<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Touchscreen works wrong when screen is rotated vertical]]></title><description><![CDATA[<p dir="auto">I want to use my touchscreen vertically, but when I do that, the touch can’t click right. It’s like the mouse won’t turn side to vertical.</p>
<p dir="auto">I have tried the screen with my PC, works perfect. It’s something between the screen, Rasperry pi and the Magic Mirror. Anybody have an idea about what? I do the rotate with the “screen layoute editor”. Have tried reebot.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18064/touchscreen-works-wrong-when-screen-is-rotated-vertical</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 13:54:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18064.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Oct 2023 20:57:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Sun, 08 Oct 2023 09:51:17 GMT]]></title><description><![CDATA[<p dir="auto">You need to edit the touch matrix. Full tutorial here <a href="https://www.gechic.com/en/raspberry-pi-touch-monitor-rotate-touch-screen-rotate-settings/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.gechic.com/en/raspberry-pi-touch-monitor-rotate-touch-screen-rotate-settings/</a> but it’s usally done by editing your40-libinput.conf in /etc/xorg.d.</p>
]]></description><link>https://forum.magicmirror.builders/post/111456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111456</guid><dc:creator><![CDATA[viktorzonix]]></dc:creator><pubDate>Sun, 08 Oct 2023 09:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Sun, 15 Oct 2023 07:12:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manino" aria-label="Profile: Manino">@<bdi>Manino</bdi></a> glad I could help :)</p>
]]></description><link>https://forum.magicmirror.builders/post/111752</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111752</guid><dc:creator><![CDATA[viktorzonix]]></dc:creator><pubDate>Sun, 15 Oct 2023 07:12:52 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Mon, 09 Oct 2023 13:32:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ahaaa! Thought you talk about the driver for the monitor.</p>
]]></description><link>https://forum.magicmirror.builders/post/111477</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111477</guid><dc:creator><![CDATA[Manino]]></dc:creator><pubDate>Mon, 09 Oct 2023 13:32:40 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Mon, 09 Oct 2023 11:17:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manino" aria-label="Profile: Manino">@<bdi>Manino</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/viktorzonix" aria-label="Profile: viktorzonix">@<bdi>viktorzonix</bdi></a>  told you how to tell the driver the orientation changed.  I just didn’t know how</p>
]]></description><link>https://forum.magicmirror.builders/post/111473</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111473</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 Oct 2023 11:17:52 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Mon, 09 Oct 2023 08:07:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Driver was only for Windows. I have buttons on the screen, but could’nt choose to rotate screen. All text was black except the one for rotate that was grey.</p>
<p dir="auto">Maybe it’s because of this, found in the Dell manuall :  NOTE: “Horizontal Position and Vertical Position adjustments<br />
are only available for “VGA” input.”</p>
<p dir="auto">I’m using HDMI. I don’t even know if the VGA would have solved my problem. But no need to know,  <a class="plugin-mentions-user plugin-mentions-a" href="/user/viktorzonix" aria-label="Profile: viktorzonix">@<bdi>viktorzonix</bdi></a> solved the problem for us. So glad for u guys helping, I haven’t asked one question at MM forum and not getting helped.</p>
]]></description><link>https://forum.magicmirror.builders/post/111472</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111472</guid><dc:creator><![CDATA[Manino]]></dc:creator><pubDate>Mon, 09 Oct 2023 08:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Mon, 09 Oct 2023 07:48:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/viktorzonix" aria-label="Profile: viktorzonix">@<bdi>viktorzonix</bdi></a> Yes, that’s it. Thank you so much, can’t describe how glad I am for this, I really appreciate you share this for us!</p>
]]></description><link>https://forum.magicmirror.builders/post/111475</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111475</guid><dc:creator><![CDATA[Manino]]></dc:creator><pubDate>Mon, 09 Oct 2023 07:48:57 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Sun, 08 Oct 2023 20:22:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/viktorzonix" aria-label="Profile: viktorzonix">@<bdi>viktorzonix</bdi></a>  Wow! Thanks for this. In my searching a couple of years ago, this never came up and nothing else ever had the correct info. I had just lived with the fact that I had to keep re-entering it periodically. Woo hoo!</p>
]]></description><link>https://forum.magicmirror.builders/post/111467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111467</guid><dc:creator><![CDATA[almightyyoshi]]></dc:creator><pubDate>Sun, 08 Oct 2023 20:22:43 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Sun, 08 Oct 2023 11:15:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manino" aria-label="Profile: Manino">@<bdi>Manino</bdi></a> You have to do a couple of things. The best explanation is <a href="https://wiki.ubuntu.com/X/InputCoord" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>. Basically, find the name of your monitor, and then do this command in terminal:</p>
<p dir="auto">xinput set-prop ‘<strong>name of your device</strong>’ ‘Coordinate Transformation Matrix’ 0 1 0 - 1 0 1 0 0 1</p>
<p dir="auto">This will rotate the touch controls to the right (depending on which way you turned your monitor, this might have to be adjusted). The only problem is that I haven’t found a way to make it permanent (in Raspbian), so it reverts every so often and you have to run the command again. I’ve written it to etc, but it doesn’t take. If anyone has any suggestions for permanence, I’d love to hear it.</p>
]]></description><link>https://forum.magicmirror.builders/post/111449</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111449</guid><dc:creator><![CDATA[almightyyoshi]]></dc:creator><pubDate>Sun, 08 Oct 2023 11:15:05 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Sun, 08 Oct 2023 09:51:17 GMT]]></title><description><![CDATA[<p dir="auto">You need to edit the touch matrix. Full tutorial here <a href="https://www.gechic.com/en/raspberry-pi-touch-monitor-rotate-touch-screen-rotate-settings/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.gechic.com/en/raspberry-pi-touch-monitor-rotate-touch-screen-rotate-settings/</a> but it’s usally done by editing your40-libinput.conf in /etc/xorg.d.</p>
]]></description><link>https://forum.magicmirror.builders/post/111456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111456</guid><dc:creator><![CDATA[viktorzonix]]></dc:creator><pubDate>Sun, 08 Oct 2023 09:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to Touchscreen works wrong when screen is rotated vertical on Sat, 07 Oct 2023 23:02:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manino" aria-label="Profile: Manino">@<bdi>Manino</bdi></a> must be a touch screen driver  needing to know screen orientation changed.</p>
<p dir="auto">display support on pi is very private compared to Windows or linux</p>
]]></description><link>https://forum.magicmirror.builders/post/111444</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111444</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Oct 2023 23:02:24 GMT</pubDate></item></channel></rss>
