 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Wed, 25 Oct 2023 20:32:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> - Thanks for the help here and offline. My problem is solved, and for the sake of others following is the resolution.</p>
<p dir="auto"><strong>Problem</strong>: MagicMirror install script outputs node.js errors on new RaspbianOS install running under VirtualBox.</p>
<p dir="auto"><strong>Diagnosis</strong> [by sdetweil]: “so, the problem is that the intel raspian is a hybrid, x86_64 kernel with a i386 user runtime.<br />
and they stopped making a nodejs for i386 after node 12”</p>
<p dir="auto"><strong>Solution</strong>: Rebuilt the virtual machine using Ubuntu instead of RaspbianOS. [I’m sure any Debian or other Linux distribution would work just fine…]</p>
<p dir="auto">Thanks again - I can now use this as a dev machine and spare myself the risks associated with fiddling with the production machine!</p>
]]></description><link>https://forum.magicmirror.builders/post/112072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112072</guid><dc:creator><![CDATA[JohnGalt]]></dc:creator><pubDate>Wed, 25 Oct 2023 20:32:38 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 24 Oct 2023 23:29:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  - Thanks, the log file is on its way to you…</p>
]]></description><link>https://forum.magicmirror.builders/post/112054</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112054</guid><dc:creator><![CDATA[JohnGalt]]></dc:creator><pubDate>Tue, 24 Oct 2023 23:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 24 Oct 2023 23:05:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johngalt" aria-label="Profile: JohnGalt">@<bdi>JohnGalt</bdi></a> can u send me the install.log file…</p>
<p dir="auto">I have a vm of raspi x86 as well…</p>
<p dir="auto">this same userid at gmail… thx</p>
]]></description><link>https://forum.magicmirror.builders/post/112053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112053</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 24 Oct 2023 23:05:31 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 24 Oct 2023 23:01:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> - I’m not sure this the correct topic for my error, so if not we can move it - but I am having the issues described above, but on an initial install [as opposed to an upgrade]. This is on a freshly created VirtualBox VM using the current RaspbianOS version of Debian, using Sam’s install script.</p>
<p dir="auto">After a long series of lines indicating it was setting up various node packages, the install.log file ends with a message that node failed to install:</p>
<pre><code>added 1 package, and audited 2 packages in 1s
found 0 vulnerabilities
installing on bullseye
[96minstalling correct version of node and npm, please wait[90m
  installing : node-v20.8.0
       mkdir : /usr/local/n/versions/node/20.8.0
       fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-x64.tar.xz
     copying : node/20.8.0
   installed :  (with npm )
Note: the node command changed location and the old location may be remembered in your current shell.
         old : /usr/bin/node
         new : /usr/local/bin/node
If "node --version" shows the old version then start a new shell, or reset the location hash with:
hash -r  (for bash, zsh, ash, dash, and ksh)
rehash   (for csh and tcsh)
node failed to install, exiting
<p dir="auto">Thoughts??</p>
]]></description><link>https://forum.magicmirror.builders/post/112052</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112052</guid><dc:creator><![CDATA[JohnGalt]]></dc:creator><pubDate>Tue, 24 Oct 2023 23:01:50 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Wed, 04 Oct 2023 04:45:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> said in <a href="/post/111268">Upgrade errors?</a>:</p>
<ul>
</ul>
<ul>
</ul>
-kai</p>
]]></description><link>https://forum.magicmirror.builders/post/111299</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111299</guid><dc:creator><![CDATA[kai]]></dc:creator><pubDate>Wed, 04 Oct 2023 04:45:44 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Wed, 04 Oct 2023 00:29:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> My scripts don’t depend on node or anything else they’re all bash scripts. So if you haven’t deleted anything you can still run the back up there and be able to restore it later</p>
]]></description><link>https://forum.magicmirror.builders/post/111298</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111298</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 04 Oct 2023 00:29:39 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 15:53:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> yes I saw that too</p>
]]></description><link>https://forum.magicmirror.builders/post/111269</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111269</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Oct 2023 15:53:31 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 15:52:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> turns out there was an update to MMM-Wallpaper that missed due to all the bugs in upgrading. 😉</p>
]]></description><link>https://forum.magicmirror.builders/post/111268</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111268</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Tue, 03 Oct 2023 15:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 15:09:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I use your backup scripts on my main mirror. My dev machine I did not backup. Will teach me for next time. :crying_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/111264</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111264</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Tue, 03 Oct 2023 15:09:56 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 15:08:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a>  always backup</p>
<p dir="auto">I have one that makes a small image<br />
<a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
]]></description><link>https://forum.magicmirror.builders/post/111262</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111262</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Oct 2023 15:08:43 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 15:06:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks Sam. A bunch of missing libs but all working again.</p>
<p dir="auto">Now to add my modules I had running on the dev machine. The joy. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/111260</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111260</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Tue, 03 Oct 2023 15:06:01 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 14:53:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> maybe<br />
<a href="https://github.com/snobu/destreamer/issues/216" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/snobu/destreamer/issues/216</a></p>
]]></description><link>https://forum.magicmirror.builders/post/111256</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111256</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Oct 2023 14:53:15 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 14:52:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Can you help me fix my WSL? I seem to be having and issue with electron and a missing lib. I have emailed you the install.log as well.</p>
<p dir="auto"><img src="/assets/uploads/files/1696344736453-d54de45a-bb9c-4c18-9751-9e4b2e73e80b-image.png" alt="d54de45a-bb9c-4c18-9751-9e4b2e73e80b-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/111255</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111255</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Tue, 03 Oct 2023 14:52:21 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 13:56:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berksmash1984" aria-label="Profile: BerkSmash1984">@<bdi>BerkSmash1984</bdi></a> I see 64bit…   let me look</p>
<p dir="auto">seems the process is different there… darn</p>
]]></description><link>https://forum.magicmirror.builders/post/111244</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111244</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Oct 2023 13:56:03 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 13:07:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> said in <a href="/post/111221">Upgrade errors?</a>:</p>
<p dir="auto">Cannot find module ‘fetch’</p>
<p dir="auto">we removed this in 2.25</p>
<p dir="auto">see<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
<p dir="auto">or, you can comment out the require in the module node_helper.js</p>
<p dir="auto">as fetch is built in in 2.18 and up</p>
]]></description><link>https://forum.magicmirror.builders/post/111237</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111237</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Oct 2023 13:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 12:59:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I tried to run the upgrade script on my RPI 4B running Bullseye and it hosed my MM. During the install, I see this:</p>
<p dir="auto"><img src="/assets/uploads/files/1696337786429-76423370-fda2-4559-a897-b4f743221236-image.png" alt="76423370-fda2-4559-a897-b4f743221236-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">It appears to have removed/partially remove npm altogether:</p>
<p dir="auto"><img src="/assets/uploads/files/1696337851268-5e3b02c7-4a6f-443f-aeb3-055cf0851db6-image.png" alt="5e3b02c7-4a6f-443f-aeb3-055cf0851db6-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Any thoughts?</p>
]]></description><link>https://forum.magicmirror.builders/post/111235</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111235</guid><dc:creator><![CDATA[BerkSmash1984]]></dc:creator><pubDate>Tue, 03 Oct 2023 12:59:04 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 09:13:50 GMT]]></title><description><![CDATA[<p dir="auto">I also had this problem, using Buster on a Raspberry pi 3b.</p>
<p dir="auto">It started with my npm being to old, unable to upgrade because my node was to old.<br />
Installing the newest node gave me the `GLIBCXX_3.4.26’ not found (required by node) error.</p>
<p dir="auto">The solution for me was installing the LTS version of node using nvm.</p>
<pre><code>nvm install 'lts/*' --reinstall-packages-from=current
nvm alias default 18
<p dir="auto">this uses node version 18.</p>
<p dir="auto">after that I could upgrade npm</p>
<pre><code>nvm install-latest-npm
<p dir="auto">and with all this in place the upgrade of magic mirror worked.</p>
<p dir="auto">Hope this helps</p>
]]></description><link>https://forum.magicmirror.builders/post/111227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111227</guid><dc:creator><![CDATA[SuperSchenk]]></dc:creator><pubDate>Tue, 03 Oct 2023 09:13:50 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 06:05:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> It does seem to work again on latest.</p>
]]></description><link>https://forum.magicmirror.builders/post/111225</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111225</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Tue, 03 Oct 2023 06:05:10 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Tue, 03 Oct 2023 00:18:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a>  <a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a>  and any others… I screwed up for the non-buster systems…</p>
<p dir="auto">please try my scripts again… they should FIX the problems encountered…</p>
<p dir="auto">I remove the current node and then install the correct…  18 for buster, 20 for bullseye</p>
]]></description><link>https://forum.magicmirror.builders/post/111224</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111224</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Oct 2023 00:18:51 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Mon, 02 Oct 2023 23:55:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/croc_dad72" aria-label="Profile: croc_dad72">@<bdi>croc_dad72</bdi></a> did u run the node20_install.sh script?  by itself?</p>
<p dir="auto">I have to go test it again</p>
]]></description><link>https://forum.magicmirror.builders/post/111223</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111223</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 Oct 2023 23:55:20 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Mon, 02 Oct 2023 23:46:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> now im getting this when I start it up? Any thoughts?</p>
<pre><code>macserver@EDITHs-MacBook-Pro magicmirror % npm run server
evalmachine.&lt;anonymous&gt;:42
} = primordials;
ReferenceError: primordials is not defined
    at evalmachine.&lt;anonymous&gt;:42:5
    at Object.&lt;anonymous&gt; (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
    at Module._compile (node:internal/modules/cjs/loader:1254:14)
    at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
    at Module.load (node:internal/modules/cjs/loader:1117:32)
    at Module._load (node:internal/modules/cjs/loader:958:12)
    at Module.require (node:internal/modules/cjs/loader:1141:19)
    at require (node:internal/modules/cjs/helpers:110:18)
    at Object.&lt;anonymous&gt; (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
Node.js v18.15.0
<p dir="auto">Tried running the node upgrade but that seem to fail too?</p>
]]></description><link>https://forum.magicmirror.builders/post/111222</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111222</guid><dc:creator><![CDATA[croc_dad72]]></dc:creator><pubDate>Mon, 02 Oct 2023 23:46:05 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Mon, 02 Oct 2023 22:50:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">for my buster install:</p>
<p dir="auto">Ran  “apply” re-run did bring back PM2 and other tools -  No MagicMirror though. Says it’s running, but doesn’t appear.</p>
<p dir="auto">Running “force” re-run same result.</p>
<pre><code>0|MagicMirror  | &gt; magicmirror@2.25.0 start
0|MagicMirror  | &gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
0|MagicMirror  | [02.10.2023 15:49.10.094] [LOG]   Starting MagicMirror: v2.25.0
0|MagicMirror  | [02.10.2023 15:49.10.101] [LOG]   Loading config ...
0|MagicMirror  | [02.10.2023 15:49.10.105] [DEBUG] config template file not exists, no envsubst
0|MagicMirror  | [02.10.2023 15:49.10.112] [LOG]   Loading module helpers ...
0|MagicMirror  | [02.10.2023 15:49.10.114] [LOG]   No helper found for module: MMM-MagicMover.
0|MagicMirror  | [02.10.2023 15:49.10.116] [LOG]   No helper found for module: alert.
0|MagicMirror  | [02.10.2023 15:49.10.297] [LOG]   Initializing new module helper ...
0|MagicMirror  | [02.10.2023 15:49.10.298] [LOG]   Module helper loaded: calendar
0|MagicMirror  | [02.10.2023 15:49.10.319] [LOG]   Initializing new module helper ...
0|MagicMirror  | [02.10.2023 15:49.10.320] [LOG]   Module helper loaded: MMM-CommandToNotification
0|MagicMirror  | [02.10.2023 15:49.10.322] [LOG]   No helper found for module: clock.
0|MagicMirror  | [02.10.2023 15:49.10.323] [LOG]   No helper found for module: MMM-Worldclock.
0|MagicMirror  | [02.10.2023 15:49.10.326] [LOG]   Initializing new module helper ...
0|MagicMirror  | [02.10.2023 15:49.10.327] [LOG]   Module helper loaded: MMM-ValuesByNotification
0|MagicMirror  | [02.10.2023 15:49.10.328] [LOG]   No helper found for module: MMM-Multimonth.
0|MagicMirror  | [02.10.2023 15:49.10.331] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
0|MagicMirror  | [02.10.2023 15:49.10.332] [LOG]   No helper found for module: MMM-CalendarExt3.
0|MagicMirror  | [02.10.2023 15:49.10.463] [LOG]   Initializing new module helper ...
0|MagicMirror  | [02.10.2023 15:49.10.464] [LOG]   Module helper loaded: newsfeed
0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Initializing new module helper ...
0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Initializing new module helper ...
0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Module helper loaded: updatenotification
0|MagicMirror  | [02.10.2023 15:49.10.856] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
0|MagicMirror  | Require stack:
0|MagicMirror  | - /home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js
0|MagicMirror  | - /home/bkey1970/MagicMirror/js/app.js
0|MagicMirror  | - /home/bkey1970/MagicMirror/js/electron.js
0|MagicMirror  | - /home/bkey1970/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
0|MagicMirror  | -
0|MagicMirror  |     at node:internal/modules/cjs/loader:1084:15
0|MagicMirror  |     at Function.&lt;anonymous&gt; (node:electron/js2c/browser_init:2:117419)
0|MagicMirror  |     at Module._resolveFilename (/home/bkey1970/MagicMirror/node_modules/module-alias/index.js:49:29)
0|MagicMirror  |     at node:internal/modules/cjs/loader:929:27
0|MagicMirror  |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1150:19)
0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:110:18)
0|MagicMirror  |     at Object.&lt;anonymous&gt; (/home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
0|MagicMirror  |     at Object..js (node:internal/modules/cjs/loader:1326:10)
0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:1126:32)
0|MagicMirror  |     at node:internal/modules/cjs/loader:967:12
0|MagicMirror  |     at loadModule (/home/bkey1970/MagicMirror/js/app.js:180:19)
0|MagicMirror  | (Use `electron --trace-warnings ...` to show where the warning was created)
0|MagicMirror  | [02.10.2023 15:49.10.857] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
0|MagicMirror  | [7847:1002/154911.190579:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
0|MagicMirror  | MESA-LOADER: failed to retrieve device information
0|MagicMirror  | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
0|MagicMirror  | failed to load driver: kms_swrast
0|MagicMirror  | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
0|MagicMirror  | failed to load swrast driver
]]></description><link>https://forum.magicmirror.builders/post/111221</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111221</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 02 Oct 2023 22:50:14 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Mon, 02 Oct 2023 18:51:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> try the upgrade script again, with force instead of apply</p>
<p dir="auto">it will remove and and add the right version the right way, including on buster</p>
<p dir="auto">please advise your results…</p>
]]></description><link>https://forum.magicmirror.builders/post/111198</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111198</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 Oct 2023 18:51:05 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade errors? on Mon, 02 Oct 2023 17:17:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks Sam. I already broke my dev machine. How do I clean install 2.24.0?</p>
]]></description><link>https://forum.magicmirror.builders/post/111196</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111196</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Mon, 02 Oct 2023 17:17:21 GMT</pubDate></item></channel></rss>
