<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error updating MM]]></title><description><![CDATA[<p dir="auto">Hi Everyone</p>
<p dir="auto">My MM upgrade seems to have hit abit of a snag. Here is the log file after trying to update.  The error I’m getting seems to be a little bit different to the other ones posted here (but root cause probably the same). Does anyone have any tips on how to get my MM running again?</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"  force
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
  libc-ares2 libuv1 rpi-eeprom-images
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
  nodejs*
0 upgraded, 0 newly installed, 1 to remove and 404 not upgraded.
After this operation, 185 MB disk space will be freed.
(Reading database ... 100567 files and directories currently installed.)
Removing nodejs (20.8.0-1nodesource1) ...
dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules' not empty so not removed
Processing triggers for man-db (2.8.5-2) ...
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
ca-certificates is already the newest version (20200601~deb10u2).
curl is already the newest version (7.64.0-4+deb10u6).
gnupg is already the newest version (2.2.12-1+rpi1+deb10u1).
0 upgraded, 0 newly installed, 0 to remove and 404 not upgraded.
deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
Get:1 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
Get:2 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5,267 B]
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
Hit:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
Fetched 17.4 kB in 34s (507 B/s)
The following NEW packages will be installed:
  nodejs
0 upgraded, 1 newly installed, 0 to remove and 404 not upgraded.
Need to get 0 B/26.8 MB of archives.
After this operation, 177 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ... 94745 files and directories currently installed.)
Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
Unpacking nodejs (18.18.0-1nodesource1) ...
Setting up nodejs (18.18.0-1nodesource1) ...
doing test run = false
update log will be in /home/pi/MagicMirror/installers/upgrade.log
Check current Node installation ...
Node currently installed. Checking version number.
Minimum Node version: v18.18.0
Installed Node version: v16.11.1
Node should be upgraded.
Installing Node.js ...
gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
The following packages will be upgraded:
  nodejs
1 upgraded, 0 newly installed, 0 to remove and 404 not upgraded.
Need to get 0 B/27.0 MB of archives.
After this operation, 5,819 kB of additional disk space will be used.
apt-listchanges: Reading changelogs...
(Reading database ... 100369 files and directories currently installed.)
Preparing to unpack .../nodejs_20.5.1-deb-1nodesource1_armhf.deb ...
Unpacking nodejs (20.5.1-deb-1nodesource1) over (18.18.0-1nodesource1) ...
Setting up nodejs (20.5.1-deb-1nodesource1) ...
node version is
Node.js installation Done! version=v16.11.1
force: line 240: [: too many arguments
Check current NPM installation ...
NPM currently installed. Checking version number.
Minimum npm version: V9.8.1
Installed npm version: V8.0.0
npm should be upgraded.
Installing npm ...
E: Unable to correct problems, you have held broken packages.
npm ERR! code EBADENGINE
npm ERR! engine Unsupported engine
npm ERR! engine Not compatible with your version of node/npm: npm@9.8.1
npm ERR! notsup Not compatible with your version of node/npm: npm@9.8.1
npm ERR! notsup Required: {"node":"^14.17.0 || ^16.13.0 || &gt;=18.0.0"}
npm ERR! notsup Actual:   {"npm":"8.0.0","node":"v16.11.1"}
npm ERR!     /root/.npm/_logs/2023-10-04T14_24_00_147Z-debug.log
npm installation Done! version=V8.0.0
saving custom.css
upgrading from version 2.25.0 to 2.25.0
fetching latest revisions
updating MagicMirror runtime, please wait
npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.25.0
npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.25.0
npm ERR! notsup Required: {"node":"&gt;=18"}
npm ERR!     /home/pi/.npm/_logs/2023-10-04T14_24_06_797Z-debug.log
Checking for modules with removed libraries
processing dependency changes for active modules with package.json files
]]></description><link>https://forum.magicmirror.builders/topic/18048/error-updating-mm</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 04:27:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18048.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Oct 2023 14:28:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error updating MM on Sun, 08 Oct 2023 09:08:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sil3ntstorm" aria-label="Profile: sil3ntstorm">@<bdi>sil3ntstorm</bdi></a> i make  sudo rm -r /usr/lib/node_modules<br />
then i used the upgrade-script<br />
bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh</a>)” apply.<br />
the script above<br />
bash -c “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh</a>)”<br />
not work for me, error arch=: Zeile 1: “#!/bin/bash: Datei oder Verzeichnis nicht gefunden.</p>
<p dir="auto">after that i make npm install in the MagicMirror directory. Now all works fine for me</p>
]]></description><link>https://forum.magicmirror.builders/post/111454</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111454</guid><dc:creator><![CDATA[stoffel]]></dc:creator><pubDate>Sun, 08 Oct 2023 09:08:41 GMT</pubDate></item><item><title><![CDATA[Reply to Error updating MM on Sat, 07 Oct 2023 21:30:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevmang" aria-label="Profile: kevmang">@<bdi>kevmang</bdi></a> Did you completely empty the node_modules folder? Did you have to run bash again from above?<br />
And then you had to completely reinstall all the modules you previously had on it?</p>
]]></description><link>https://forum.magicmirror.builders/post/111441</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111441</guid><dc:creator><![CDATA[sil3ntstorm]]></dc:creator><pubDate>Sat, 07 Oct 2023 21:30:06 GMT</pubDate></item><item><title><![CDATA[Reply to Error updating MM on Sat, 07 Oct 2023 02:38:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevmang" aria-label="Profile: kevmang">@<bdi>kevmang</bdi></a> awesome,!!!  thanks for the feedback</p>
]]></description><link>https://forum.magicmirror.builders/post/111424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111424</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Oct 2023 02:38:24 GMT</pubDate></item><item><title><![CDATA[Reply to Error updating MM on Sat, 07 Oct 2023 02:16:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for the help! Used force to re-install MagicMirror again but still had an electron issue so I deleted the entier node_modules director as wel as the package_lock file and re-installed the modules. Then I had an error with MMM-MyCalendar which I fixed using the advice from here: <a href="https://github.com/jclarke0000/MMM-MyCalendar/issues/40" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jclarke0000/MMM-MyCalendar/issues/40</a></p>
<p dir="auto">Most importantly everything works just fine now :) Thanks again!</p>
]]></description><link>https://forum.magicmirror.builders/post/111423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111423</guid><dc:creator><![CDATA[kevmang]]></dc:creator><pubDate>Sat, 07 Oct 2023 02:16:00 GMT</pubDate></item><item><title><![CDATA[Reply to Error updating MM on Fri, 06 Oct 2023 12:36:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevmang" aria-label="Profile: kevmang">@<bdi>kevmang</bdi></a></p>
<p dir="auto">local version 2.25.0 already same as master 2.25.0</p>
<p dir="auto">you need to use force  on the upgrade  command instead of apply</p>
<p dir="auto">also, show the output of npm start</p>
]]></description><link>https://forum.magicmirror.builders/post/111405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111405</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 06 Oct 2023 12:36:11 GMT</pubDate></item><item><title><![CDATA[Reply to Error updating MM on Fri, 06 Oct 2023 08:53:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for your advice. I’ve completely removed npm and node and that solved the errors when installing but MM still doesn’t appear. Here is the log from the install:</p>
<pre><code>pi@raspberrypi:~$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
  nodejs*
0 upgraded, 0 newly installed, 1 to remove and 401 not upgraded.
After this operation, 177 MB disk space will be freed.
(Reading database ... 100354 files and directories currently installed.)
Removing nodejs (18.18.0-1nodesource1) ...
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
0 upgraded, 0 newly installed, 0 to remove and 401 not upgraded.
deb [  signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:4 http://archive.raspberrypi.org/debian buster InRelease
Fetched 17.4 kB in 1s (15.1 kB/s)
  nodejs
0 upgraded, 1 newly installed, 0 to remove and 401 not upgraded.
(Reading database ... 94730 files and directories currently installed.)
Installed Node version: v18.18.0
No Node.js upgrade necessary.
Installed npm version: V9.8.1
No npm upgrade necessary.
saving custom.css
restoring custom.css
]]></description><link>https://forum.magicmirror.builders/post/111400</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111400</guid><dc:creator><![CDATA[kevmang]]></dc:creator><pubDate>Fri, 06 Oct 2023 08:53:39 GMT</pubDate></item><item><title><![CDATA[Reply to Error updating MM on Wed, 04 Oct 2023 14:36:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevmang" aria-label="Profile: kevmang">@<bdi>kevmang</bdi></a> also, do these commands</p>
<p dir="auto">nvm<br />
and<br />
n</p>
<p dir="auto">I wonder if there was a separate way to install node…</p>
<p dir="auto">I know  I use them at times…</p>
]]></description><link>https://forum.magicmirror.builders/post/111317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111317</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 04 Oct 2023 14:36:21 GMT</pubDate></item><item><title><![CDATA[Reply to Error updating MM on Wed, 04 Oct 2023 14:34:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevmang" aria-label="Profile: kevmang">@<bdi>kevmang</bdi></a> said in <a href="/post/111315">Error updating MM</a>:</p>
<p dir="auto">The following NEW packages will be installed:<br />
nodejs<br />
0 upgraded, 1 newly installed, 0 to remove and 404 not upgraded.<br />
Need to get 0 B/26.8 MB of archives.<br />
After this operation, 177 MB of additional disk space will be used.<br />
Selecting previously unselected package nodejs.<br />
(Reading database … 94745 files and directories currently installed.)<br />
Preparing to unpack …/nodejs_18.18.0-1nodesource1_armhf.deb …<br />
Unpacking nodejs (18.18.0-1nodesource1) …<br />
Setting up nodejs (18.18.0-1nodesource1) …<br />
Processing triggers for man-db (2.8.5-2) …</p>
<p dir="auto">yeh, thats interesting…   says success and failure at the same time, but DID fail…</p>
<p dir="auto">can u run this my itself<br />
bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh</a>)”</p>
]]></description><link>https://forum.magicmirror.builders/post/111316</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111316</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 04 Oct 2023 14:34:43 GMT</pubDate></item></channel></rss>
