<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Screen not fulling shutting off.]]></title><description><![CDATA[<p dir="auto">Hello Team, I have a minor issue,  I am using the module EXT-Screen, and it’s currently working; however, it doesn’t fully shut off. I can see the backlight of the monitor still on and most noticeable at night, the old MM 2.24.0 worked correctly, I’m not sure if I have to modify the /boot/config.txt? I’ve done something years ago, had a similar issue. Thanks for the help and all the work the Team put in.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18091/screen-not-fulling-shutting-off</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 20:46:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18091.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 15 Oct 2023 17:40:09 GMT</pubDate><ttl>60</ttl></channel></rss>
