<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2.25 language &#x27;nl&#x27; not working]]></title><description><![CDATA[<p dir="auto">After the update to 2.25 everything is in English.<br />
My config.js is not changed.</p>
<pre><code>let config = {
        address : '0.0.0.0',
        port: 8080,
        basepath: "/",
        ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120", "192.168.1.1/24"],
        language: "nl",
        timeFormat: 24,
        units: "metric",
<p dir="auto">Anybody an idea??</p>
]]></description><link>https://forum.magicmirror.builders/topic/18078/2-25-language-nl-not-working</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 01:32:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18078.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Oct 2023 20:11:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2.25 language &#x27;nl&#x27; not working on Mon, 23 Oct 2023 16:00:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a></p>
<p dir="auto">Message from MMM-OnSpotify.</p>
<pre><code>Its now fixed in V3.1.0, both the icon color change (now the helper css classes are loaded on a separated file),
and the clock translation error (locale settings were getting overwritten by the module instance of the moment library).
<p dir="auto">Installed the update and problem solved.<br />
Thanks for helping!</p>
]]></description><link>https://forum.magicmirror.builders/post/112001</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112001</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Mon, 23 Oct 2023 16:00:59 GMT</pubDate></item><item><title><![CDATA[Reply to 2.25 language &#x27;nl&#x27; not working on Tue, 17 Oct 2023 03:40:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> tried everything as told in the readme, but no luck. Currently disabled that module.</p>
]]></description><link>https://forum.magicmirror.builders/post/111808</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111808</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 17 Oct 2023 03:40:12 GMT</pubDate></item><item><title><![CDATA[Reply to 2.25 language &#x27;nl&#x27; not working on Tue, 17 Oct 2023 00:08:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> onSpotify changes all the colors. the readme describes how to undo that.</p>
<p dir="auto">but this  module only has English(en) and Spanish (es)<br />
but he describes what to do for your language</p>
]]></description><link>https://forum.magicmirror.builders/post/111801</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111801</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Oct 2023 00:08:11 GMT</pubDate></item><item><title><![CDATA[Reply to 2.25 language &#x27;nl&#x27; not working on Mon, 16 Oct 2023 18:28:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
So, restored ‘old’ version and update MM. No problem, only MMM-MyCalendar causes to stop MM. Disable MMM-MyCalendar and everything works fine. But…</p>
<p dir="auto">When I update MMM-OnSpotify, than the complete MM is in English instead of Dutch. Also the colors of the Icons in the Calendar Module change from Red to default.<br />
When I disable MMM-OnSpotify, than everything turns to normal (Dutch language and Red Icons in Calendar).</p>
<p dir="auto">Strange thing, now I’ve to look why MMM-OnSpotify causes this issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/111796</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111796</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Mon, 16 Oct 2023 18:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to 2.25 language &#x27;nl&#x27; not working on Fri, 13 Oct 2023 03:46:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I have a backup from 1 week ago so I first go back to that backup (previous version of MM), update again and see what happens. Everything started when MMM- MyCalandar stopped because of ‘fetch’ change and I didn’t realize that it wasn’t a problem from PiOS or MM.</p>
]]></description><link>https://forum.magicmirror.builders/post/111690</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111690</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Fri, 13 Oct 2023 03:46:26 GMT</pubDate></item><item><title><![CDATA[Reply to 2.25 language &#x27;nl&#x27; not working on Thu, 12 Oct 2023 22:33:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I tested <code>language: "nl"</code> and it works so this is no general problem</p>
]]></description><link>https://forum.magicmirror.builders/post/111677</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111677</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Thu, 12 Oct 2023 22:33:32 GMT</pubDate></item><item><title><![CDATA[Reply to 2.25 language &#x27;nl&#x27; not working on Thu, 12 Oct 2023 21:51:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> wild… I suggest you open an issue in the MM github repo.</p>
]]></description><link>https://forum.magicmirror.builders/post/111672</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111672</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Oct 2023 21:51:44 GMT</pubDate></item><item><title><![CDATA[Reply to 2.25 language &#x27;nl&#x27; not working on Thu, 12 Oct 2023 21:38:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> first manual, after that your script.</p>
]]></description><link>https://forum.magicmirror.builders/post/111671</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111671</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Thu, 12 Oct 2023 21:38:42 GMT</pubDate></item><item><title><![CDATA[Reply to 2.25 language &#x27;nl&#x27; not working on Thu, 12 Oct 2023 20:51:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> how did you upgrade?  manual or my script?</p>
]]></description><link>https://forum.magicmirror.builders/post/111669</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111669</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Oct 2023 20:51:02 GMT</pubDate></item></channel></rss>
