<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How many modules are working]]></title><description><![CDATA[<p dir="auto">I just installed MM on a Pi 4 - no issues.  Default modules are ok, added Ecobee that was good, added Yahoo finance and that was good, but then just about any other I tried it didn’t work.  iFrame modules don’t seem to work (any of them),  flight tracking, and a few others then I decided after installing then removing close to a dozen I thought I would ask - how much is actually working.  Most of the repo’s are over a year since last update, others are years.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18073/how-many-modules-are-working</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 15:38:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18073.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Oct 2023 22:13:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How many modules are working on Wed, 11 Oct 2023 09:25:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mgustin" aria-label="Profile: mgustin">@<bdi>mgustin</bdi></a><br />
As long as it works properly, there is no need to update it just to look “active”</p>
<p dir="auto">“Working or not” implies various cases, not a simple reason.</p>
<ul>
<li>Worked before, but not now, due to obsoleted/deprecated dependencies.
<ul>
<li>Some might be fixable easily with a tiny effort. (e.g. install a few recent/alternative  dependencies)</li>
<li>Some might need the whole restructuring, and the module owner seems to have abandoned it; &lt;= It can be said that “Not Working”</li>
</ul>
</li>
<li>In some cases, A user is just misusing the module. For example, incomplete installation, wrong configuration, mistypes, missing preparation, choosing the wrong module that is not fit for the purpose, etc.</li>
<li>And there are many (yes, maybe too many) equivalent/alternative modules you can try.  Cheer up.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/111570</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111570</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Wed, 11 Oct 2023 09:25:46 GMT</pubDate></item><item><title><![CDATA[Reply to How many modules are working on Tue, 10 Oct 2023 23:22:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mgustin" aria-label="Profile: mgustin">@<bdi>mgustin</bdi></a> nobody tracks modules working.<br />
they are all voluntary submissions.</p>
<p dir="auto">no commitment to maintain</p>
]]></description><link>https://forum.magicmirror.builders/post/111563</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111563</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 10 Oct 2023 23:22:45 GMT</pubDate></item></channel></rss>
