<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Config.js Changes No Longer Auto-Load in MagicMirror (MM)"]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I’ve updated to version 2.25.0, and everything seems fine. However, I’ve noticed that when I make changes in the Config.js file and press Ctrl + O to save, the new configuration is no longer automatically loaded by MagicMirror (MM). What could be the reason for this?</p>
<p dir="auto">For now, I’ve been manually reloading the newly saved configuration by running ‘pm2 stop MM’ followed by ‘pm2 restart.’ Is there another way to do this, or is it possibly a new feature?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18062/config-js-changes-no-longer-auto-load-in-magicmirror-mm</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 14:37:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18062.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Oct 2023 16:15:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Config.js Changes No Longer Auto-Load in MagicMirror (MM)" on Sat, 07 Oct 2023 16:27:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chazzer" aria-label="Profile: Chazzer">@<bdi>Chazzer</bdi></a> Yes sadly they keep changing the libraries and what they do in the node system.<br />
sometimes file change notices or watched and sometimes they’re not. mostly not</p>
<pre><code>pm2 restart all
<p dir="auto">will do the same thing.</p>
]]></description><link>https://forum.magicmirror.builders/post/111436</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111436</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Oct 2023 16:27:50 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js Changes No Longer Auto-Load in MagicMirror (MM)" on Sat, 07 Oct 2023 17:08:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Oh, that was quick with the response, thanks! Well, that’s just the way it is!</p>
]]></description><link>https://forum.magicmirror.builders/post/111437</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111437</guid><dc:creator><![CDATA[Chazzer]]></dc:creator><pubDate>Sat, 07 Oct 2023 17:08:15 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js Changes No Longer Auto-Load in MagicMirror (MM)" on Sat, 07 Oct 2023 16:27:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chazzer" aria-label="Profile: Chazzer">@<bdi>Chazzer</bdi></a> Yes sadly they keep changing the libraries and what they do in the node system.<br />
]]></description><link>https://forum.magicmirror.builders/post/111436</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111436</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Oct 2023 16:27:50 GMT</pubDate></item></channel></rss>
